New 24Gold14 Owner
Hello! Just purchased my first RV, ended up driving 600 miles from Texas to Illonois to pick it up since this model doesn't appear to be available locally.
I went into this with the expectations that RV's are far from perfect, even new, so I am trying to get everything figured out before I take the family out in it, my first mod is replacing the China bombs with USA Goodyears, I will check the axle grease while I have the wheels off. Other than that I plan to double check the sealant on the whole thing, I've already found a few spots they missed so I need to touch up the sealant. I've also found screws starting to back out, when I got it home one of the exterior screws vibrated out almost an inch and almost fell out. I also found what appears to be bolts for the sidewalls, where it attaches to the frame, the nuts on several were missing and a few more about ready to fall off, they look like 3/8 or so, I planned to put Nylon nuts on there to keep it from happening again.
Does anyone know what kind of sealant Cherokee uses on the sides? It looks mostly clear, feels a lot like silicone but at the same time it seems different.
Any other advice on what to check? I'm mostly worried about water damage and safety. I can't believe the bolts holding the walls to the frame had nuts missing! Thanks everyone!
