Old 03-01-2024, 04:51 PM   #1
Wolf Pup 18RJB
I have a 2021 Wolf Pup 18RJB and have made the switch over to 2 100Ah ION batteries connected in parallel. BUT the solar on the system doesn't seem to charge the batteries at all. Do I need to get a different set up and what's does anyone suggest? I don't even know how the small panel that came with the RV even works. Total solar newbie and don't know much about it.
tazmanbob54 is offline   Reply With Quote
Old 03-01-2024, 07:23 PM   #2
bikendan's Avatar
Moved thread from the General Toyhauler Topics section to the Toyhauler section's Cherokee sub-forum since the OP's trailer is a Cherokee product.
Old 03-02-2024, 04:45 PM   #3
If you’re talking about the small panel that came on the trailer those are a feel good selling point. They are too small to do much especially if you’re trying to support 200 aH of lithium batteries.
I would suggest you search Solar charging and start reading.
You could start with an MPPT charge controller and about 300 watts of panels. That will give you a little more than a 12 volt refrigerator will use. If you’re not using the fridge it should top up those batteries pretty well.
MGD1961 is offline   Reply With Quote
wolf pup
