Old 06-22-2017, 06:50 PM   #21
They most have forgotten, nothing like it in mine :-(
raulrio is offline   Reply With Quote
Old 06-22-2017, 07:32 PM   #22
Sagecoachdriver's Avatar
Have you tried the switch by start button?
Have you tried this switch? There is a switch just to the right of the start button and to the left of the oil stick/filler.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 06-22-2017, 07:35 PM   #23
No, I don't notice that one. I'll go to the dealer tomorrow and see if they've figured it out and try to look for this.
Old 06-22-2017, 07:42 PM   #24
Once when I changed the oil on Winnebago Minnie's Onan generator, I cleaned the area under the oil filler/stick and accidentally flipped the switch. Took a half hour to track it down after I fired it up and tried to exercised it.
Old 06-22-2017, 08:02 PM   #25
Yes, sounds probable,.I'll check it out!
Old 06-23-2017, 07:17 AM   #26
Wolverine 1945's Avatar
When you go back to General to get your unit you should demand a proper walk thru,,, with some one like a service guy !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-23-2017, 07:35 AM   #27
2017 Windjammer 3029w
My old motorhome had manuel switch. Inside the power door for inlet cord, I plugged the inlet campsite plug into a box with a power plug in for generator. If on shore power, the cord plugs into campsite box. Keeps from accidently having both plugged in at same time and there was no transfer switch. It just meant if loss of shore power, I had t go outside, unplug from campsite and plug into box inside electrical cord plug in box for generator. Was easy to get to.
Dastagg is offline   Reply With Quote
Old 06-23-2017, 07:46 AM   #28
I just took our RV to dealer for the same issue. In my case, if you remove the generator panel, there's a little black toggle switch at the right of the prime thing or manual start up (not a tech person &#128513. Ours was in the office position and once flipped it worked like a charm
Sherise is offline   Reply With Quote
Old 06-23-2017, 08:01 AM   #29
So if one position of the switch is office,,, what is the other say ???
Just Kidding !!!
LMAO !!!
Old 06-23-2017, 08:06 AM   #30
World Wide Wanderer
wahoonc's Avatar
Just Kidding !!!
LMAO !!!
Vacation? [emoji3]
Aaron[emoji41]
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 06-23-2017, 08:07 AM   #31
Exactly as in my photo in the post 6 prior. Common issue and easy to overlook.
Old 06-23-2017, 08:34 AM   #32
Yes they hid it pretty well !!!
Old 06-23-2017, 08:54 AM   #33
I didn't see your pic until after I posted, much better than my description 😁
Old 06-23-2017, 11:21 AM   #34
raulrio, I wonder how long the dealer will be searching? I hope the switch solves it!
Old 06-23-2017, 11:53 AM   #35
We'll see!
Old 06-27-2017, 01:10 AM   #36
Any update?
Old 06-27-2017, 05:41 AM   #37
Yes, some. The woman in the service dept called to tell me that a breaker was tripped and the vehicle is ready for pickup, but they could not really tested because I have less than a quarter tank of gas. The could have called or just gotten the fuel and added that to the bill!!! More later, going to pick it up this afternoon around 4.
Old 06-27-2017, 06:53 AM   #38
Maybe they did not have time to drive it somewhere to get fuel !!!
Maybe letting your tank get below 1/4 started your problems ???
Old 06-27-2017, 07:09 AM   #39
No, I had around a half tank when I first tried it and it did not work. A possibility may be that the inexperienced gal who did the orientation started the generator while the RV was plugged to house current.
It sure seems like after the sale, their time is too valuable to spend on you! They have fuel and propane right there.
Old 06-27-2017, 07:30 AM   #40
Sorry to say raulrio,,, you pretty much nailed it !!!
generator
