09-14-2012, 06:28 AM
#141
Originally Posted by ggphillips58
On my 2013 wolf pup 17rr tires have nitrogen in them with a sticker on the window telling all about the tires. There selling point was "quick lube axle" I have yet to put my Harley on board to tow because I want to keep it light on my first several trips. When I do load the motorcycle it will be very tight with there placement of the tie downs.
Welcome!
I say put the Harley in and go !
Why wait ?
Congrats on the new unit and Have fun.
Turbs
09-15-2012, 10:05 AM
#142
Originally Posted by librarian
When I saw the outside wheel placement my first thought was, "that's different" but on second thought it may be part of the problem regarding axle failure, the longer the axle the greater the tendency to bend.
The axle isn't any longer than standard because the trailer is narrower than many in class - that was a good point in our book, because the Jeep Grand Cherokee doesn't need huge towing mirrors to see behind the trailer, the standard mirrors are fine.
The same Lippert axles are found on many similar size trailers in class.
09-17-2012, 10:16 AM
#143
Originally Posted by i8zmnm
I just joined this forum today since I am planning on transitioning from my Fleetwood Arcadia high walled pop-up to a smaller hard sided travel trailer in the spring.
I narrowed down my choices to the Cherokee Wolf Pup, Forest River R-Pod 172, or Heartland MPG. I have been strongly leaning towards the Wold Pup, but this message thread is scaring the pants off me!
Is this axle problem limited to certain model years or is it universal?
I have a 2011 Wolf Pup 17RR and it has the 5000+lb torsion axle from the factory.
09-30-2012, 01:18 PM
#144
We've really blurred the line in this thread between the toy haulers and the travel trailers. The RR and RP models are toy haulers and likely have a different axle because they have to be rated for more weight.
12-05-2012, 09:49 AM
#145
Wolf Pup 17RP
All,
Just purchased a 2013 17RP about a month ago. Already took it camping a few times. Working out the kinks now and making it our own.
Few questions:
-Mine did not come with a furnace, Is it possible to add in one? We use a space heater and it works as long as we have it hooked up to an outside power source/generator. Trouble is also finding a low wattage heater.
-Water pump access to winterize? Turning it on, it sounds like it is up under the shower/toliet area. Is there any "Easy way" to get to it?
Sorry to be nit picky but can't really find anything specific on here via the search. Other than that We love the trailer and is just the right size for 2 people.
Anyone else out there have any issues or things I need to be worried about on the 17RP?
-Brian
12-05-2012, 10:21 AM
#146
Water pump should be under the bed in the front left corner - you need to unscrew the "lid" on the box they built around it to get to it. Are you sure you have no furnace? It should be located under the microwave. Can't imagine they'd build you a unit without a furnace unless you specified that? Strange. Mattresses are garbage - change them before you even consider sleeping in them. You should double check how the tie downs are anchored before you trust them to any bike.
12-05-2012, 11:31 AM
#147
Water pump seems to be a little farther back, on my 17RP it has the water heater in the front left corner followed by the fresh water tank. Sound seems like it is coming from behind the fresh tank. I will do some more investigating and post pics later.
No furnace. One downfall on the RV. I live in the South so it isn't necessary but a good nice to have. Picked the unit up off from a dealer on ebay for a good price. Thinking about installing one if possible without costing too much. If its too much of a hassle the electric heaters provide enough heat. Just no boondocking.
Thanks on the heads up on the tie-downs. I plan on putting it through the ringer before I get on the road.
Over all, its not the best quality camper, but for what I paid for it, can't beat it.
There is just not that big of selection for small toy haulers. tough finding one with a real bed!
02-16-2013, 11:18 PM
#148
Originally Posted by ken0042
I've just towed mine home from the dealer so far. Used a friend's GMC Sierra 1500 and really barely felt it behind us. Of course that was as dry as it could ever be. I'm taking it in for a service vists this weekend with my new Acadia so I will let you know how that works. The plan is to get a weight distributing hitch this summer sometime. I live right next to British Columbia; and they require one for any trailer over 3500 pounds. Apparently they are pretty strict; to the point where they will impound your trailer.
Speaking of the trailer going to the dealer; be sure to check the manufacture date of your Wolf Pup. Apparently there is an issue with the roof seals. I can't find my letter at the moment; but I seem to recall it affected trailers manufactured around the early spring of 2010. (These will still be 2011 model years.)
How is your Wolf Pup ? How does your Acadia do?
02-17-2013, 06:58 PM
#149
Welcome to the forum!
No problems towing it with the Acadia. One of my first trips I made the mistake of pulling it 200 km (120 miles) when it was full of water. I say mistake in that I noticed quite a difference in mileage with the extra 400 pounds of water. At that point I had planned on keeping my water system completely sanitary for drinking. I have since changed my tune, and just use bottled watter for drinking when camping.
I have had no complaints with my trailer performing as it was intended. We are looking at upgrading to a Grey Wolf just due to size and space issues. We bought this trailer with the intention that it would just be me, my wife, and son camping with us. Now we find almost always we bring my nephew as well, and we also have a dog. It's a little tight in there at times.
The wet bath is also a bit of a challenge. If somebody has a shower the floor remains wet unless you have another towel to dry the shower. It is also a little tight. My biggest issue with the trailer is one of storage. There really isn't anywhere to store clothes. Also the main storage being under the bed has some issues. A few times I am wanting to get something from inside there when somebody is still sleeping or having a nap.
The other thing I did was upgrade the mattress on the main bed. For $300 I had a custom foam mattress made, and it makes the difference between waking up sore and having a really nice sleep while enjoying the fresh mountain air.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
02-19-2013, 10:36 AM
#150
Thank you,
Did you have any issues with the Axle?
