Originally Posted by NXR
I had that happen on our GT5 after a while. Somehow the service tech fixed it. We'll be back there at the end of next week an I'll try to remember to ask him.
We had another door dragging which was "adjusted" by the dealer. We picked it up today and I asked the tech how he adjusted it because it's now fine and none of the others have started dragging again.
He kind of smiled and said the doors are not adjustable so I asked him what he did. He said it looks like the weight of the door is deforming the door slightly so he took a rubber mallet and gently tapped it on the bottom to un-deform it. He said you need to be careful to not hit it too hard because the door can deform.
I also noticed that there is a drain hole drilled on the bottom of the doors that were never filed flat. I put some masking tape around the holes and used a fine file so there is no edge to drag.
Ray
