12-08-2017, 08:45 AM
Lifting heavy RV hitch to receiver
I would like any comments concerning a device to lift an Equalizer (or any other brand) hitch, up to the truck receiver.
I have the handle, that attaches to the ball, and makes the lift easier than picking the thing up by hand.
Problem is I have had a back operation and near getting a second one. This has made the lift of the hitch somewhat painful.
Is there ANY lift device out there made especially for this type of lift?
I have looked at a Motorcycle Lift (hydraulic hand pump) but before investing in something like that, I’d like to hear of anything better.
Raise height is right at 18”. Thanks.
2017 F250 XL, Supercab, 6.2L Gas w/Tow Pkg
2017 Grey Wolf 26RR Limited, Toy Hauler
2016 Cricket Mini Golf Cart[SIGPIC]
12-08-2017, 09:31 AM
The “handle” that I spoke of is the HitchGrip. Still puts strain on back /shoulder when lifting hitch.
12-08-2017, 09:40 AM
Not specific for a hitch but I've seen a few of these recently.
Mostly for lifting propane tanks but could be used for anything.
HERC-U-LIFTS
12-08-2017, 10:36 AM
Harbor Freight has a series of lightweight aluminum racing jacks that might be of some use, and can do double duty as a handy jack for your tow vehicle. The max lift is a bit short, but it will get you close!
https://m.harborfreight.com/catalogs...&q=racing+jack
12-08-2017, 10:40 AM
I was going to suggest a custom made "cradle" on wheels that the hitch sits in with an area underneath that can receive a floor jack. But after looking at that device offered by 5 Picker, I think that is your tool.
You can lift your hitch, spare and propane bottles with that. And if it is collapsible, that's even better.
I leave my hitch on my TV. It offers a little weight for a better ride and since I have already been rear ended once in these parts, it offers some protection for my truck. It will definitely stop any bumper headed my way and put the hurt on someones radiator. If you are stupid enough to rear end me, then I am smart enough to protect my vehicle and not give a damm about yours.
RMc
12-08-2017, 10:54 AM
I went through this evaluation a couple of years ago. I had a perfectly good Equalizer 4-point hitch that worked well but the ball housing was around 58lbs and too heavy to lift with bad back (surgery). Since I paid $800-$900 for it installed by dealer I looked for solutions to lift the housing but on paper nothing seemed a workable solution for me. I wound up buying an Andersen WDH that is much lighter for me to lift. It solved my problem and I have no complaints with sway control or distribution of weight to front wheels of TV and it’s easy on/off and backing up is no problem.
2010 Toyota Tundra DC SR5 5.7l 4x4
2020 Grand Design Imagine XLS 22MLE
Andersen WDH
2018 Rockwood Mini Lite 2104s
2014 Jayco x17z Hybrid
12-08-2017, 01:19 PM
HERC-U-LIFTS
This looks like the cats meow ~ but all I see is a boat hand winch, a pulley and a few pieces of metal. A bit of southern ingenuity, a picture and something similar could be fabricated ... even a bit smaller if needed.
12-08-2017, 01:24 PM
Senior Gold Member
Heavy lifting
I am 70 and quite often get a nice young man from the neighborhood to help with heavy lifts like my Honda 3000 generator into the truck. It doesn’t take long and young viril people are usually happy to do it. The problem with gizmos is you have another thing to carry around.
12-08-2017, 01:25 PM
I give a young guy in my neighborhood $10 and he does it for me. There are nice younger people around.
12-08-2017, 01:47 PM
Whoa! I have an Equal-i-zer hitch and have no problem getting the bars in place (I'm 75) because I use the power tongue jack to lift the connected hitch up (the tongue has been dropped onto the ball and secured) to remove all of the tongue weight. The bars simply swing into place and can be secured (if the bar needs to be used, it is a simple pull up). Once the bars are in place, the tongue jack is reversed and stored for travel; the bars then take on their weight distribution role without hassle. Just reverse the process when unhitching.
Easy - peasy!
