09-26-2018, 10:10 AM
Best Portable Space Heater for RV
I'm sure there already is a thread for this question, but I can't find it anywhere. My question is: "What is the best portable space heater." I've used a radiator-type in the past but want something smaller for my Class C motorhome. Thanks.
Hi Rider
Jack and his dog, Amber
2016 Forester 2401W MBS pulling 2006 Jeep Wrangler
2020 - 162 Days and 5,359 Miles
2021 - 113 Days and 3,835 Miles
2022 - 35 Days and counting, and 3,372 Miles and counting
09-26-2018, 10:33 AM
Empty Nesters
I just use an electric 1200 W with 2 heat levels and tip over shutoff. I have heard that the radiator ones work well also.
Here is one of many threads on the topic:
http://www.forestriverforums.com/for...rs-149445.html
2017 Sunseeker 2250 24' MH
09-26-2018, 10:41 AM
When a furnace failed on me during a trip I picked up a couple of small heaters like this:
https://smile.amazon.com/andily-Heat...l+space+heater
Nice and small so they don't take much room to store. Have tip-over and overheat protection to minimize fire hazard. Also have power selector so I can run one at max output or put two online at lower power settings. This allows me to have some heat in the bathroom as well as living area without overloading the electrical system.
The oil filled radiator types are nice but for someone with a smaller RV they are way too large and hard to store.
Both of mine fit in a small space at the bottom of a closet and combined are about the size of two shoeboxes.
09-26-2018, 10:53 AM
Denver To Yuma In 90 Days
I have two of the radiator-type heaters from Walmart ($35).
Sure they take up some space, but I find that they heat much better than the forced-air-fan type heater since they continue to heat even when the element is not powered up.
Between the two of these they can keep my 33-foot 5'ver pretty warm inside.
09-26-2018, 01:03 PM
I too use similar heater except I put the heater temperature control to high and plug the heater into a digital thermostat controller that plugs into the power outlet....provides nice percise repeatable temperature control...
We bought a small electric ceramic heater that oscillates back and forth. Has 750W and 1500W setting. Small enough sits on top of dresser and blows heat thru whole bedroom. Tip over shutoff switch. Works great. We also bought seat cushions from Walmart for $5 each that we put up in the roof vents. Creates extra insulation and we are always nice and warm. Use this in northern MN all the time.
09-26-2018, 01:10 PM
We use two Vornado AVh2 plus's. They do a great job in our 35 rig. One in the bedroom and one in the main area. They also work great as a fan on warmer days. They work in a manner that is very unusual but they work great. Take a look at their website, it is worth looking into them. Someone else told me about them and I now swear by them.
09-26-2018, 01:38 PM
DeLonghi TRN0812T Portable Oil-Filled Radiator
these are terrific - we have been using two of them front and back for years.... much better than forced air on/off all the time
https://www.amazon.com/gp/product/B000G1CXZI/
Great when you're on shore power
09-26-2018, 01:39 PM
Lasko Stanley model 675919. I’ve found this to be the best and pushes the heat throughout the rv. 1500w and 750w settings w/thermostat. Most of the time the furnace is not needed. Check it out.
09-26-2018, 01:44 PM
Don't know if there is a best.
We got one that's cool to the touch (cause I'm a total klutz), has an internal thermostat, and can operate as a fan only with a two speed fan, and shuts off automatically if tipped over.
The one we bought isn't available, but similar ones are usually available at Walmart or online at under $50.
2015 Dynamax REV 24TB class C
09-26-2018, 02:05 PM
I mentioned "space consumption" because lots of people have TT's that measure in the lower "20's" for length. Space is at a premium.
09-26-2018, 02:22 PM
I prefer functionality...
One of those radiator heaters on high would probably keep that little camper almost too warm, but they won't have to listen to the annoying fan running constantly or worrying about a pet's tail torching up on the ceramics because they supply a constant even heat...not just when the fan and ceramics are firing!
Or popping a circuit each time it kicks on.
Plus, there are smaller, much more portable versions of them, although they are much more expensive.
09-26-2018, 02:32 PM
We use the same ones that Titan Mike has a picture of. We got them at wal mart for $18. They work really well for our 35ft rig.
09-26-2018, 04:31 PM
We have been really happy with this Comfort Zone CZ448 Oscillating Ceramic Heater. $24.99 at Bed Bath & Beyond.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
09-26-2018, 04:43 PM
Grammar Pedant
I got a small Sunbeam ceramic heater. It's just a tiny little cube, but it cranks out an amazing amount of heat. If I needed a new heater, I'd probably start with something similar to what I have now.
Former RV: 2018 Rockwood Mini Lite 2504S
09-26-2018, 04:51 PM
Oil filled radiator type.
09-26-2018, 06:53 PM
Ink bird
I googled ink bird but can’t find “this” model snd it looks like what I want. Do you have a model # and supplier?? Thanks. 👍👍
09-26-2018, 07:06 PM
We use the “TitanMike” solution. Usually buy them in the spring for about $6-9 on close out at Walmart. What I have found is that they don’t last if used a lot like every day in the house. What happens is the internal circuit breaker keeps popping. They last a lot longer on low, so we tend to use both on the low setting.Even then for $6 you get 2-4 camping seasons out of them! Jay
09-26-2018, 07:07 PM
I use the thermostat below from Amazon. As for heaters try to get one that uses ceramic elements vs resistance wire. Also try to get two heat levels 750/1500W. The low setting comes in handy if you have limited service.
https://www.amazon.com/Lux-Heating-C...mostat+digital
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Originally Posted by jbrosecity
Yes - and I connect to shore power that is separate from the RV power system. 600 watts does great. I also cut an inside access panel to the water pump to keep it warm.
Ram2500 4x4 Diesel / FR Surveyor 251rks