02-20-2013, 08:56 AM
#151
I haven't had any issues; at least not yet. I will be taking my trailer in this spring to have the bearings checked as part of regular maintenance. I will see if my mechanic finds anything wrong.
Wolf Pup T16P owner
07-01-2013, 12:43 PM
#152
I purchased a new 2012 16P Wolf Pup last year. I didn't care for the 5000 btu A/C unit so I up grated to a roof air. SOOOO much better. My quesation now is, "Does anyone know where I can purchase a cabinet door to match the others to put where the wall A/C unit was located?" Thanks for any input.
07-07-2013, 10:08 PM
#153
I purchased a 2012 Wolf Pup 16 last May. We have made several trips on it, but on our last one we noticed the excessive tire wear that others are talking about. Bottom line: what is the best fix for this axle problem? We love the wolf pup: it's just right for the 2 of us. Just want to fix this problem the first time around if possible. Thanks for any help you can give!
07-08-2013, 04:24 AM
#154
We had the axle replaced wit a 5000 lb axle and a set of 15" tires at an authorized forest river dealer for about $2700. This included removing the original axle and replacing components. This is a torsion axle with no springs. We were quoted a price of $1700 but after they got it diassembled they run into extra expenses. This was done at Country Creek RV in Mississippi. It is safe now but wish we had a tow vehicle that could have handled a doublw axle trailer. Good luck.
07-20-2013, 11:21 AM
#155
Some pics of our new 2014 17RP
[IMG]http://www.forestriverforums.com/forums/data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0aHB wgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIyMjIyMjIyMjIyMjIyMj IyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAFAAaoDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJ xFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3O Dk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIW Gh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx 8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRM iMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2N zg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goO EhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPEx cbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDyaEIsw5wjDByKiV2zhiSMjPuKtqiQwnc y+YBnr97PoKrvlcrsKFfvZHIFc17gaF/MNQcNCscYVR8kaBF4HXA70wQCYjOQWwVUA/Me4z61FFmHEiE7164NXob4xhmbII42sc5UqRj3HrSuBpW2lxza NcPNPCklv8qgNzKCMk4J5wRjoPxrJtLiFbxfPhVo85IYEYx9Py 9MGopg8JTEqOeuFbJXOOD6VNp7Q7yJ0SQKejdx7e/X86NNwO21DwzaxXGnWdpdLqNpcxI9rcxYAkOfmUDPBBPQnjPtT vCvh7VYNaSWyvrYrZrNMPMmztQgDeOwJyMdwR7Yrn1eKC0Uxzk NDKdoBLKwYDOAcY6D65HTHO3pWYLkXCSMsbAOwZtgXBwRkEEjj qPQ88U3KMXci7N3xhocuhytMhEtsxjDSSPxI/d9pzyeMfjWKFuLS+jWZRA0imRVU581GXnbwcsBke/GKt3dgRCWF0wntoD5zszAIEThkx16YwfQYxTIrbUo/BkniA3kbNJMLdbbCiSYfX73YEKPrjioSVRtiMfxFqtvcKtnBGy eVJsf7wJIPOQQMHPbt0ya19J1SCHRISFU35WaCUlsfIT+7P1+d x2ztGa43U7O8imt57xkMtwvmBd4ZtrAEFsdMhh1qSC4t4LmNmX MyjjdyjdsHBBH15pxioRsU9ifU9MlsblZllM0cp2McklT2ycY7 ccnpUF7YPA8U5feJBu5zxjAwc9+a2JNVTUpFa42BAEaMBfusHB 34+gIx6GrDbp90YTMDsrSlkCgY6cfr+JqFJrcZzdzbtckNBjMc JlkDEDgH/6/TvW74F1q7t9RtbOC7htYJHcTyOqjcp+Y7jtJJGDt9C3pWde2cc MjwLMsjzNtDqQoGR36gdT06cVFoLDS9Rll+Rp4sqhHzDPTt69M +9aKel0Jq56Hf6JpmniG7jZi8qCYbJGVXx1DJ6kHI579q5M6vq MwnlDTJmNIwY32JjK5Lj6DqO5zWzrD3WoazpCRIJgoiGCEVpAz YAI9AdwyRwACcdafodwnh/x0ravp4is33gpcABEcgrnpjG7KjrwfUVdO/Ri9TI0vRb3+3LS0s4mlvVYTbjkptxlHG0NlffHPFSau15b+IGi vpGF3Ewy+MAN1HvnnuBXqP/CS20mi31xHpUMHkQsqSRuAPmk2D7oGBk598cVx19d6c8u2VJL4 qCkBPVdylRnnkqWBz6jtngnBR6gn0MrxOt5FbQw3YkgBjMqB4x yGbk8Y5ySe/tWXcWBl0mNWSFryfmNhhnI/vE84GB168e9dfA2j/wBn2ryaXbl48wSXfzBJCAM7hnOckZIOMA4rHa4mfU4rezjTYjb GEWcfKQ3y8Z4I6+lZtaoaOZPhi+tbGW8kgkZYn2SAK37vkYLHG ACeBzz6c128HhiWWGxm00lvPdI9yLsU55BkJGeF5xz29K9K0zV NK1zR20yQuZZ4G81XH32x8xBPU55//VWV4V1rR49CbyTb2csDxs6nBIJAjLMOOvzc+hzXTyX1TBtEFvY adKps9GMt3fylI5L9UIEYTDEFsfxBSBycjbzV/VtT1K306UahbNGzzBrWOOQlxsO4Z4w33VJ68ZFOY/2Ys+qR6zFerI6PFAPkyWYI3Q8jkflXJXWuX7TXVylw/wDpZdDGh3Aqe30Gcfn0onUUNybHUeGvEdgLkSXU4F9fu3nDYAE KliNzd+NoA6jIBqH4ja5BZaEl1ZCOWZ5lheRSPlxltrEHIPynj 6jjNcNY/EG60nULVDbM8ML7pUZ2zIwQoPx24HpwMjiub1CddVheZXmfFyW SMncwDkkknuRwvvmhzTjcFfYy7mMnbk4JUEk9fmAJJOf07UlyE +zJIWV1cbVUH5hjHB498dexrSvtBu7S1XUbi3khsZpBGPPQhs4 JPBxkj/8AUSOax/MJ3LEJZLRXyBISFzgjJxgZ9v51g1qaXHaVqcWnXktybdJm8sBE uFV13BlPzDv0rf1LxLLfWy6dYRDTtLZUmkgDjYspwSycZA3bht zjntzWd4d0G38Q61FazXJtUmjLhsAAuFJC5J4zjrzzRcTXen6Z FAL6J1WWSJUU/Mm087hjG1sggZPTmtoylFeRDSbPSdf0uy8MeFdD1S2mW41GDAh ndSVljKscheigbtwJ5/E1h6Dqgm8UHUby0inX7E4ld4gqwlyADz0Gc8gH756gmsCXxJey afbut9KsiW3kFSBnORnBHIGBntyOlZwW5mkW2sY5RNdxBHiics 0oIGeB64LY7A4o505X6CtoXNQgbTZxE99Gy/aGzDay5RNjbcgDGfug9hwcGn6Zc6vHe3H2VzDLdW5j33GIw8eR xkg53HgFcfrRq/hFtG0yyvbiciadtskccWUgO0HDPu5fDA4x688VrJ4VuJPCy6lG Xks3Zfs3mMF4JHmN1AGCrAZJzvOB2qldyuJ6I6H4VRNbatJLcu 8PmsRGkYDIx6FWPVSDnAIx6Hrn1C+v7rTrne9u9xavux5K5aPC jGfXJ3fTiuJ1WIr4X0/WIxDPdNAsT3JcvJ95T8hPGc7s/wCHFZehaxeN4kgeZ3No8hTZLPhW/hyQeoUdKblFNRJTdrnZx2sWoapHcs805BaWBJfkWEE9SB1wyjG f71RaxbxaPeWUisslxd5jmlkABlIAAyR064465HpU88UFkya0i ASXUaRyPF0QkHLDtk8AcY/Os+5vRDr13aWazyvsVpZFLPhm+8Ce3AGAAB+lN6IFuWpyfE8ka tfLFYxjfJABtO5T/ez0DDGKvQ3rT2kosZoooLZCI5IR5gbGRkr2HHHPNcVeDzEuLi4 ht2aPMWyS42yA8YCYByfbnHap9F1qz02+tI3SJlCkHJBcMmQxB 4B7fp3NZKd3Yp6GZfQarqhu5S7yzDBkiXJOTkcAcduccA5HauY sIZ7PU55G8v5cxuN24YJK/iDtI9677xf4lttUFvY2M7RpId8hZNu4j7qkkjHTv0/CuH1W6jWxu4kuoRGCXlFsxPmuW4BOOQOcAcdzWFVa7jRnapqkl 4ETbHGkOEEUagZGfp0A7VSvbsXWEAQIEVVQLjGBjGfXufcmm2e FgSaRQVLfMD/EoxgZ6gda3pNKhdXnjvYGijhG53U/I7bjj2GNoyTyT+WVrhsYLaaJLEPDMFm3rtgxgnPfPp2+ua3tG8 P3F/q09ld3UdiIoiXMoAbB57/rz0FYkFpI8qysDAI2CbgSu0+2OcY5/OresC1gsbgrK7OZh5AEW0SLhcnrkY56jnjpmrgtRsi8S2Okabs tba8N7iMSpKDsC7zxkcnhQCen3hXORpIz+YfnEZAXK9R9PSnwK rs5cHHc55/M0u0bWlydwbjjn259qtspImEq/ZZVkjO0kcEbVZhzhiPmP0FE2nNcacNRjhSFFAjKhs72GATg9Oo 9ee1RxQS3N2ltARltqkqT1J/nzXV3/g+bTdGEqXcEkhuGjFqUKTY25JJ6kfKeCB+uKuCuI4mC2CzBZo3 xnBCEbh+daDQ6OjFWMm4HB/fd/wDv3W7qf/CMXclhHam6to/KC3kiRAlZfmLEj8QAB27ccwnUPCcRMavr7qnyhwIwGA74JyKTi 1sCZyd0YIwjQM25Twc/4VQWRoJGACkEY5GeDXQ3tsm8zK+JJSWIZQiqM9uuTk9vfIrCuY mjn8nzEk4BDLjuKziUO+TYQdzEjg9QPXjvUZbMgJIyO2OT70sa 5TI4Oe9bcGmT3llAIYos+bs5bBLHoCT69qbdtwMiDiVBIWKg9D WlJGAY1iVCQAXZQct04PuPaqTuBMG3PwBjJ5qaNZpwRCN21vlP cdwBRcR3nh3TdM1jSry1+wtBdwxH55JSBNtX5gB0Vsn26A4PNd CD4fuLe23Yhg+wNLKtsp5lAUqpPupIO44yPXmvPrNJLmW2j85O oxGOWU8A4HX61oaLNNJY3fm3EkSQxCIeWcCXbkHPGehH0purBb k2djTinkuZoZLOOSPyGCo32ciM5+YK3XILDHQjnFeh6prehP4U 1TShdQNdPZyDyY0wolIONuR/e5HbkYrxe8EkVxcxtMxgE7D5TwxBIz6cihjsihSO7EzyfOdqkb c5G33OM5z2/GqpyjATTMQszSqGZmAbCgnpz2q26mW4WRk8pEI2nOAcDnn1zUc kBjuPm4JYg9yDW+LQasyy7QHi8tAGbcZOOc5+mPwqZytqaGQ7x pPJIpO0OBgnnB9TWul7GsUph2IiqSq4+bPpu61TvzH5UESIqzG YrIUJJYZOP5AZ46+1V025MRO5VGc92Hpj8f8A9VZPVAype3L3J