EDIT: I just re-read the OP and realize that the problem is to lift the heavy cast iron hitch and ball assembly up and into the receiver. My bad! But I use the Hitch Grip Coupling Tool available from Amazon.com for under $30. It is still a bit of a heavy lift.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
12-08-2017, 02:02 PM
Collision Protection
RMc
I've wondered about this, does the hitch really protect the vehicle? There is a web site which markets a device which is shock absorbing, mounted in the receiver, claimed to protect against damage from collision. It is to be used when not towing.
The rationale is this: The vehicle body is designed to provide a "crumple zone" which absorbs impact, protecting not only the occupants, but also the vehicle frame as well, by making a "softer" collision.
The claim is that the body damage is most often repairable, but frame damage could be serious enough to make a write off of the whole vehicle mandatory.
The logic is attractive, but the device is pricey. Has anyone else heard of this, or perhaps purchased one?
12-08-2017, 02:11 PM
2019 Silverado 1500
No camper, currently
12-08-2017, 02:13 PM
I too researched this problem since I also share your problem of lifting the hitch. I used to have an Air Safe with Equalizer sway and WD. The ride was fantastic, towing 10,000 pounds. Our trailer was so stable we could leave a glass of water on the counter and have it there un-spilled after a day's driving.
The problem was the 80# Air Safe, then the Equalizer bars. I do have a kind neighbor who always lifted it on and off but at a campsite we had to leave it on the truck. I tried lifts, jacks, custom shelves and MacGyvered Gadgets, nothing worked or they were too cumbersome for me to handle. We sold the trailer with the Air Safe, downsized and now use nothing other than a ball on the receiver. Good Luck to you I feel your pain.
Chummy V
2014 Forester 2501TS
Ford E-450
12-08-2017, 02:22 PM
Lifting The Hitch
I'm 82 and the hitch has suddenly become super heavy. I have the hitch ball lift, but it's still too heavy to move around. Sooo...I built a little wooden cart on wheels that places the hitch at the same height as the receiver. Now, I roll the hitch up to the receiver, move it to the edge of the receiver and push it in. That's it. I don't have pictures, but it was simple to build with wood that was laying around, and a couple of cheap plastic 3" wheels that I refused to throw away. The trick is to make the cart the right height for your tow vehicle.
12-08-2017, 02:27 PM
I bought a hitch pin with a lock. Locked it in and forgot about it until finding it always ready. Now I have a 5er,,,, much easier all around.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
12-08-2017, 02:43 PM
Put it on at the start of the season and leave it on. That way you only have to worry about it twice per year.
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
12-08-2017, 02:45 PM
Multi-Slacker
Leave it in. That's what we do because neither of us enjoys trying to pick it up. We do have a lock on it.
Safe Travels
12-08-2017, 02:52 PM
And if you reread a second time, you'd find he stated he already has the HitchGrip.
Family of six, camping in a Grey Wolf 26DBH LTD pushing a 2010 Armada via 10k/1k HaulMaster WDH stopped by a Prodigy P2 brake controller
Tug: 2010 2wd Nissan Armada Titanium with tow package.
Specs: Max Trailer Weight 9,100, Tongue Load: 910, GCWR: 15,100, GVWR: 7,150, Payload: 1,592
12-08-2017, 03:03 PM
AKA: 'tiredTeacher
I was given an inexpensive hand truck. I wheel the truck up to the mounted hitch head and using some spare, nylon 3-strand dock line, I tie the head to the hand cart, pull the pin and back the hand truck up pulling the head out. I store it tied to the truck so it's at the proper height to install by reversing the procedure. No lifting, no machinery. no expense.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
12-08-2017, 03:26 PM
Unless I'm mistaken, 'crumple zones' are designed into unibody cars, not body-on-frame trucks. Yes to protect passengers. Frame not a consideration.
I had a 1500 truck rear-ended a few years ago. I was stopped at a red light and a guy hit me at about 35mph. Totaled the truck, and the suburban that hit me. All body damage, no frame damage. No receiver hitch. Doubt it would have really made a difference in that case, or at any speed above that.
However, I do keep a stinger and ball in our minivan hitch when I'm driving for Uber. When working Friday nights downtown, some of the other drivers really crowd you, and I've been bumped. I figure at low speed the hitch will ensure the other driver is more likely to get the damage.
