Old 01-28-2018, 03:09 PM   #61
We had a 2010 Mariner that we towed. Owner's manual said it could be flat towed. After 2 years and a burned up transmission Ford changed their mind and said it could no longer be towed. It didn't matter because we were going to a fifth wheel but it goes to show you can't always trust the owners manual OR the Manufacturer.
RonAnne48858 is offline   Reply With Quote
Old 01-28-2018, 03:28 PM   #62
If the manufacturer put it in writing then they should be liable for any consequences for just following their written advice.
If buying new you will often get a notice from the manufacturer that there is an important change. If buying used it's a good idea to research the TSB's for the make, model, year and see if there are any listing changes in drivetrain's or new limitations.
One Manufacturer even sent me a new Door Sticker because they changed the tire inflation pressures. This was for a vehicle that had changed hands several times, not a new purchase.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 01-28-2018, 04:36 PM   #63
Our 2016 Ford Edge V-6 AWD is flat towable. We use a Blue Ox tow system and Air Force one. I did have the dealer install a battery disconnect (we don't use it on short trips).
2016 Georgetown 328ts
2015 Fiat 500 Toad
db7512 is offline   Reply With Quote
ford, towing