WSUgyBiOBnbk85P1pNMtxNeLlx8rgnn3qV7FZZsw7/LcgAEZOf096uLpQ06dGaRZFdiNgU4IzgHI/PFVdJCOys71tMmi3XUU8kcnmFl2nJH97HHscVs6TrUja5N4hOn wTW9qjIrQSIhXbuBYoPVXwcdMj73NYui6Q+sSW0MV5bRqJApLM Q7KWC4HHJB5PPQ5rKbSzpfjC8txfwiOOVg06ksmCD2HXrjFaUL wi29iX5HQalcreSNqZuiRqI+0S2zfNtIYYC+mCD74HoaxhAssu 6COQwj5pAPlAJPTPPp/wDqzTby4SR4gspLpuDlRxj8euefTpUEDT7TcnYsI+QPjk54xn2 rKpK8rgjZhu7T5y0EkYaEiQsAfMbYdpJ7kNt5PoMVs+HNVW3tt QaCRY5pPvyMwAUYYg+p+gHUjNcY08p3x7VXD7cn5dxx2/On2rN87+Z8wTZ97kYGB+lKMnuwOiN+H0uaWC5UXDhUhQYJk/eLkEnp6/Trxms5Ybw3UdlDbLJfNIzTx2YMsqDYMI4HygZBPXv+FMgeO6iE DMoSMgkuMZ3Ht+RP4Vt67LqWmy+dqULRsgSGFIzsUDhRsx9Oor WMo8uoMpJY3MEnlXoeGZ3GEkUhl7jIHsB+lFze60ItiyuIZwyL vbrt28DjjGAR046ViTyx3F4Nzbo3+RkkONpA6EZ9eM1pRBFsRP vjQiJ1IfHOPlDDHPBz0wee9YJ2YjntfumhjtYzC6OkY84yKcuc kk8nkdMe1ZtneQQAFrfc5kDDHAHXI45xzjrzSaqq/wBoYR1K7RtGegwOtXDPpUFnbpGGkukf5i6fu2Ung+vGOc+ox0J reK7FFzVPFV1qelppt1HH5ke1EkkOdqfLgc9OUBz1wSOnXnIz5 K7m8ti+4KVkU8jI5GcjnpkCtrUdLuXuGvYIRJaxCI5kRIwwbGB tB+Y+oHOOcendePtX03UtA0rU9IuAL23JjKxFg0SfxHPHGVHUc g+nXblck2wWmhy2j22loLyO6uJJdMji+0RyiJFkLqBlBgkjmQZ I7J2zkY5tLqWS6Ybh9lj3XCzfL5a7gmRkZ2jcOvTn0GYZZ5rIC eSMidcOjSHpn59w9z0/WumOjar4v1bT9QhhuFS6DrcXf2UsgZeCxyQDnjsvXoT1E01YNb nH/ZXRwFljcMuVZW7cc+o69+teofD/AMP2txrE1zd3ts1zDaDyImQkoCi/vVJA+6WAzjv16VwV34R8TWjZm0XUBtUIWW3kZQMDGCB0FbvhzT tbtNQshZ2EhnYNLGZLY84x83PBIw2McjH0qIWUgkmkelX0CQ/D2SG4RbOVZV+zvJ/E6KMOpHQtsJB96w7nxPbvprW8GotPHJbm3WGRcrIFj2l8BvlJw zD264611lpoOma9ZRy6jYwyhneVpJFyUK5UAEkk4yTkntXP+Kd B8PWzq0GqwWB3mXzVk8yRG5yVHRc/KM+grolK0WRbUb4F1y11GwutOkglnkdy370ZQKVbORyBwPx3dO K1NVsbO6ae0TChIdwtrZkjLOSCD2HGCTXI6f420bw9os9guoPI 0k7SZtixwD2GOh4Bz6k1yl74302KaWS0tbmaSU5ZrqfA9gAuen vUNt2shJHqmkSQ6d4S1DzDIzDbs3/IzvkjaP8AZ3g/mfSsOXx6NKnt5754oNuIyN4+cLkdsk43HketeaN4+1Z3ItAsKn G9YU5cehY8kVlX82pa1d/aHt0jOMDAJ/nVa2QKJ6tqHxT8NCS6mit7i7lldHTZDsRSBgkliCc/SqNr4oj1tZJEtDNBExZYmHzRludxxxn0NecReH7qbmWTHtnAro vBTt4X8Zae80oaGZwr49On8mJ/CiUFJWQ9jsb9m1VrSzRBFbyh3aOIZdgAMAnseD/LvXJT6HLJdxWlkktzNI3IRM4xj9eenuPUCve7i00nUCS8cRcd/uN+Ywagi02TTo1TTb14I1JKxOokT1OM8jqehrKNHuw5jySw8Ha y7rM+lSgxMVwiZLP6MD069egxziulj8A22o2VvdzTSRrHuWSJe qurMCrZPygALzyetdVq134laECza2SUdZIs/MPTa3Q/Q1534oi8SXV6zypNLEDmM7grD3I4556jPFP2cIahdso+JbnfMH sftCobSOIeZx+6ACkH15XPHGMelcgFMswBJJLBcAZzW/Y2DTXsK3CSpISN7O5+UFuSFPJxzz09u9dN4btCPFKf8I+YIrtZ 5f3k03mIYcEAbR34LZH94VnGPPK2yHsJ/wAIFJbWWlWljG1xqepxNLJKx2RW8eAeRg88nk/QVW1LwivhvxFb6eJUu5HiS4yyYBJdhgjnI+XP5+lezaNaNaw3D vK0sk87SOzZzuwFI/NeMcYxXCeMDJceMvtdjcRQmytVjkuJWZVjfccAEAkt868DucVr KnHoUnpc8z11bxtckDyC28mIKisAm0DJAwBx1z071gy3ssVy7e YWVgAxY8jFd744jAmutQmjFtNPcYETZ3phEJOffdwPXNed6nO1 xcqQWKhRgNgED3/z3rB817MLIllu3ntUGF3o5IZUG8jjjPXAx09zVUS5GcZ/4CKbI5ZEK8YXHFQ5m/vNSKsb25Yrjzb2SVf3TYAADBiOAcHoawrc+RJ5sZ3gjEqgYO09 ePSroje883ypUZ2ycEctjnj8v1qCKNZbtQ0LndwQxOfTIwKlNA TWIX7SyohO84UnA2jPXnjp2rZkQSW7yvehYFGVUqNxHJx16+x9 e4p9jNCgBkgRZdvyOkYDAHoAex7jNPNqXuHc2xto2x8hI6cc8H gAcD+tRKWomctIkYJeByePmVxgg/571Jb3BinQNGPLzkgH9PWtK6tRDeK8ri53gl3+8ef5VG6xLcxo m9wq8HYAce4H86u+gHQSalp9nBFNYWxVlwh3EjcNvLE9znpn+t ZO5EmIEmI3JOcYxu5xj15xUraU1vsA3SS+WOUzgFsdx7+31ovb e3WQzXBSKMdIoz/XtUwgnogK9u7wTiQb1LMR5fTB+vr1rSN5p/2hJrmFRN5gdpYwxbdnJ3EccgfrWDNqs8k4nwSVIILnlsfqaxJb rUFE9sHcQ3Lh2RBw5zxW3sb7iR0d+6ukt5BBKVW5EeG5JbbnjH UcNycZxUR1sIsq/YJlMmAwYdPlGccZHc0yyk/sG2Qm4eMzY86CX+NSR90eo4yK3o1tbmISLHDIjDIJRTVOEUNLo zlJtTWYKjrJsD7jn6GpU1K1+0mRo5CAABgDsP8A9XNdMbC0YYN rDj/cFJ/Zdl/z7IOMcEjj060rRHYxoNds0tpFKSh3ZsgKMbSTxnORjim/21blh/rAoPAxnArcOl2jYzGxx/00b/GnR6ZbxypIhkVkOV+fcPyOQalRiHKzOg1/TY4gHuLgkg78oMD0xz/n3pja5YOrnzGeQ8hgvftnNdFYvcadP51vdPvznLxxvjnP8Sn0q nd6XDfzie6czSr0LIvA9MADj2p8qFyszrLVrRMFnYP/ABHYWHrVuLxDbQeYGkDu4OJXQ5jJ7qPXgcnjk9qfJbyRqVS528 Y/1S1Ve2znc0bZ65hHpikoJa2FZkP9oWDyea1wu9m3EEHj9MVoLq +ltEIRKFXI3MXPIB9O1UlsoAzFkhIbkgx/y5rotS8QtqWk2+nHTdJhihxgxWeCcDA6k4/rTVJNbg0yl/benJKJIJ40KOpEqErtP+9171Yu/ENjfFEku7eSPYiDdIBgDsc1iRWNrEzFILdd+d4MZYN+bHH4Ypz afZuoBit0x/ch/nzUcg1FmjJqlpct9nhntLePcU3sFbcg5GSOeDx9Mdajtb4RQZk lR3T+FJ1y/GM8n8ce9UF0uzAwViPuYc/+zUz+yNNGd3OfRQKr2cWg5SLUcX2py3EHmMDGCS+PXkgDoORx9 TVBDKJTH5ZcNkYKk8+o9+K1Liw0doo1MKx7BgtHhS3uT3NZ8ie HoM7izEdvNyf0quVW3GTWsgx9lupLmO2LbmijBwzAEDK5APJ69 smrlktxB5kdnO4nmxDNCgdnmQncQMDkAouQDk7sdM1gz3uiAYh sJHPr5jD+tUJZ4ZOIbQRe5kLVor9yWez+CxJZRS32qae1r/o4iV3xa/KpGFG4jcWLMxyedvrW1d+L/DFuh36pHG/92L9+w/BD/XFfPKrIx/8ArVZit5pTtBb8zVtIWp7JqPxX0PT7UHT7C4vJwcb7jbEp98Am uS1H4qa9qimK0xBF12QAnH41zENlb+U0U0EkkrDOXkwB7gY61P YRXOnPstsAyei5NGi2CwS3Ovao/wC+mmbP95z/ACFNj8O3chLTPszycDGa3VhlmUG7u5PfzJQo/TmnD+yrfBkuY2b/AKZoZD+bYqr9BaGOuhWUJ/fzqT6Fs1chs7NB+5tnk9wmB+Zq2+rWaDENvPIfVsKP0qI6tcvx Dbxp7t8xouFyVEkGBHBHH9T/AIVYW1uXGS7KP9hAP1NZ7XF5Iv7+88tfYhQKu2uh3l/H5kVrfXSEAh0jcqR67umPxpAONqn/AC0Yt/vOT+lZmseTHDHLEV3QuGwMdO/6VuweHLyKQf6FFAT/ABTSqPz27jWh/wAI4LiN0u9SgQEYKwRGQ4/Ej+VNSS1FY9O8OaqmpeG7C6aB3JhVWdDkkr8pJ/KrxubPPzlo/wDfXH615T4D8Y/8IrpNzp94pZI70Q89Fb5gSc9BhV/OvRdM8TQ6u8qxQROUUN8rDOPw/D86JNKVilCXLzW0NT91IP3U24egIb+dRtDg/wBRxTJbi2YES20yf8B3CqoGmucRzrG3oGKH8s0WJJJrSKU/vYkf3ZefzrP/ALEtIrtLy3QwXEZyrIA2COnBrQFvKozFdMw9GAYfn1ppa5jOGR HHqpxSSs7gUx5y3ZlvnF7GF2iEnyR+IUYYdODxWPrZuv7Ce30m 1ksZVfekVvGjRtliSC/XocYxjj3GOga6UH95FInvtyPzFNJt5uVZSf1qnJ2sJHg+vxayt 05v45OzZAJUDsM47VueHJ9HtNAa5vdHl1K9U4hhEI8snJIZz94 4OfYbRXrJgHQE49M1UudKsrlSLi2icHrlf8KySs7sq54hc3ou7 y4vFhWAPISsauWEeRnqeT3rMLy54RMdsivcR4T0yNWW0At0chn jUZRseo444GR3xzXOt8KrZnY/2nMMnP3RUOF2aKR54Ibe3txLFcRuTzj5uG/x9qb55v8AUFSGFVgWPG0AKNo7k/XkmqVo8RZZp8mNXCuoIBKn0B/Gr1wkMV2k1rhuAY8NhTwOc9c57VzvR2EbEglg8xQSBGQxDp1yM 8d+wFakQkgSG6XLTGQouE2kE54HPbnnmsKPVbSKBmkEiu4+ZI3 wCfXoAOnHHTrUMV/cspKfu0Jz8zED8qlUpSFc6G91V7tBDetNISpV1cAhVbBB5HHf+ maqyatD5DW8UIkcnLeUMfXp2PPWuaWZGZnkJcliTvPHp0qU3DT chi3auhUF9rURfuL2aZi09wf92M/1P+FY15d7QVQKinrjqfx6mpXjeT5S+31CjJ/PpUUkCIP3cQX3PJrZK2wWKunPu1CEMNylwDmuxXaowAB9BXL2t s7XUTYPysG/Wui3VnULiPuIY7qB4ZBlXBHTp71ym278O36sWLWzHqOjD+hrp9 1JIqyxtHIMq4wQe4qYysNq5Na3kV3AssLBlP6VYDVxVxaXGh3i 3NuWa3zz9PQ10dlqEN7CJY2+oJ5FOUdLoEzUDU4N71TM0a9ZFH 40w39qv3rmIf8AAxUDNENxT1w1ZI1ewBx9pQ/Q5pJdcs4o96SFj6AU0JtFq8by881mSXGO9UdR15ZCqpE+XwRnj isu8nvIlyUUZ9G3YrSwrm6brHeo2vQP4q5Z57iT70hA9uKjCEn LMSfeiwHSy6pHH1kX86rvryqPkDMfyFc9PlFGDipYRmNSeuKLA aMms3MmQgC/rVV7m6m+/M+PQHFAFOA9KAsRCIk5PX3p6xCpkhlf7qMfoKsx6dcv/Bj6mi4WKqxqO1SAAVoRaO/8cij6DNWo9JhH3nZv0ouOxkrjsK0rJnijLBF5/iatvR9CivtQgtIYA8kzrGu7nknGfw6/hXt19p48MeG55rZ7e0KRiONbW2SMsx4AJ5J559aBWPniJria6Y 25dpOmIQS36c1fi8P6xdHP2K7Pq0w8sfm2K9XXTodP0iKO6uv3 mMuplP3jyeAay9+nI/DByDztXJp3FocfZ+DLqQ/6TcWNsPV5Sx/ID+taUfg+zhbEmoXE59Le3C/qSf5V3FpdW8NtuisLmQkdWwq/0qD7bcyyMYrKCPP947j/AFp3YjnDomkWFrLcz2UrwwoXd7m4OAB7KQP0rye+vJNQvpp0WO FHYlYYRwi9h+Vdl8RvEN3dXkOmR3JVLUkzeUCqFzjA46lefoWN Zng7wjP4lu2uLqV/sMDDezZ/eH+6pP059PxpruxG18MPA7eINSbUb5ZfsVmylA6lVlk5wATxhS AT+Ar2LUNGtYosyzAk95Jmf+tUtM0vTbeFUlaBUQAKrNkADjGO lT3VzoluuxJ4AfSJVH8qG7gZajSoJCDPGPZFFatjdWWT5Vpc3B 7bYyagsr6xMpCQXE2OgWMmumtLyVlAg0iYe8jKv9SaQHnwtoLT 