Old 06-05-2020, 01:43 PM   #1
Adhesive remover suggestions for front protective film
A shout out to anyone who has removed the protective film on the front of their motorhome. Can anyone suggest an adhesive remover that they found works well. I can remove the film with a hairdryer and plastic chisels I got from HF fairly easy but getting the adhesive off the paint is something else. I've tried WD40 as well as Goo Gone but it takes forever to get the adhesive off
Nomore9-5 is offline   Reply With Quote
Old 06-05-2020, 03:09 PM   #2
HONDAMAN174's Avatar
I’ve had good luck using this. Be careful though if you get the non- aresol version as it is a stronger solvent.
Just glad to get away
Old 06-05-2020, 07:43 PM   #3
We used this, available through automobile paint supply shops
https://www.kolorhouse.com/auauqueaadre.html
Falconman is online now   Reply With Quote
