Old 09-26-2020, 12:40 PM   #1
Can I add a ladder to my 2020 Berkshire 39A
My new Berkshire 39A Motor Coach does not have a rear roof ladder? I was told that if the coach did not have one installed by the factory, there may not be sufficient bracing for an after market ladder. If a foldable extension ladder that fits in the storage area is better, please recommend one. I'm 62 and 285 lbs. Need something heavy duty.
RDupre is offline   Reply With Quote
Old 09-27-2020, 08:22 AM   #2
SeaDog's Avatar
Your assumptions are correct. I did a google search there are allot of collapsable ladders out there I found only two with 300 lb weight limits you might give the internet a search for a ladder that will fit your needs good luck.
Retired Navy
2016 Flagstaff 26 FKWS
berkshire