4oEyWrW9trFuoaObGC4ypPfqQn5mu4ttEGm7zpyR2+/BfyY0G7HTOBz1P51xvxYivxbaNrL26wJY3PlsUk3ECTAyeBjBV fzrqLO50zUbG3uTLDG8sauVOAQSORn65rRLRMTfQtyPqCZ3LDJ/vqV/xqq93ID+908n3icH9DipfsSnm3u2Uf7ExIpjwalHzHdll9JIw3 6imIpzT6ZKc3ETRn1lix+tNWG2kH+jXpX/AHJP6GoL7WL6wuoYJ7BZ1m4SSMhQW/u4Pfp+dVk8R2UrrHcWN5C7NsAeE4zxx6dxQBomK+j+5Osg/wBtP6io2nuVH7y2Vv8Arm3+OKzX1Pw7KsjrdRBkBZlU4bAGTwD VuKBJIw9lqD7DyMSbh+tIQjTWhJ82N4T6lSv6inIQx/cXm72JDfz5oZNSj6PHMB/eTH6ionuJv+W1kG9TG39DSGTO9ynVUcexxUXnt/z6n8xUDNZnkpJC3upH6im77X/n/H/fylYDxzTku9RVY3lQqT8+/C7Mcg5796y9Qj8m/niWSNlSQrui+62D1FJJC9syyITg8gkYIp3lGSQscLk1z0173kW yFBj7q1fSIlRuf8FpJ7X7L8zxvIQM7Uxmp7PVBev5VqIYPlJ3y EEjA6HPf6CtuZJXEQ6dbvK2ETJz6ZNbA0vbzNIq59Tkn8BSWzQ CCWES26oshRnlj8wx/MdpBBwxOAc9Mc4zWVqmFEchRnb5hz67gcE+n3uh9Kn2mugGtYS adcGLyBJKrkAErtGM4zzzV+70idJVRxCTI22PbwpPGOcnOcnnt XHWUhjsbWMhzxyGbAI3E4r0axvbyCIPcshW4O5UKuzIvzEYbHQ DBPXArKrVlFaDeiMC+01NOh2yWUsfmZ2MQ5OR0zyMZyD+HvWHN EIJHyTIpXKnzGK88jv6djzXcu1ve3ZuILWCTy3JWQufMLFQThR 36e3bFWLz9xbfvbZLeJIcvCqKSq/KcFThT8oPHvXN7drcXMeVO0quCWYc9GYkVPGAXJKhyUOATx096 6rVDp2qfwvbgIu2QFWG0MAcRjGDj39OmawHtha3oSPdgN8m4YJ HbI7VvGfMik7lALbvMRGH4PzLJg/iMcYqO8szYPFeW33GPzJ29x9K2muJtZtc+YkYtVJaN2CgjvtHc 4AqGxbOnyqwztUt9MD+VXGdkNbGa3k3kPnW6AYHzR91/wDrUyAgygFc47evtRcWUivJdW2AYmBIH55AqzpaLqd4iwFI7kn JiY4DH/Z9z6e9XLVXQiWOzlkuI1iHO7kHjGanu0mJCz43FhuyMbTnpW3b pLp94zICkjAoGKg7Se/PerOmRWmo+KtMs5LKILJdKk5LHZJ8w6jI9KwjN8yQdTnnFpbQS GdmKgAKEHU9ayp7iC5VRYQks52gNycjk8V7P4o0rRbXwjcCNbE Pe3rLGsECBljUkAg8sB8g7/xd815UYILDV3WMAJHa7vp83P8AKuoLGCdKv5D84Cj3OKiudLmt IDOZAwUjIGeK0ZvEAYny4c/U0k90bzRJ5GQKwIBA+opXHoZd9B5cML7s71zxWzYWEDWkLtkkq D1qCbTpbuxtfLwCq8g1t2kf2e3SPYrlVAySaTeg7ESW0C9Ihn6 VMqgdFA/CpFQu3GBShcHGam4wVWNSBfelRVOcsB9akHlg+v0pANAFSKuel G4EYVTUkKkt0H4mmgO0+Hlnaya5JJeSrHFFASGaXZhiQAM5Hbd XXeJZ9BM9hbRNE+yQ3EjR/vDhQQFzz1LfpWd8P4XttPmmQrvmbOBavKcDgdCB6/nUcrzahrWp6i7XUiRsLSMxokY+X7w5BI5A6etWtESVbrUbRiFi t52A7bNoqrDdyPOBHZD2DtUz27yMcwyn/rpct/JcCnWWml7ji1tyf9tDL/6FSCxduL3U/swXbbwp6hSf1wK4Hx14kvbGzTT4L4Ga5U+Z5ZwUT8P72T+ANav izxLc2bjRtCmE2ryNsMdnbqDEMc/d/i9u3JOOKr+Evh29tOdQ19o3uyd6RNNny26ksf4m/PHv2pd2Scf4P8JjWJDeXyXH2OMjYiQu3nH2IHQY5+uK9Wg0xEi VY9NuCigBd0aoAP8AgbD+Va6adYmTEtxEfUtIWq8lvokZC+fb5/2UBNF7gZ2nwvEpIt7SEf8ATW5C/wDoKmi5ny+Dd2C/9cw0v/xNdJFPplvDiMTSZ/uRn+lZ899Dv/d2Fw/+8Cv88UARaTuZiRdXbH/p3sFH6sGrdEM8ij93qsv+/OsX/oJH8qTTb64KbYtLK+7Sgf41pebqDDi1t0/3pyf5LTQkcx4j8PS6t4f1C1OmrukgfY0148jBgMqQDnnIFc58L tSN14altpIJJWtZMEr1XORj81J/GvSsak38Von/AAFm/wAK81gjudB+KmrwSbzDqkaTxiEmMO5Xkjn+8rfnVxe6CS6nWTS 2LHbPFIn/AF0iP88VVNrpM3+qmiU/7LlD+hpZbt43Jc6hH7NEko/ln9aQajGet1APaWFoz/M/ypkmZ4g0WS40W4FteT5RfMQCTdyvPeubuZtRuxdxQ3KuZZ7YRN JHnD4wzZUn0/Gu0f7NcsN0VjN7iUE/qtZMHhewtZbSSKxuENt5hBiYNksc54bPH0oC5iXCalYWN2oghe SzuRJmNyuVcLnj06flUUqxPoEy3GmuWtpTtbyxJ+6IViM/Rq6HUdDsr+QPPLfxuowD+8Xj34xVKXQxiNbfW2iRFCeWxUh8H+ LPJPNCYzGuhpA0uK7tlubABgrIXeMhCc7gAcd+46U/S79pp2gstXndW3rE7Th9xAGOGXP5nvW3ZWeoros1lcw206kuiM jfwZ4/xqiI7y40q0abT2jvrZiVG4EHGRg9xkUmBFba1q55ae3niC738y HDBc4xlSQSO/A61uLJduiutvAVYZByeR+VcvPZQRKl7f2Hlv8AayzRiPeCHwP0 PSugW10tVAWYAAYAweKQmjw4ytKWicgnHyM3BBz+dQwRMbyMgO 4J5VRz16VK6kzosYEhOfm6Z96mlSJo/mZgVbbuUZB965djQddXL3s5Kq+HxtEj7iOOuT/LpWdcWUkrq8asHPIcD/PpW/ZWsltaXLMjK5GA2zcyBRktwDx+I6dasQ2lpdzR3COMx4EgiG1F J4HzZBz1OeelQpKOwHO2l0Ldil3G+4v80Z6HH9a7GX5LMSho5I jGhaPc24djkN1+nTpxWTqGmx3qbxHiEkAFn3MM85Pp9Kyhql5a LDZXsjyWscqkSjrtz0J6kYz79aprms0ISBzPI8LSGTY7pHjofm 6/jitzVJR9qlMF0rTGQKDnaNvXGeMjI6981jWYtrmwAYYkhnOGT7 xVm/8ArZrpLmOxeG0dZoE3kBzK+xwMn8OPz6dqmpZMckXLO/s7SyED3CJKWGZGgLAKeCAT06gelZmrpFDC7QakLmRlMaGJuExg kZJyRhiM455+tZbMIXJWUuGJG9MruHTPrg8VsWLWCKk6yziW2k MkYlwAoyeOuc9D7YNYOKWpFu5gWVoXDSM5ADKHXfg4J5wOh49a 053RryNI4vKRdqqrYBGBgZA47Z981XuL+GacSNkShMOAAVkbPJ 6jAPXuSasNfJc3sDbFjhXChAWbauevPfvWqbbuWipLbyWEhaxu TNhDuZQQFLAgj2NM0e6+yzmSfcckFiuC2M84zxnnvxVnVWaeWO EXfnp5RKb3YgEZwoz0PHA9aoxW8kSKzyokvmCNozwwB9R2qkCR a2Ga4upLfeQXLK+7DEHoPc5x09KS60a3vNN+1W0nl38PHlBeXK 5JOBznj0+uKu2ItwzpcbmC/KwC4ZT2xUshFkqPgbkfBUtneQeG2jpxjn396lylHYJIpaHrovp ks9Rd/PA2QyZyS3QA/wAq2rPU10/xPF5bxyFJoyobJPmBhjH4kfWjV7Ow8R6VcXTWptdQgjM3nJj58 LwhBIz7HkjjGa5vwpewQ+KtKGphQsV3Exd22rwwPzH04qqVqku daNdATseqePp7iF9K01X3R2trwEgZQCcDPPX7hrzHWpHkuZDIz sRZuPm7fMK7zxbdvf8Aia9kEUW1GESCNty4UAcHAzyCa4bWwxu ZNyop+xycL/vLXUwRyFuMx/jV0D/iSXfH8a/zFUrYfu/xrQUf8SO8/wCui/zFNgjXsRm0hOcYQc4rSYylcNckj0D1gzTyRabapC4WWRQAx4wA MmobS0vb6Tab4oNrHJOASATj8en41nYbZ0Cp7Ek+xowAa5T7LI 7gPcyEZx1/+vU9zpK2zR72k+Zdwyeo9RxRyhc6dZEj+ZtmP9o0f2hbqcedAC fcVzdtYQuCWJOCBy56V0L+GtOOnpcCYRs3ZwxXv3zT5QuXESR+ QCfoKv2VrLLcRRKoLyOFAJ7k1heHQpsiryACJ2ReM554rsPDdu LjVQENyxVC37iNi3Ydh70rDPSL271HRvCLCFLaD5FghEe4vuPy jHA57/hWVJDqVlp8Fks4jjiQLhIsc9Tznnkmm6nbp5llatBqbsN07CUk cKMD77gdWrDv7KGdPLa2nQMfmxdohI9MhycfSqbES6tfRaNYi4 1LUpI0Y7UUEbpG9****1zbadqvi9xHdGTR9GOGPnv+/n9tv8I+vHTrWzY6fYacWW0sNPt933nMwLN9W2lj+Jq+LjYeJbJ fYSM3/sopXAXTtD8PaLa+Ta+Qv95ydzufViev8qspLpiNw6n/AHUBqq943QXVv/wGBmP/AKEKIrhywzcv/wBs7P8AxY07iOh0+8slPyRXDn/ZiP8AhXR2U6HmPTbtj6lQP5kVzelGRjkS6q3/AFzgiUfqn9a6OGOd1BMWrNx/FNGv8iKaEXZrq52/Lprkf7boP5E1h315fBvksYEOe75/pWg9pKwObK9b/f1Bh/Jqx7yxZmwdMjP/AF1vJH/nmgGaGn3eqyfKBbKPxP8AQVsImokfPPbA+0LH/wBmFcta6ed3/IJ0of7y7v5rWzbadOq5S10yP/dg/wDrCmmCNIQ3JPzXeB/sRAfzzXnHxUS4sbrw7q0dyXS2uXiYkrlWfYVOABxmP9a9EjgvU GBJaJ7JAf8A4oVheN9EvNb8G6nZ+bHI5i3xosOCWQhhg5PPy1a aTuFrobDeX15Zw3KRW0iTRq6/MV4Iz6Gm/artDh9OB90lB/niuf8AhvJeat4QiljvJU8qRoti7SBgAnqPUmumms9VQ8XuR/t24P8AIijZ2I6EDXn/AD0sblfogYfoagu00fUrVrG/tcxykf6yJ0+YdMkds1ZKaqvWW2ce8ZX+ppnnakmCbe2fH+2R/wCy0AedX2maOkjW0Goo0YbOyzvTIoI45QsGBFVHsUZ4xH4gmjZ PuCS5eNl+m7dj8xXQ+IYbZr65lu4fIn8uGUbZS2/dIyMADjoAG6/hVfT5NKGsnRRZzXEMsQJuVAyJACSVOcgcfj6Vd2SWzqWql57KG 8WZ3IkgeTbKrAtkrzkdMqPcU+XUbi2K/a9IaDAw0ixK4J9fl2kfTFY+qXdvo2tBZ7FpkzGI/PtgdvyDac4O3vnHoarXGl6ZBHeRNMYSCCI0kbEbYDHjIyOcZ9q myA7KDzLm3M1tHHPEvDPDPIhQ+hDdDyPzFNxc/wDPvcf+BA/wrF8KeNWFxFbTeIU2Mdq/aR5g9OWLAiurbT7VnJXUrkqTkFbhMH6c1LVhp3PnmGSWaaRg6o XG04+UHnNTPm82wC3wUQFiq9ePvEj61VmuXuWTIAK8AheTW1Zs k6QxiDERyrYUkfWvPlNxVzUz90Uu+GZ3k6hmLEfT/wDVWwEtROI5zE8wIWMRsqMSigoGJGQuB1/DPWtR7dLj5DIFVdowjMGwOBk9TUMSn7UJQsAJVlaVYsnrwSvRj nk/TvWarJgZaws05KQByvzXGz5wQflCrnrk+/vWUtyiXc32hDgKwKyRk84OO4wPfn6Gt63nfy9qeR+7kEytGRIW AXGzI4I5+vJ+lcxfPIrfNyXy2Tgnr61002IijsruxtnltQJ4mG JotuSuO/8AOrj3Qn0xGgjzGp/eMRj5vTP07Vct7qDTXjuGtFuN0uSGlO1cf7IOc8jg4BGORzirr NpZ3F9EdKY+b5QLFSH3PjJB2gAn1OPr3ofvbj8ixp0k1yXRbVm hIVJXiQsyLnk57cZ/Or2rxKtoDG0wtwN0Um1WwzH7pPBHQ/THSm+H77Sr21jt2aKwuIEZppN4DvySNhIIOOOvYD61rMkIjsop I2u1uJFVX80ELnI6KcZAGeR69Mc4TfLKzJv0OOnEUkyfZ1KIQM iRt238fz7Um5IyuI1EnRivQjHWu0uNFg02OMyaazojBnuX64U5 JIBOBg44Xt3Ncm1iWNzGk0O5V80MTywA5A/w9quErlJoh/dFGdhzzj2quscjOGQ5YkqMDkUrSCMLFhskZJHStvRtYaNGW4lc x26gwRlQybjnJIPfBIHpVSlYbZNpyiWAvK7rPujUhfl+UfeJ+o/Oty5uYdS0eS3YoGiLGE57qDjB7/Ss+2gtnsLm7hklZxE6tmNsRBgeFIPuTzwP1qvDP5cRg+8YCkm4 Ejd68+oyD+BrJvmBO5W0+7uLe7NwUjLjLsLhdyyDGTweDTNShb