Old 06-05-2021, 01:40 PM   #1
Slide out
GM i have a 2019 wolf pack toy hauler 25pack 12 the sly out it seems like it hang from the top before it pull out anyone had this happen any impute will help thank you in advance
Travel man
travel man is offline   Reply With Quote
Old 06-06-2021, 07:00 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. If you are saying the bottom sections moves before the top but the unit slides out this is not unusual with rigs. Are you ensuring you are level with your stabilizers down before moving the slide? What does "GM" mean?
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-06-2021, 07:07 AM   #3
Depending on the slide mechanism that is relatively common and if top and bottom end up fully extended or retracted at the end of the cycle it isn't a problem. Some mechanisms are adjustable but it is probably not worth the effort if the lag is small.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 06-06-2021, 09:24 AM   #4
slide out
Yes all level and notice the bottom start to pull out and the top will not yes wandering if this was normal on the wolf pack 25pack 12 yes was concern really appreciate the impute thank you Sir
Old 06-10-2021, 09:09 AM   #5
My large slide in my 365Pack16 does it all the time - bottom first, then top after bottom moves a couple of inches. Does it even when level. Just finished a 5000 mile trip where it was put in and out dozens of times. No problems.
Butch and Sharon
Goldsboro, NC
2020 Wolfpack 365Pack16
2018 Yamaha Star Venture TC in back
2020 GMC Sierra Denali 3500HD DRW
akf15e is offline   Reply With Quote
Old 06-10-2021, 10:34 AM   #6
If you have Accuslide actuators (cables at top and bottom of slide) this is easily adjusted by adjusting the 4 cable tensioners but if the slide closes completely and opens completely at top and bottom it is probably not worth it.
https://www.balrvproducts.com/produc...de/index.shtml
2015 335DS
slide
« Patio Ramp Awning? | - »
