03-23-2017, 10:45 PM
#21
Antenna placement class C?
2017 Dynamax Isata 4
03-24-2017, 06:06 AM
#22
If you really want to communicate on the air. Get your ham license. ( you don't have to know Morse code anymore) You can get a tech license and you talk on 2m and 70cm. The expense is more but you don't have to deal with filthy talk. The cost would be about $15 to take the ham test and about $150 for a radio. If you end up having fun with it you can upgrade your license and gear and start talking to folks around the globe at the campsite.
Duff
N5RDM
03-24-2017, 06:16 AM
#23
Ham radio is great hobby , but for traffic info , finding out about the delays , not many folks will be in a 20 mile backup with Ham gear.
Some folks use CB radio as a tool, not as a hobby toy.
03-24-2017, 06:28 AM
#24
Insert witty title here
I can do all that plus tons more on my smartphone and no license is required.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
03-24-2017, 08:01 AM
#25
I got a fender mount for the antenna and put it on the driver's side of the nose. I don't remember the brand or where I got it but it looks like this:
It's worked really well on the road for getting traffic jam info that Waze didn't have. 70mph and it doesn't hit the nose of the coach. The fiberglass antenna is stiff enough that it only bends a little.
2015 Forester 2301 - Chevy
Skip & Deb
03-24-2017, 07:51 PM
#26
I use my 2m as a tool as well and I don't have to listen to men talking about nasty things. I use mine for traffic info and I'm a storm spotter with the NWS Fort Worth. It's not just for play my friend, but hey if your good with dirty talking truckers over modulating and using illegal power more fun to you Sir. FCC doesn't regulate like it used to. Have a good one.
03-24-2017, 07:52 PM
#27
True
03-24-2017, 10:18 PM
#28
Your options for class C antenna are roof or side mount on coach itself. Either way running the wire may be a little work
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
03-24-2017, 10:31 PM
#29
Got are first TT, a 2017 2506S. TV, 2016 GMC Canyon Duramax Diesel Loving it!
03-24-2017, 10:32 PM
#30
Forester Fred good option.
That's a firestick brand cable with firering. I believe the mounts are vehicle specific. Those are good mounts and cables and the installation would be easy. The one downside to a firering is you can overtighten it on the stud and it will not function properly. Like a compressed disc in the human back!
03-25-2017, 08:24 AM
#31
That's why I went with the fender mount. It works, maybe not as well as mounting the antenna in the middle of the roof. But, I don't want to drill any holes in the body of the coach and try to figure out how to run the coax. From the fender through the firewall up to where I mounted the CB was about an hour job total. I only ended up with a couple small holes inside the fender lip for the mounting screws rather than a hole in the coach for water to get in.
Skip & Deb
03-25-2017, 08:26 AM
#32
Yup, the directions were very specific about NOT overtightening the mounting ring on the stud. I've had a good deal of experience in my previous life doing and overseeing radio installs so I'm very aware of not using gorilla strength to mount radio gear!
Skip & Deb
03-26-2017, 08:34 PM
#33
I was looking to use that type of fender mount for my am/fm radio
05-30-2017, 09:13 AM
#34
If I see you on the road and notice a problem with your rig, how do I let you know on your smartphone?
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
05-30-2017, 09:21 AM
#35
Wave your arms like a crazy person, point and yell at his rig as you pass him. And honk the horn a lot.
It worked for me when I guy did it because I left my antenna up.
It worked for another guy when I did it to him because he left his antenna up.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
05-30-2017, 09:36 AM
#36
This does sound like a lot more fun! =)
05-30-2017, 12:51 PM
#37
The FCC ended CB licenses back in the 70s and I didn't need one to visit Canada. I paid for my CB and antenna once but my smartphone digs into my wallet every month.
05-30-2017, 01:22 PM
#38
Just as confused as you
The reason the FCC ended CB licenses was mainly because so many OTR drivers failed to get them and you will be lucky if you can transmit/receive anything over 10 miles. Normal consistent range is +/- 5 miles. I won't get into using expensive amplifiers to boost your range so you talk over all others just so you have bragging rights. The drivers close enough to you that might have been able to help in case of trouble couldn't understand what you were saying.
Plus, the likelihood of dropping your CB down by your feet and not being able to retrieve it is impossible.
Richard & Jill
05-30-2017, 01:55 PM
#39
I use a small Midland with a thru-the-glass mount on my rear window. It suffices for 2-4 miles distance and the truckers will tell you which lane to get in if there is a traffic backup. When the language gets rough, the BOSS doesn't have to say anything, I know to turn it down. The mount has stayed on since the truck was new(12 years ago) and still works great. I don't talk much on it but mainly use it to monitor what's ahead.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
05-30-2017, 01:59 PM
#40
CB's are very handy in traffic, i have 1 in my personal truck for long travels with the TT and i also have 1 in my daily work truck that i'm in for 4-6 hrs daily driving. It has saved me a lot of time sitting in traffic so its worth every penny, and the conversations are pretty amusing.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - 42 + scheduled....