XTbmWaNWZhErbcKvQcY7Zz+VRahBAyzyrIgmQKX2A7TubHX1ye eKfBatc2jXSGUxxSxIAZNxwGGWyeeT/P2rSEVF8yEjNsby50i7+x3oZY+24fd9Pwq7qRDyu6nKmzkIPry tampW1pc2MkcyOvGQ5OdtcgfO0+SSFzmKVGRWI7H0/HFde4ija/6v8AGtFf+QDen/pov8xVGNTFGFYYIzz61fX/AJF2+YdDIvP4rTYCX8jR2+nPgZCdPwqSJt8SBEG/2HWotVUrYaa2OChA/If402FsRE5b2waljJUTddpG2Vy4DHB45rS12Dypox5iNtjVRtA UkepA71lxkLIpOTz6/wD1qknHzqxZWLLk4xx9eKALemPcIJzAwB8shicZx+VOtpPKZ7q W3V1bIVj6+oPqKr2cTT+ZGg3fLk8gdPc1O6wyxm3t3BiiXzJZG 2/M3ovfGTj9aauJmt4aET6e7yOoZpnOCpPf2FeleDodOjEs9zDJM TwAlsXAA/CvIdFfW/II0+KBYPMP7yXAySemSa7iC68eW2nFR4h0m3iCbRGkMbNjp18v +tK2upR1x1G0n1a8vFtJvLGIYVWLoo65x0yeaYb+LfkWdwR/ugVgWU/iazt0R9c0iVAPutahT/30pH8qvxahelcyX1oHP3ijAj+lJ2GaiX64J/s+dvq4/wAaa9+d3GnEfV6r/wBoXQUZ1S1/Nf8AGoPt1w7EnU7fP+8v+NIC419Mx+WwjH1ep7W6u3kGyyt8/wC03/1qzGvZuh1SH8HX/GtHS7mR5T/xPIounPmJ/U00SdjpcurmP5LWyUf7zf8AxNayHVj95bIfQuf6Vg28+1Bv8VI P+20P+FTfbbccHxQh/wC3iEf0q0BsMuqkcS2i/wDbNj/WqlxHrOMi7hH+7bk/+zVnte2hH/IyqT7XcX+FMeaycc+Ic/8Ab2lDESEauG5vz+EH/wBlU0Kao7YOoTfhCP65rNdbEc/28D/29pVdJNOEvOtr1/5+wP5GkFjr4rS6CjfqM5PpsjH/ALLUhtJT1vrn8Ng/ktZdncaWIx/xOd5/6/M/1q6t1p2P+Qgp/wC3k/41aGjzrSdOj0n4k6zpF2T5V85vIHZiM7xuzxjuJB9RXZSaHZkf LMR/uzuP61wvxOSGw1/QvEFldK7bvskg8zecg70PXpndXZR3r6haw3Men2pjmjWRR9pGc EZwcp1pvuQ9wOjxqMLdTr9Lhv6moG0uZT8moXQ/7ag/zFElqHPz6TAfpNGf5gVXfToj/wAwYf8AAZIf/ihSuBxXjbSdYOpxSxXNw0Itwu8qCAQ7kjp6EVyZttcjIK3Bb3M Yr1WfSkWRZY9Kuo3XkNG0QI/ESVLFc3UClW0+5lB/5626OfzDZp3FZHARPqF2tq94w2B1hlcIc8gnOfbH/j1F9qeqwJZWk9kks9mzI0jA7ZF3HAx3+Xafoa6HxFokGuzw3H2 a+sLhFKs8NpIwkHbKg4GOenrWTNpOuLcwNFe3CeTCIUcxTD5AS QCpQ56+9FxWOfl1K6gvZZodLRE3lkXP3PTtipZtVt7meSeXR2E kjF2xMcZJya9Mhu9IitYormC7uZgo3yyQlMnv/CP5CpPt3h3/AJ8ZP+/dHMOyPn+1u1jnxtDDvXQLcfJu2/u2Iwfft+fpXNwxRLYMGcGUvgKg+bHuecDmrdppdxeW0cyCRwSc BQSxAODgDk9q82cFJmlzblu0MDqV3EkJxkn8Py6UzTr6KY4uVc QcsXDAqOwz6Drz3qxcq8NogRTEUQMQq+g5xjvk+3SuYmeYuyRs j5xuKIPlP4DiphSjYDo0vYXVpoUeUInzs0LOm7oAQFAB68+1c7 rrbpbaTfCXO/cEYsQc9CT/AJ5Irc0ue3twLi8j228RKt5kvBbn7hIHI9Oa5rVLsXUduZAryh SC6nDY6DdxycDr/WtaatII7iSL5tyqLKwIdV+bvz1B7Vqarm0vI544XW1OBJEpVRJ gnGduQcjrwQKyknWFIJYEKyoFJdWI2kDAPFF3IUhRGXLq3zfKA do6dCfU/wD16pq7Eyyk41e5QXUzrsRlhdpCCHP3fm+uCfpWza+INV02Q6b q0+5NpEU0ib1c4wAT2HuM9efWuetELRujSFVQbyv0/wA4q3bX8qaVdgzx+UWCm3fktu6kcZx8oB5pSimrMTRvLdQm58m SG2ubhYnPmR8oSMgLtPBzwT075qiml29yJJ4roF2YOLcKAwByW HHA9vauaVZLV45VDNADuK8/LzXRW2tWgtGtHz5M5G5wxYc4BO09MDPT6VEoOOqFsZ+q2FzYgz f2fNbxqArPIo+Zj09R69KrwpvUZI+boRz2qS5v/wDX28ZE8bZCvIMkA45HoeAPwqrGJHtXxnbGvUdhWiTa1KWppQ6 hPDB5Kyvs543HB4x06dKvW+nk6Z9ouC8RcAw74ztm5xgHPuOme M+lc9HPhADIevINaUeqLZQSRI25ZUZMb8ZVgVYcZ9TWcotPQNi vdz+ZIIoFZY1TawxycZ6/jTor2a20790WVVw0gXPIDZwe1Ms98sMshXqCoFX5dOWWwQzNIi hhhRwpXcATn8a2tayKexrwajZ3VmbmOWQgLlhjlTjp1rn4RBcX 2+6fJu0kQlj1IdQoH5VWubG70W5Fzby5QHhx2HoRUdpK2oaxD5 kqRqjmVVJ7lgWA+pya2sIkntJdGvFdkEtuTxuGR+PvV7U7iG48 OztBgLhflAxj5hW3PGksbJIoZWGCD3rlNU0prEtJHlrZuGA/h+tPcCtqSyi1sDJKjps+TC4IGB155qSAjyxxx9OtJqk8c9hYCN smMMrDHTpj86jgmHkbTnikwJwB5gwKkkXGMgdPaqgmCsDzT2mL jLZx2FLqBYgVZH2kjaOTjGasToixcFQAfu4AqlDLhmwO3f6/WrDMpAJQZ9Tik73A6zwSgbTl3XJiHmPj5iP4q7yOGKcwxnUz97 ccznoPxri/BUbp4dEwg3q0rjdn/aNdlpVzseSVrAuAuwfN+NPqMuTW8eCBqbE+n2g/40lvZK7gfbyPfz6hn1CLLO2nyYHZTk/kKqjUrqQlbTSBAf8AnrdOTj/gCZJ/EigDYmskVeL9z/23NRpp4Cb2viiD+Jp8D865+fS5dRbbqWtamYj1hsbdbZfzG5iP 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 6j1rtPh5eWV94Sie7eISJIyAMoJxgH+ZP5VwupfBvxXYkmG3gv UA6284z+TYP5Zrb+GjXPhzUb3R9XtLm3lkHmLHIhVs9iAeoOG5 HpVdCZxtY9HZdH/AOetv/3yKjMWinnzLfH0FWhqFq3S3uT/AMAP+FBvoMZFpcfipqCCjJb6K4wZYPwx/jWdJZ6KCR5sP5//AF62zexN0srj8RVG5vkVv+PGc0wM02ujdriIfRz/AI0htNJPAuk/7+H/ABqd9QUE40+b8x/jTP7R6406b8x/jQBC1rpna8Uf9tiP6037Lp//AD+j/v8An/GpTqGTxp8v4sP8aZ/aB/6Bsv8A32KVhHhMszynOOuAc1o/280cccEUqrHHgKcd89cdD9SCeaymtpIwrgLjOeTVKbIkbYuc9M da5ORSNDslaGVpLi2mmaeOMnO1VWM568Dp6U+8gh1GOA+WYGCg sUG5wM84O4A8ep4/GsC1vbi2McaNGshfzDKoAJx05xxj9KYQPtCzNjO4ZCjbu9/xqORpiNK1fUJJjDEyTTxhlVncqyjuPfJ9fasy6sGg2iRMMV4PZ h/eB7jFb+maVJrWjxskIE8UbLEIlJ8za2MkZ4OTk+oHeo/Eqm3NvEXDBULBzgFskd889OtWnaVkWlYo2+p/ZkkaJVw4C7QAGAwARnHTgVmyKkrgfMpLY2dgPr1rbjW3WGO5jT cGCM6DIGeM9PesqawmSZisBMbHgZoQrF+6sI1jEKzADyo3xt6u wJA/BSD/AMCrAZGEmzq2cDHrWoEku7jzJGyPvsvaom2QkPGx3rywA6/SqjcGMt4ZYZxFkbt4VgexzjFO1WyYXM1zAhU7gDsX5GJ7UiWkk ccVxG25WbJz1HPekvL14ruOHgHCk7e9MCmjo2ezgjKHtVizhcX 4CucPkED3HT9a17xf7RsR56NJNxskCkmMeuR2+tR2VnLZajbLf CSNXK+VKmNshJBA3HgH86XN7txFTUrSFdWjWIOsUqb8NyUAYg9 vY1VnVRd4QBUyAcYyB3xXQ310LTUmuU06OZYVEaO878hs5XjAP U9vWtKx1u9tIVt7Xw/Ync33EuCXJJ/vHkfnRzaXGzAhVFtlVcBQ/U+5/nWr5USabcS+aWlndCFCZ2DevJP4Ulxr8EBmhn8M2kbQlRJicvg nOO5Getar6d4muPDMl7D4YtrfS5hHO1yJMlYwwYMAW9PQd6bi5 WsyinHcRSSsqXSMw6jisXVtGiutRhjjaOJ5Incsq8Egr1A+prX itI0ummRYw7DBKgDNRzgjWbPPeGXp9UrUk5h9N1jS2L25ZlH/ADzO4H6rUN7rV3PYyWtzbhWbHzYK4wQen4V2slZGvf8AIEuf+A/+hChAco8ttiIw78lcSI44z7GrMMFrMnC4P1qbU3Q2OmFCpKoQ2 DznA61UQZcMnDVQiyumxO4AJA+tUliUbuW4YjrWpaMzTBSDuHU VmqcM577zj86AJ4LTzCSHcEDsala0ZVH79wfQkf402KUqSRzx6 1MiyTbyF5AzUPcD0TwfazN4Ls5A8ZTfKAHVT/y0b15rrrbS7lbMZhtm4ycwqT+dch4Qe3fwpp0MkMhIeQsyqDn9 41dUG0tht/eRn1Mf/wBehjE/s2br9ki/4CGX+VSC0ljXm0/KeQf1oihsWICXYH1JFXlslbHlX2fpKaBla2tZWkyLefI6Bbth/PNMvdXOjRebq9jq1pb52/aYblbiIH/aO3cv1Ix71v2VheoP3d/KDj1VqtyQ6uijF1u/3of/AK9CEY2i3FvqG26s7y/mgbpLFHDMv6JXTm4liiA+23K/9ddO/wAAK5nUvBOpanNHqWm3cWl6zGcpeQIyeYP7sgHDA8ckHp3qPTf iJqui6kuieNbGGzujxDfBikM/uTggZ45HHrtqktAOsiu2HJ1GyB/6aWbL/wCz1YF+5+7e6U/1JX+pq4l7cMiuLF3RgCGilRgR6jJFKb5lPz2V2v8AwAN/6CTTVgIUvLlvunTpB/s3BH/spqTzb7/nyt2Hqtxn/wBlqT+0bcfeEyf78Dj+lMfUNPcYkuIPo5A/nT07AQSNcP8A6zRg/wDuyof54qnNBERl/D04/wB1IW/9mrQEejznhbGQ/RDQ2kaZKMi2hHoU4/lS0EYvlaehy+h3Q+lirf8AoJNWY30dfvaddJ9bGUfyWln0C1yT GxX6TsP60yLQmVvkmnAH92dj/M0rgXEudIUYBkj9mWRP54rzP4lNDp/i7QNesbhXyPszpvJIKNvXr2O5hXqcWnTIv/H/AHQPu4b+YrA8d6Bc6v4L1O1W5knkWLzolaNc70O8YIA54x+NWp JBvoa/yvpKX1tGkgkRZFXGPlOD1+hrLlv7oZxawj6t/wDWrN+E2pXGp+CV3SoRDK0SArkgYDevTLGjUbvUoLuaI3Crsdg AF7Z4/TFDVmT0JH1O9DY8qAfj/wDWqCe/vmQ4WAH2H/1qybifU3bIuZPwQ1Ev9oMp3XEx/wCA1Iiw97qZ6GIf8AqP7Tqpx+8T8IzVCW0vCxzPMM+4FVzZT5+ a4cfWXFO4WNYy6uR/rQP+2VN36t/z1P8A36rIayUfeufzmNN+xw/8/af9/TSuFjidavbW7Vk8zaFbeESJSGwMZDBsjjPGK5i5tZFlA2HOSDz W/ctao+6EkrjBz61jmRpJWaQ4LHJ+tcsNEaFiCCOTR0kP+tMoXHq pB/wqxa27LdRfu1D5wQx46GsyZHWNFgLMEOVJGPzrRF1KNp8t1YMD z6f5NVIehr25hjmaV7aDz1B+XblTwMHH/wBbvWNql1DFq21BmKJVXGOuRk5/OrqXXlT7mBZlwAfQVhamstxNJcKpCyucAe3FEdZDudTZ3KWotZ zuBVE8voQTgdfw7Vc1zUhqNqmlWybbi5nETuBj5f8ADvWRZRO1 tbKkbGWMDI2nGR/WtSGwma8kuHMK7gEVT8xQZ5/kPyrmmkpXfQLndPZafDZyD7LbG5kUjKoGIJ4zz9e1eTXsctqCq GMRSMy+WyAlDnHccGu7ifTVkSWa5uLhozlVA2DPuc1ah1qOHKW dlBbjoXCAkD3NYUqsqfS5Nzg7e3vpraGOK3lcgMCQmRg/h2yavN4D1e/uBKLOfbgfejIP611l1q83lDF87s3G1Fx/LtUC38RUfavNcnq5PQfQ81qq1V7Kwxtt4EuXgjhu7uKGLoYwxJ GPTHH60uo+HH08xxWVjaatFIrLMROIWQcddznIIz0Pam3M6Ods VvcY6IzgoHzTZbyWGILc2YA5KKnf6jGaEqt9x2OY2y6Jr1lDPA xs7eZbsQCVZDEFOeWUHcgCkkdcZruPEev3lro0SrGFg1K3fyZt MthKGHTiQOPmwRzjjPtXLWFxeQ+J21hY8tt8tV2Z2jAXv04H60 