Old 12-04-2022, 01:13 PM   #1
Coach Battery Compartment
I’m cleaning up the coach battery compartment and noticed some holes not sealed that’s apparently letting dirt and moisture in. Should I seal them or do they have to stay open for ventilation?Attachment 282026Click image for larger version
CampClark is offline   Reply With Quote
Old 12-04-2022, 01:18 PM   #2
In mine, I left the holes open for ventilation. It didn’t seem like a lead acid battery compartment should be tightly sealed.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 12-04-2022, 01:33 PM   #3
Thanks. Two more thoughts. Maybe just seal the lower one? What about putting a piece of rubber material under the batteries to absorb bumps? I did find the battery strap in the compartment when I removed the batteries so I will be putting it on when I replace the batteries. Click image for larger version
Old 12-04-2022, 01:34 PM   #4
Originally Posted by CampClark View Post
Thanks. Two more thoughts. Maybe just seal the lower one? What about putting a piece of rubber material under the batteries to absorb bumps? I did find the battery strap in the compartment when I removed the batteries so I will be putting it on when I replace the batteries. Attachment 282028
Sorry for the double pic.
Old 12-04-2022, 03:08 PM   #5
Kanadian Kamper
kenandterry's Avatar
I’m cleaning up the coach battery compartment and noticed some holes not sealed that’s apparently letting dirt and moisture in. Should I seal them or do they have to stay open for ventilation?Attachment 282026Attachment 282027
Like others that have posted questions when/after removing batteries……
I hope you took detailed photos before you started removing any connections.
This is suggested assuming everything was working satisfactorily before removing the batteries.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
kenandterry is offline   Reply With Quote
Old 12-04-2022, 03:28 PM   #6
Lol I learned that lesson years ago.
Old 12-06-2022, 08:14 AM   #7
Had gas tank in the trunk of a Ford , the spare tire sat in a depression made in to the top of the tank. Had that brown rusty water stain and a whole lot of grit.
Grit and dirt eventually ate pin holes into the gas tank.
Found this out after filling up and the spare tire started floating!
what's that got to do with a battery well...
dirt and grit in the compartment will eventually wear holes in the battery.
clean out the compartment
glue some rubber 1/2" strips to bottom of battery
(hot glue OR self adhesive rubber sheets cut them to size)
space strips so there is plenty of gaps for water to run out and to collect the gritty dirt
only has to be 1/8'' thick (or thicker if you can find)
rubber sheets or rolls of weather stripping can be bought at local hardware
PS glue strips to battery so can take out the battery leaving a clear space in the well.. Makes cleaning easier.
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 12-09-2022, 03:47 PM   #8
Certified Curmudgeon
Duckogram's Avatar
Goop
I cleaned up the metal and coated the compartment with a generous layer of flexseal. Followed that up with a critter prevention screen over the vent/drain hole. When I reinstalled my AGM’s I put a wood spacer between and in front(MH front) of the batts so that when the strap was tightened the batts would not move forward. Worked great for years.
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
battery