t9NfnWDqemxpb3h5cRDCzY7MoGM+/WurkUrcy1HayM95rm6tdP0owBRZKzRRCERvggElgMkn5ckmobe x1A6dd3thJciwRwb1YyBEMYIyAeeOelXdMuru+1O/dlKXsiss0bnDAHrx6dKrav4aa10ybUJImUJtOS5xksAOMepArS Ls+w2lYtpfQu42yIfY8VDcSLJrNkVCj9zL905zylYQBb/lmrD/ZqXTto1uDCMh8qTOf+A1djI6GQ1k68f+JLcf8AAf8A0IVqSnis rXf+QJcf8B/9CFAyM2I1DRLeIsquEUqxHQ1TbwzqCDcjxOPY4osNRnS0iVkyo UAVdTUoiQJFKj1xTAzk03UlPlvASvI3IQSP/rVSnt3jdo2QrID0A+99K9GtNHhu4UeO8nTPIZEB/nUWoafpf2aSO51WHcq8ea6Bsj2zRcDzmOTy87uPrxU8V2Yg2wg 7hjrW/ZauLeVYLq43QJkLKjkZ9ASK3rHxVotnfzybJpY/IjWLgvh/m3n5umcrSauS1ch0AeIdK06Bf7MFxbhSVRARIoY7ucc9+9dVpW opqLsgt54plGXhZ2Vl98HIxWTF4l8OSD5rmeFvV4Gx+YzXSafZ 2t0YmivlbBEifvCCD2Iz7H9aCzRt4G67bhf95Ef+WDVkKAcNIn HXzLdkH6E1pQ2+oRIPLuy4x0IDD9KDcahFkvHC/wDvLipAoxJbu2DHYSf9tdp/VP61ajsY3cbLKXH/AEwmRv0Dg/pT4r6RWzJYZ943/wAa0bK6s5pP39pcKP8Aai3CmBJaWkUXWXUrc+6y/wA+RTdZ0LSvEOmPp+o6g8sR5XzCgdG7MpIyD/k1rx/2QcbBbIfoEP8ASrK28LL+6kfHqkrH+tWkI8Ha8134Pa20NvLb6 jpF6S6KzcPt6kY+443DOODx7Y9Z8M+LF8Vab9t0xrWbbgSwtIY 5IW9GXBx7Hoe1aer6Da63pc+nXzyyW0y4ZTjj0IOMgg8g184eI dE1P4e+LV8p8mJvNtZ2QFZU9weD6Ef/AFjTv0YNdUfS/wBpvV+9YZ/65zA/zxSHUHU/PYXa+4QN/wCgk1x/gTxZbeMtOlZLBLa9ttouIo52Uc5wykDocHjqMfiesMMq9EvF/wBycOP/AB407CJDqtqv+s86P/rpA6/zFQyappM42Pd2/wBGI/rTJJ5Yxn7VdIf+m1qGH/joH86zdS1ExaZdym6spSsTfKUaJjkY45PrUy0Gi6dP0a5+41o5 9lU0g8PWa8oqD/dYr/I14Xa6Tqcl3FaRyPM7sIogGx145r24WixWkMVxpMzmONULrHHJ uwAM9c9vSsqc5STurGtanGFuWVy2mixr9yWdfdZ3/wAaZPptyo/d3l3j/fDfzFZrjTYuXguLf/eglj/UDFQ/atN6R6kEPobkg/kTVmJ5NY6hfaJ408S2dpcSRx/a33hOATvY5x26mtZ72/u23NcTOfWuYfdP438RvE5cG8k+cc7hvOOfwrqvD3h241x5kW5W 38rZkyKTu3HAxj3puTshNajPJu5F5eX8Tiq5tpA/zSH8ZKZPayW91PbuwLRSNGTnrtYj+lVJIsNy6/zqbhYtSwR7vmmj/wC+81GYrZfvTp+AJqqyx55kphWP1Y0XAt4tR/GT9EpN1r/t/wDfIqttU8CM/iaNo/uD8/8A69K47HHTSu7ZllGR3BzTEWJjwrMTWjaWVsgDsxk5yGJ+X64P +NXGCREDBJHoMfyrFy7AYoMa9M59BzU6NEBEfLf5jkEjAIrbij 3kp9ljwQFJYAfzpsu2Aqz+XtUdFVc/mKnnGLNa2McvnFRzggO3AOKuWVxFNsit2iXAz8seCB65APFUW1 aNyVVUUYxwOlR/ag4ISB2J5IK5rOzluCN2K3jndTLqdtAoO3Dlif0X+tVLl/K3Kjw9/mQE8euaoN9qfP7mRsjHGeamXTtSKjFpIAfUY/nV+xRViwmY2DPDu38cgkA+vFT/AGm0hAAiTfnBcOcj6D/69UU02/Jy2CR2bGPyqwmlTZG51AA5H+RTVJILDmvo2ZVVSFJ/1hYkn14xU0V68YIhVS2MEuoY/mRTBpzKxZWRTj+Fc04W0pBEl1IRjGAmOPzq+VFIes14ykNGGJw TmPmnB50Hy7RnrtYAD8BUSafabgXaVj1+9j+VW4rbTwfniDf7z E0agBMyxs32raCBk5OakgCuMNqSqex8gSEfQkjFWETT1Jk+yx7 VPJx0qG5lspQAqIADuyGb+VOzY+ZLcg1Sy0+S3RZtTuZ5Izuik 8sBo2/vL8x56VzWta9qg0OXTb7zJRLIm24U/JIAwPzD+FuB0rommsV+7bKT67D/AI1Vu7mK5gMBsEdWHIZQM/lVxVtyXJdDjMJty8LAeqmiwaFdZgZXOBHJu3DGOlF14du2vd1s nlQ+jSdPpU76FdMq/wClEFVI7ng9RWljM1Jr22Vf9ap+nNZGr3sc+lzwx5LNjH4EGqk mnalbE4zLGOxOarS3UkeVuLYrnuOKLATWMW6zMilwsQG9uwJ6V axcrayXEJSaNOGUnkZ9qxppVEAWJT8zbsF8nGPb8am0q6vIrlL dGZElcbl6BvqeuKYG5batqKabJGgIjkUnK5yoweB6CuZYnPNdv qeky3l5FJbWaWCW8Cid4twBJXGWyeCfm6cVzF/pot3KGbfIf4QrfzPX8KFoMhhfESkkEcjaTTiiAb42yncZ5U1b0 KMQajbXkxxBb3MXmHBJAJJ4A5PCn9K73UfF2j/ZTG1teXETnaN0YRScdixz69qTdgSPPGtZo4RM1vMIiNwcoQCPX P4iun0rxreabY20UdtDKsahR5ueVHuOf51i3F1G8N1DYiRbaQ7 3tWbcVwQd2R+Rx6094ybSGSGVntWyEU8+WwxlT9Mj6gg0wO6tv iXbSfLeaLg/3oJgxz9GUfzrXtfGmgTkZlvbQnu8ZI/NC38q8uihyeeK0ra0ct+7dS3pnBqXYZ61aa7aTuBa69C3osjgf o2DXZaTNqXlbkNrcIe4yv6jNeCx2t2o/eRkr6smRVyJJGTARSPQf4UkB9BfbbtD+805yPWKRW/nig6lbFcXEc0QPaaFsfngivA4tQ1LTzm1mmhx/wA85WT+RrTtfH3iO0G03szj0kCSfzGf1q7iPZ420qY/untt3+wwU/pzXKfEvwZH4h8MvNbeZ9usVaaDLswYcF15PcKMe4Fc9Z/Fq+j+W7tLWUDvhoj/AOzD+Va8HxL0W9x9t0ptw6GMpJj89po3C54FpmpX+i6lDf6fct DcwNuR1/kR3BGQR3Br6P8AAvjWXxhpDTLFbpe2+FuYdzKFJztYHB4bB+mC K8U8faZZ3niOXUPD8Ev2W5XzJIhEV8uT+IAeh+9x6msbw9rms+ EtXjv7NnjkX5XjkB2SL3Vh6fyODTTewnpsfVn2i7X79iW/65Sg/wA8UG8jdGSe3nRSMEPCWBH4ZFZuhazNr2i2uqWMltNBOm4BgUZ D0KnGeQcg/StL7Rdp/rLHd/1ylDfzxSGU7az0K1uTPBBawzEYzjaQD6A9KuNZ2F0CTBBJ7hQT +YoGoRr/AK2G4i/3oiR+YyKUXtlMCpuIT6qzD+RosBn3GhxZzDuX2WVh+mayrjTLq E/LPcKPrn+db8uk2FwNywRA/wB5Bj+VZV1oBU5ieYD/AGZGP86hgeB2sElz4l19wWJF9LuPT+Nq7Xw0dNtIrj+0dTlsW8 +3lVolZmcIWJX5c8E46/8A1xxOlW7T6prLMxyL6XOTjne1azWsKD5inHqc0MTRYldJ7maU kHfI75PuxP8AWq07Rq33hSI9vGcbkH0xTZrqHHy5b6CpGRGZex J+gzRvY8BG/lTDcMR8sbH9KTzJ25CqPqc0DJQJG6J+bUuyT0T86jVZz/y0x/urTfKl/wCez/nUhYS1tdJQCS3nun3DhhGn+NX4rSybjz3QHplMk1bm8AyW1ybj S5njjzyjA5/A96ov4j0+G6e2+xQBUOPMMfJI9jUyi0yrFmPTmcjyUZ07E45ol tZYD8yqD/vCs66vopjvVyR22gCqLTE52Fh+NCQtDYEoXIy3A5ANM8+Q/cTJ6ZLAY96xmkkPVmPpTVc9zV2YXN9bxoxltpPtVqHXJ4/lWX8OP5VzqlW6qv5VKqgdMUWHc3f7ZuHXiYbTx9aa07yZLKxrM WZk+7gH2p4urhjjzDycUrDLjTbefLUH1NRfa5t3ygbcc881XaS YNh9wPvSBs9WosK5aLsw5Az9aUE8Y5NVdsR6kn609WRBhQPwp2 GWdxC+hNNYlvQfhUQlGegpWPGaaIYpTdn5u2eBVSSNTySTgdan 3/wBR0qFyCj8j7p4z7+lUIrwySxrM888EcMaLJuZyBg54ORgHj9a htNdsbvbiRQWxgN8p5GehqWay/tiN9Ks7pYLqW1icM+VVtu4su4dDyPyNcffaRqegXaSDCTIf9ZA 4kAP+8uRSWpTPTdI0wazepaWzKJWBP7w4UADnJ5rf/wCEDRCVm1KzZgMskG6VgPoBXjtn411qxlDPIHZejfccfiuK0tL 8b+IPOKLciU3TlpPtSAx9M9cbunfP4U7SDQ9Ti8F6cFOZHc9ty CJR9STUV54HtypMd3ZqndfNy36CuRsvE0s0AmkeKIkkbEmx+h4 rTi8UKrqjSIxboGAGfxHFS5MZX17QmitLlhNJPK67eDw3oK4O1 0bU7e5jkNo4Vc9vUEdvrXr+l6st0xLxoij+Lb5n6ZBrpLKFb7A hubb3H2Uqf1ampCaueIPba1JbrHGCCxMj+Um7A6L6+p/Ortp4O1/VUQSWUsyAh1MriNc9iM4r2LU4NM0dQ+pa3aWRYZAkaNC30BHPS uZuvHng2wzu1+4uGBxttI9x/PGP1o5uwWOYsvg9f3E2+SZbJ1+YOJVkBP4HOak8TfDTU9C0Y6o lxHdhXX7R5SFeOfnZRkcc8+9XLr4uaAqlLGz1ad8cPLciL8eCf 5Vg/wDCz9ZluC1o0kW05G6cv+mMGi7CxLo3hjV7+wF7a6c11b52kws rkH3UHcM9RkcjFSm0t7W8+y3sMlpcAZMcoKN+Rrnj4t1mw1mfV 9PuHsrm4z54tkVVYkcnbjHJwTxyeeta+reLLzxjeQahN5EM0UC wkRH7+Mksc9ySeO1U1pdAa5solXdEzsPRcH+oqjNdW4PlyysuP 76kfzqlFcXkIy9vDMO5K7T+Ypkl3DIT50FxEP8AYfeP1FRYCcR h33W91/3y/wDjUxOoRjl94/21zVFYrSU4S6jJ/uypsP8AWnmxkjGY1bHrEdw/SqJLP2xwcS2iN7qcUn2izf76SR/UZqus1zFwJmP+y4/xp/2uQf623RvccUhk4t7Ob/VzID9cGpVsrhBmGd/+AtmqomtJPvxvGfzpy21tJ/q7hQfRvlp3EWc38TBjhiOhKYP5jmtC18U63Y4Ed1dIB2W4Yj8m yKyltbuPmGRiP9ls0/7VfQ8P8w9GWnzMVjq7X4ma3bkebMJR6TwKf1Xaa2bX4tPjFzp9 u59Ypin6EH+deef2hn/W2yn/AHaPPspfvK8Z/OjmCx6tH8SNAvFAvLGdD6mNJR+hz+lW4vEHhK7ZfJ1OCA5HyyO 0B/I4rxp7a2l5jnTPo3FVZbGVclDuHqpzSbTGiLRUiuLnUpC6EG7k IbPUFjzWu62kXWRPwrA8ORwtaTvNIq/vT1HNbDy2MeBvZv8AdGKGA83dop+Xc3+6KjkvM/6uBj7niomv4h/q7Zj7sahe8uXOEjRP1pWAeZrh/uqq/rRsuHHzSkf7oxVcx3UvLyMPpxTAkEQzNMM+7ZpWGXBDGvMso/4E1MP2PP30qOK5svNRA27ccDaO9b0ehvLGsiz2AVwGAa8jU4Pq M8H2pWC6NiPwboKDH2F3A5w88h/9m+n61ZvvD2nahpyWbw7I4VxEYusYx2PcA54PtXYQ6S8qfLCxz 3arLeH5gm5UUHHQA+ldDbe5rZHz1rvhnVfD0nmkM0DHCTICVPs T2PsapWmsB38ufKt69q+gpLN7UkySKuOCW4x+f1/U15x4k8JaLcH7RYXltZXGcmFpAI2Ptk/L9On0rNxIcbHOhA4BByPal8kZ6YrDktrnT5DJDJuT+8D/ADHardtqiSrsl+QnrnpUsRoGNh9049+tP5UZYnFMZ29yKj3kf/XoAsrLkHDDjinCQk96qbmPQ0oPqaVgLokA9KkFynAdBgH8ao4G KUY9aLAXDMgwVftyCKsJfxBdrwqfcDmswBc8E01xxRYDTlv7Zl xHbbD6mQn+lIzZh3D0zWO8m0clcCpBq1uIdjsVKjGccGmhMsRj Byxy31p0knysfVT6+/4VkzatBg4Z2+gqjLq27ISJz9eKYizJc/Z9QjYEf8e/OfQMM/pmp76SOeBY5DuQyJkeozWG8rSkNLyQMDdzgVWuJXf92j7cckin bUZ1MJtbddsSIijsoAqvf30MaRspXcJB1+hH9a5Rowfvs7n3NO gjjMgUxjkHrSeiuVFXkkdE97FIh8xKy3nVi3lghuuRxUQZ4G8l iSpHyH09jUEnes1N7M6HRi1dF+HUpBasC7bhnGTzSaP4g1u1Mi W2sX8CgcCO5cY5+tYznBqXTmIu9v8AeBH9f6VtE5paOxa1fUry 9uZZr25mu7ggIZppGZuAMck+gxisouXHPUVq3lt8plVuWIwtUJ YtoDMoXd0xTJIB1qeeWRQqZPAGTjnpwM/SmwxlpVC4bJpHyJXDH+I5oAuact/csfs5BC9SzYxW42n3jQrIYbdphwxSQ5ce4xjNc9bXZtidnGa0o daZcbh+tGgG01rHbxxvHNPE7KCSYyAD3BIPHbtzz0xzZgu9QVc xzpcxjjBIcD/CsmPXk9SKn/tuBxiTDD0YZFS1cDUXUUY4uLJR7xnFToNPnPySmJvRxj9RWD/bUEXMIeM/7B4/I8UR+JlBxc2scy/3kGxv04qbMZ08drdRjNrcbx/stn9KHknQ/wCk2scnoWTafzrIt9V0W6IHnPbN6SjI/MVs2qSEB7S5WdPWJ80XAarWjjDJLCfY7h+tO+xxSf6u4iPs42V eEowEuAyn/ptGCPzGD+lPFlBOPkVWP/TCTJ/75bBouIzW024QbvKYj1T5h+lRq08LYWRlPpnFaE2nmEgGQoewn Qp+RNIq3cAyu4r6o24f1oAq/bJxw6q/+8tKLmFv9Zb4/wB01MZlfiWNSf8AaXafzFN2QuMruX/dbePyPNICMpaSdJCp/wBoVDLZkqxidG4PQ1O0GD8siH2bKmoZYXEbZiYcHleR+lAzO8P Lbf2ZI8z7W844UDPGBWg9zaKMJA7n1JxVLw6bYaRJ5odn808L0 xgVd+1BQRFbL9W5/nVPcRA19LnEcKIPpzUL/bZuWZgPYYqR3vZzgEgeiLUL2TA5nlVP99ufyosIia3jUbp51B9 zk0JNaxjais59lpSLGIcs8jeijAqP7WBxBbIo9WOTQBHc25uSM W+FPBDHqPpUA0tcf8etv+MQrRRLufB3ED/ZGBSmyTPM3P8A11FF2gZbuPidfyKd2oajLk84mYD8s1hz+NZ5S cW2f+usm7+lcsiGaRUVhknjmpngKkg5DA4Ip8xerNR/Et42TiJSe23gfnTk1HW5og0bEK/IZUUZ/HFYvlnODya6fTHjOml5WCBOMnuew/GlcLFeyFyszSXsxLEYG47sfh6fStNPs1xgoQj89BzUXHRhuQ+1 VJIWViy5wPQcim0noLY6nQ9Dv43WbMLQqMsN+5Tx06dav3lnpt 3P5UO+Cc4+Vm+Vvoa5ew1a6tzkO2B3RiCPyrrbfWtIvvLkvoPK uQRiZH/dMfVgTx/L6VlJNamiszDvdOu7F9k8Lxn/AGhjNUjKyda9QjstUwkdtbySQNFhkZAI29Op9D1wPWsi+8DzXc 0iwxLa3ITzPJ37lP0P/wCvGaFPuJxscGbqm/ajVrUtFvtLnMN3A8Tdsjg/Q96zfIIzkn860JJWuz0zUTXJPemGI5oKY7UARNIzVGQT2qxjnp TgR6UAUyjGk8rNXTz2ppwTigRnzRlUJHXgD8aQWwVcZqxcoTHh Rk7l4H1FBTimBVMQpBGFbcOoqZkqFhgZzn3pPVFRdncbM+VG7j 5hVaRgBU5b3ppI74qFA29v5GfJuweKijcqwIOCDkGtI7TxVeS3 RunBrVHPLV3L8N4lwm1gRL1OBweOtZl3cGeYseAOAPQVd0u0Pm yyOSEVCA3+0en9fypslrZwH55Gf8cfyouKxQgbbMh/2hT5xid/941OLm0i5jhBPuM/zpJZBeIZAmJF6+4pgVKOlOxQRQA0MacHNNxRzQIkEhqSOTPGKg APpV/SWW31SznlhWSJLiNmRx8rgMCQc9iOKaVwuaGleGNX10n+ztOub oDqYYmYD6kDAq5feC9e0n/j+0y5t1/vSRkL+fSvqDSfFen3torxBBCoA3QMsiKPQlSQv44rXh1SynP7u 4RhgHIPHOe/TtVe7tYSZ8i2suraeP8AR7mWNR/DncPyNaUHiy/X5bu1guh6j9238sV9SXukaVrCA3lla3a9AzoGI+h61yOq/CXw/fHdZ+bYv6Id6/k39DS5Isdzx218WaaWHmm6sH9WBK/mDmugtNZS/X91dWmoAfwvtdv8R+daGqfBLUVJexvre4HowMbf1H61xGtfD/XNIBN3p0mwZ+cLkf8AfQ4qXS7Bc64vanIktJbc+sLkj8VbP86g ktrSUZjuYW9plMR/MZFecRW91YSE289xbg9RE5AP1HetO38QalEu2W4iuB6TRAH8x/hUODQ7nUXFlHEfm3J6FSHX8waoz2zeW5ikR/lJ689KqQa3DOcXNsIz2aJ+D+YqaV4JIXaK46KflYe1QNEXhaaC PR3DweY5lJBJIGMCrr3M4kKxIkQP91eao+FtQ06x0h3u7m3jYy thXBZsYHQdMU+/8YWAbFtFPce7Hyk/75Xn9ap7kjp7O7nO+Vnx/eY4FMh02N8ks0gHUxIWA+p6CsC98U6nNkWxjtYyOkK4J/HrWMZJ7hy88ruxPViTTQHZ3M+nWmVDwZHUtJ5hH4Jx+tZFz4gt 4yViSWX8ol/Icn86w8MOjEfjQJriP7krj6MaYFqTXbxjmDbb9soPm/M81nyanqnmN/p9x1P8ZqY3U/8AEwb/AHgDSi+mA+6v5UWAoBsHKnB7Gu48SWME1tY61ZIq2d0oQgDGHA 7+/UZ/2a4Nx+Fammzl4HtmPUbl9jUNGiY6SLbzjpXWeEdRbTr9oS4EVw uxwy5GexI/Ej8awAAyetOibGDUboo6jWtAjsg95pU2+DJL274DL/u+o68dR71km4iMYI2njuM4qq0oB65qN0Dnch2v61orkE0jQzDL fI/ZhwfyqFZJIZBhnVu3PWkimEjlXAST+dWY9wUpJHlffoRVAbnh7 xXqGjXay29y+wkGSBzlJB6EHOD7jmvWNJ8eaZqqKpDW1weDDKQ c/wC638X6H2rwl4jH8wO+Pvn7yj+oqeC4MafJgj1BqJRTGme/zSafeRvG0ETK/DHaPmB9a4XXvAasJJ9LOMAnyWOc/T0rF0XxXLaQ7JLlRCoziZ+n0PX8K6ODxDPe2kc8RPlSoGQ4xkH pWesWVozze4tJ7WUxzxPG46qwwahIrttTD3iMJDkn2rmZ9MuI8 sF3L7DmrUrk2M1gfSk2k9qviycYYDIp4YR/8sx+VO4WMzyiTwM08WsrdFP41d+0kH5Rt+lMe5LdSTRzDsVxpz nl2CirNtZ2ETBpw0uP4egNReaM9KQyk9ARSuwsdNp/iGDTnH2PTrK3P/PYxhmH8j+tN1XUdM1oBtQMlxLjhhGkWPxUbvzY1y53HpUbiXHA yajld7oZXv8ATYEcm1kZk7BuorMeEr1Fa+JGwCDk0htXfjFap9 yWjEK0JGZJAij5icAVuLpDSttCkH1xxThoV5A6ssLNuOxSB3Pa ncLGbd4CR2sZykfUju3c1U8gntXTnw3dW9qLm6jEEbOEXzDgsx 7Ad/X8K1I/CjRkM0c08frEhCn/AIEeKVwscA1pu/hp0Vo6OCinI9BXpY0e28owrp8cJYf62SQs4+g/+vXR6TZNDgrLACq/x2kZBPvxSdRByHlNn4O1bWJd9lYyNE2D5hwifmxAqTxF4HvfDm w3F3p1wr9DbXau34pww+uMe9e6+EMaF4XtbS8aJZ495JiJYEF2 I5IB6Edq6e31OGbgOTn1NR7bUfIfIL2rKSCOR1HcVGYSMmvsW6 SzvbYwXcEE8DdY5kDqfwNcB4n+Gfhi7tJrqzD6fJGpkP2cGRSA CceWT/IirVaN9SXBnPXHg77MIzY6dDc6aghf/R5Spm3oGBJUbiCARn345rdTRrefwteMvh2DSnddu57cozKSThW bJ4wpJPPXGM1ieE7i40mxs7OS0tr5CzSWsjOzOqHb2XO0Dn8W7 54u6j4svUtpItPeQzyyyoFLeZG27IP0IGee3PtXZKnCVn2OPkq P3uh5yGzj064Nbml+KtT06QKJluYlA2x3S+aF6/dJ5X/gJFc87eVK6HBVWIBHPSpLdkMyFjlMjNa3TVmLVbHp2neNtIvpx JqGn3Fjdbg32iwmLBj6sjH+RNem6N4osdVgYxXdvM6BeI3w7Z9 UYAg8dOa8Bm+wvZvP5kkdyke4JEqlGPZTkgjt8wzzmrFlNtt5M Egtt4oVGEttAdWcEm9bn0cl1C7Bd21j0VwVJ/A1NXzlb6jdWUpktbmaB/70UhQn646/jXY+G/Fuqqk2+aKVmxl5IlLfmMZ/HNJ4d/ZY1iV1R6neafZ6hH5d5awzpgjEqBsZ+vSvEvGfhmx0HWJI0lEN q4DqDgEKe2favQ9D1uXU9SNrqF6ArofLTeIizZHC7cE8ZridU1 uDV9aEJ8P28MNvFczLNJl5pPLU/wARHA6cc9axqU2k0+htCopao8o1yexW/QWTZjEYycnlsnP9KzxdDs1QauSL36rn9TVEMRWNizSfbK+7IHH OKtXemSafdtb3OwSqAWVWDYyM84ptjq9wLq2hsIorIs6IXgXMj EkDO9ssM+gIHtV7x1cb/HmtEYwt0yDH+zhf6UmBVhaCOQAwb+ByQSB+taBe0O1hbNuHRo8 Aj9RXOpOfWrEdywxzS1KRoyf2crt/rVJPO+IkfmKbssJOT5XTouVP5VDHctnPWraXZx1YfSkxlRbSzl fCMWxn5fM2k8e4NO/s60HDCcHuN3T/AMdrXhvGyDk/jVr7dJ2kx+FS5MEkcDLAzTN5aEg89Kkjtpo2DhcEHNawGep/KopB2yMe9O47CWswlLADGD0qcJg1QiVoroSDlejfStMuQhGB9c c1NhokSTy0DBEJz1ZQcUs2ozoCAxX/AHeP5VCjZBXsaqPnPzc0K7B2RTuXk8wSA55+tWhqdz5aCBN3qC uakRsdBxVhH/CtEToQBNauwAsXlofYIKuWvhe6usteXqx9Onzn+lWILgg9eK0I 7nkENk0mwsXNM8E6Ijq11c3FwQfugiNT+WT+td5vhSARx4SNVC qo4AAGBXAreMOM/nT/ALU+OJGx6ZqGm9ylodHqEsUallk247saxZdRdgQsuR6iqTsG5J 59ai29Djn35pWHcLhmmyec9j6VVZpE+9yPWrZGetMZBTEQghhx ik288CnNEp9j60qgp9/keooGMx600gHsc1Y+U9OlNIAouBEUOOACewqSOF2A3KAaFYbhn keoqyku3pxQAxLTPfFTxwNH1PHvT0bf3yPapNvvSuMkhOCCRu+ laoUXkECREpItxE7MXClUB+Yj3x0rFQkNirMe4t8ualjO6tLuy 0+JltUUM333+8zn/aY8n8aimv5pzwoC+prmbcOvJBqZnkPRqiwzVeASjLOpJ7dKpSw mM5jJB9jVZZWB2s2PepEbnIbIpgKpkUbfmA+tSrcTRDIkb8DQJ WLY2gipCHI+XP0pNARm+m3ZLyH8alTUlQfMxbPGDzVeRWUcpx9 KgYr2HPpSsAn2LSftX2m3jawuM5822wAfqn3Tn6A+9C6mNP1i1 W5mjlhkhuYElA27TIFzkHoTg96ryvtz8o/Cs24C3B2TWwaP/a61tCtNLlvoYyoQcue2py4OFA+YfXkU3hXV+2cGtCfw7dKxexI kXr5ch2kfQ96qbXtpRDewvbu3AEo27voe/wCFd0KkZLQ5pwaZfgAxVkzrEvzMBn1rPS3dAfJkAU9j2qwv7uM lm3EDJJrpUtDncdSZbpHPDj866rw4d0cuK8rN0JLpzLLICzcEN jArpvD9pff2jHCZEa2kIPmFASR6exqYVrysFSjaNz03T9bsdD1 W3vL1mEcbNnYu5uUYcD8azdY8e6VHaXUGj6Od1xDJC9zePlgrj DbVGf5joKlntLfyShWMIDkJt9KwPEFzaRaRPEzIp2/KOByKupG92TRqJWjY8s1GcXN2zoPlHAqrtPpVkodxwKURZrz2z 0EaPhSze78VaTCkbPuvIcgDPG9aj8QFpfEeqSOpVmvJiQRgj94 1dz8Pb7+y4BFCAJbm4LTEgHMahQuP+BM//fNUfiFDd6l40vgsJYQTy2y7V67XLf8AoMiD8KltXGkcGoNPCH8 61Dol5ER5ttKo/wB01NHaRRj5lYH/AGhSbHYz4Y3PABNaMNo+zc+APStGznjgbpGw/wBqpLv7FOC0bSG5J+7HH8n881DlqOxp6XH4aijVb552lOCTtO0 fgDWvt8Gf8/Y/75k/wrjGsLuMBmhcKefummbXqeVvqNHNnOc7mJ9zShtvY0Aj1pcg9K 1JFVz71oxN5kQbv0NZwJqe1fbIVPRv50pIaLKnaxB/CnSKA+T0PamsuVPqOlSD546hOxTGyWzIgkUZQ9xTFqWN2T7r4z 6UzbzxWhI9Tg1YST0NVRmpFDbhjgd80WA0Y5ScDNW1GOSKzYyA RmrkMiqQMnBNS0MsGgZPQ5pZcqA0aNID3GBj8zUiEsFO0qfSkM QAFc5B/GkC5J4qUoGYZGR6n1p2xywUZAB544NICEoAOcUhiIHSrLREdBm q5SRJAZZPk9hj6UAQvECckYPqOtRndH95cj+96VqRpHLwh3Ee9 PNoOhIye3egZmKQwBB4py9fu1dk03A3jIYdxVZjJCdsq/L/AH/SkA0jIw2MZBwalRxu+8Tmm5DdBmnKhYEcYpDHnOOpA9qntZ3Rx gk/SoUjCHrU8Kfvt+9s4+6DwKTGaX2hnUYHNN3yZyVBNRoNpycema eSCBhs/SlYZK0qInIBNJFOGPy8fXimBQ4wf0oAUE4IJHUZ6UAX0+YdcVc t0OcA5NY4uCgyo+lTx6nIp6nGMYxSYGlKSp2uoHpVCRd7kKKH1 AupyABVSWTft+cqAcnb39qSAnMDZ4GalitVY5bg+4qBZN38R+g qxFMynKigLl2FDEBhAc+1XkmlQnMI6cADg1WtNRCH5wPrW/p99byDJ2nHagTOM1Xw7pWpFpBZtZT9TNaAIWP+0v3W/EVx+peHtVsYZTDi7j2n+HY4H0yc/hXvNsLadgSNq/3SMZq3No9pcDKgAVrCtKOzMpUoyPk7ZhDtClnBVgw5jIPatfT9 Wl0iGKRVMjgnAzjFfQd/4L0jU1CXllFcBfulshl+hGCKtaJ4O0rQo3FhYxQliCzMS7EjOO WyR1NaKvZ3RMqfMrM8DhufE/iiVotPtppCPveQhbbn1boPxxWpbfCLxLcxNcXU9sJz92KSYsfx IBAr6Fjt0XIVQSOuBThFuY7gcfTFTLESY40YxPma48C65aX6WU unyec4ygXDKw9Qw47d61rX4X63LbyTt9miVELYeQ5bAzgfL+vS voBreMjOR6VXn09ZYnQN94YqPatl8p5JZWFimoafbWbxTvDC8U m05IMYY4I7HcWb8a7GSC0n1f8AerkTb8nH8X3gfyJqzeeG5Fu0 urVIVf7sySIXWde2c5wykkhuPTpVyPw9HLqEV3JJIoVV3IWyjH aBkjseo4/EUO7W4jLu/DVvIpaNR7cVzmoeHpYn4jBH0ru5tHVZM200kY9j+lVjbX0eQJB KO2RzWfMUeaz6H5h2tAuf92s268OmEbnt/l9Qa9aIuoyPOtAw6/LUTfZ5FI2bD3VhT52Fjyy00ISLm1u54H9A5q5/wjusdtUkrodd0O2u/mMEW9R8rAYx7ZHNZyxXSKFBIAGBg0rhY8XwfWkCkcZzV4WwFHl cgBea6jIqBadtNaC2jt0U/lTv7NkY4OB9aBjPvAN2IzUiqUY478ihdPuY/kBUr2NWV0922mSY8dlGKzaNE0EVtvGQQBVtbRVHTJ9aW3tRECI wxJ6knNX47eZuAMVVyTFngCsMEctt/H0qskqgvuGFQ4JrqV8OJcNul3Enr8xAobwpZQkOo2ADHBzn86V waZg2a/aMsVwM8fStSG3A5NXBbQ242x9B2PapBJHt4GPrRcLEMceTwDx6 ipwi5GQDzUsU0Y6ipXQMp2gDPcilcZRd49+3cM+1SR5z1qR4yS MKcdaawKEEcj0oAkCMxzsGPrQkb5bfjGeMDtQkm8A4/DNO3sp45A7UDFxt+7y3oKsRxvMAuwEf7QqBS5bNXracpKu9U2Y 5YtyD9MUmCJBacfMKq3FgzKeOMc1rrdQk43denFJeRSXdjNFby CF3XAbAx+PFS2M5p9HkXLqNrDuB1qubaVDmVSB6jp/9aut0/TLi1FuH1OWZEyZEdQQxxxjjj9fwq9Mi7TtHH93AxS5gWpxiWRA 6YPvT2JthhkJU/wAQXOPx7VrXtow3SQgRuT6cH6is8TyRyBJkIPTPUGi47EakuA6 cqRkHFWII2kYZSr9pJAzAOVBPY1rpFEUG1F+ppOQ7GQLLjjGfa oJ4DEOCv0rbMJJ5II/KoTCAeiioUhnPLFt3bUxk59s07a2MHj6VrzKmegDVTkTccVdxF VUx8wz+NOUAsCVGR0wcVctrZd3A6+tXGsflyaLgZoQk4AIPrVh EI4Yj8KVkMbY6UB89c0XEICASOaequf4jj8qckTHoMA1KsBTlq QE9vcTR/ccgd/StOC9mbH71gfeqESOxGxPoanFuzkcYweppoR02m6mVYq+M+vrX S2lwk0YPU/yrzyCKRJcc8+h611OlW8gVvnIzjrRYTOhKggdcVDOswT92B09e amjCxIoLYJ9TUuKpQuieaxnQmcofMGSDxiiTevcD0xWgQSCM49 xTTGvXHNQ4spSMrbLK5O4he47VN5arwVJq+F4+YDPtUbRA554p WC5WMeRkY+lQupHQDP0q95apxkZ96gl5PT8qLDuY93cvASShJ9 ulZsmsRS5SVMitm66EY7VgXkSq2XUYpWEQzQwXS5hJU+hNUDpd xk4xWra/Y2Ozdtfrg1oi2ix/rk/OlYZ858EE7adGfTI+lSIrZyy9OmeAal2bW4xXXczsCKD1WpvKU jueORSqMc4oByeDRcY/Zj6e9PXAPSmjB65qSM4cHaTSuBbidR0GK0o1d/ug4HUgVlNGXB5K57jFXI5nQZGce5qWM0woVT1JxWfPLkkde1Vp r51k8vDfUc1CZm3ZCZJPBoSBkmxm9u1I9sskRVoyc9acJZW4YY x15p+0Fc5yfypgU7dZrVypRDFnjYOR9RV0TnaSFYD3P9KjwQu7 t2prStjGDz1oAkclgN78dqj3K52rk80DGzpyPU06EyO2DHj3DZ oASeYxKMIzyHhUUdf8KnthcvHunhWNv7oOa0La2V9vJHIOR3rR Fou05xii4zIjGDyc09uRnGavSRxR9gcVVkZVJA3A9cEUgRArBH DBeeh9qtxzv/k1SZsjrjNPSTHIP41LGacU+zgjj2NWrWVI5NxnlYEfddsgVkeZ uUgt+FNCEjggH61NhnQSzq/+qxmq81p56jeoOeuKzE3hgN/PYVp20j4GSfyo2GZlzpQiXdbbkcHO3GVI/p9arRXk8M3lyB19PQ/j/SuklQyRYOW/SqS2w3EFOB3zS3AijuZHUHc1RTzyEY6e9X009QQ0PynOSozg1I bbdhJU2MeBxw30P9KVkBgjf1yfzzWjZRBmMhzuxj73GKtDSxu7 ge1X7e1ES+poASC2DEMB29/5VeFruIG3jpwKgyFbJHHerdpdKHw/TtSAT+yA6/dzUM+h7Uyo/SuitpEk+7jPsa0YYt5Bbj6niqTEcMNHmAyuSfpUkemTbxuQgj1 Fd8Yo1HKg/hUbwRMAVGM+1AHO2WnbfvDJ+lan9jpIudmfwq/EgBBUhvoeKto+F56+gouJmGNGJcMExtq7bWK28rMqAu+NzYzkC tFZdxx6VKoA5AqlqS3YbGpVQD0xUlRJJIZWRoSqj7rhgQf8Klr aEbbEMKjEUayM6oAzY3EDr9aeSFBZiABySe1IrCRFdDlWGQR3F KWoBiil6UhIA5NQ4hcY3HPWq1xIEj3MGHsMH+tSo6OXwpXaxXn ofpVO4iLsSpNZloyb+/x8oHNc9cyO7k811b6eH4Zcj3qnc6MHJKEEjsOlFhnL7xnDUYH+ zV+eyuInIKZX2pgtwRkof0/xosB4ssPOc89zU6Y6en6VkHWI15SKWT3IxVZ9en25SFVPuc1vZ kXOmTGeoOKkyOy1xratfOMeeV/3QBUTXt6/3rqb8HIquVhc7pFZj0AHtUqwgkhlTHXB71wAu70Hi6n/AO/hq5Dq2pwgIJ2YAfdYA8UcrDmO7WUcBmGf5VBcXUMBBMoH41xja lJI379pM+ueKZK4l/dkgClYLnV2uqRXZdYzuIOM5qfdubbkEnjmvP7eRrd0kU/xCu10qZLxAUPI+8KTVhmlEjBhk9OcVY2tIflXk98cVNDEOCqgj 1qwsZMwXIXPOMdaQystkWxwTjuOlOFk0S4JU5/CtZSqDP51EyCRwf4c55NTcZnJBlsEYHc56VpW9vGCMjJq1FaKx UIF3em7mklIjyPlDCi4DdiLyD+dVJ5EZT+84B7GiZlf7/ze2agJC/Ii4H0oAY24jjIJ6ZqMjYmCcDrgDimpJLtk3pjHQK25jTieelMC IhSP6GmKHBHI9xjOasbdwxyKAgX6UgI0lLSGMRyBv7xjOPzxj9 asMMkH070BsLxVJ76UzGOC1kYg4Z3BRR+OOlKxRdU7TzwPQGrl vc7TwSB61n5LMCSPyzTx2BH+NIDfhvVK8nPuaGlYZfiT0VF5P4 k1lQxFmB6itGM7AMAD1zUtAa1kZJACAqfUZP6GtqGAMPmCkVgW kuG+Ygcd63bW5XcABkd6VhjJtMYAm2wCTkq2Sv8A9aqhjkVijq Y3zwOob6Hv/P2reQtI3JG30p0yqUwefWkFzmJYHznac+9Mihdpzw/y4yWBAOfT1reNp5YJgwMcmM52n6eh+nFIXWMEC3mkl/55RoCxHrkkAj6H8KAK1vG6cg4NaUM0sY+YnHvRbN5ilmgkixxi VQPywTmrSRlvuhKYhY7hm4J/OrKOVBO0t7UxYJNuSY0926Yq5EUABAOOnzrj8hQgI7GX7ZbrMs UsQOQUkXaykHBBH4VdWPbyST9aiUvJgjj3x/KrCqV6nP1ppXIbIxKi8PIucnHbv6U8Llg4Y+nWnYzTXj34+Zlw c/K2KrlJuQi2d7gSTyB1TmNApAU+p55P8qtUmDnrS1tDQlkF1Z21 6iJcwpKqOHUOMgMOhqfpRRV3SYBSEU2STYvClj2ApkAmw5nZSW bKhR90YHHv3/Ook09B2HhdueSc81FIgK57euelTMSCMKTk8+1NYbun6GsGikzK nuGiYAbsY6Dv9ajW9ZW5Py1Zu4MfMxx71iXbmI8jP86RRpyXsb HnGCOpqubiHJ5Nc3PeOshPQVB9uPrSA//Z[/IMG]
07-29-2013, 02:07 PM
#156
Just bought a 2010 wolf pup 16P and couldn't keep the awning up. Anyone have a video link for how to assemble?
05-15-2015, 07:36 PM
#157
I just purchased a Wolf Pup FB. I did the following:
Installed outside compartment door for access underneath the bed storage. It came white and I had it painted black to match the trailer stripe
Removed the stereo/DVD, going to put something better in. What a piece of junk it was.
Removed the panel under the sink and asked the factory for a door, did the same with the the panel to the left of the stove. It added two more storage areas. The doors are not a perfect fit color wise, but very close. It cost around $100 for the two doors
Changed out all lights to LEDS
Added a second battery bank
I am looking for a good way of holding the toilet paper. I am also thinking of installed a bar in the tall locker so I can hang up some jackets.
I know this is an old thread I was just wondering if there are other ideas for upgrades
07-11-2015, 09:10 AM
#158
New Wolf Pup 17RP owner
Hello,
My wife and I are owners of a 2014 Wolf Pup 17RP Toy Hauler. I read this entire post before posting here. I checked and our axle is rated foe 5200 lbs so that should not be an issue. My tow vehicle is a V6 (truck-Based) SUV rated for 5,000 lbs. After a maiden voyage towing 350 miles, I installed a weight distributing hitch. Towing with the V6 is not ideal but the SUV is a spare vehicle so I am not so concerned about wear and tear. It has an OEM transmission cooler and class III hitch.
This is my first RV and I know little to nothing. I purchased it to haul one or both of my motorcycles to events. After two events where I rode 500 miles each way, and encountered major storms along the way, I decided to lose the hardcore rider label and arrive safe and sound. Here are some initial pictures. I am still researching the best wheel chocking solutions.
07-11-2015, 12:18 PM
#159
Black Bear Family
securing bikes
Bolt It On, Serious Racks for securing bikes, if you were referring to it in your post.
07-13-2015, 04:03 PM
#160
