08-20-2017, 07:35 PM
Front electrical outlets no power
2011 Georgetown 350
I have no power to those outlets...
Under dash outlet of front passenger seat and also surround sound system outlet...where should I start looking?
Thanks! [emoji6]⚡️
08-20-2017, 07:44 PM
It will help greatly if you post the make, model and year of the Unit.
You may want to add that info to your signature. It appears you are asking about 12V power, is that correct?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-20-2017, 07:47 PM
Welcome,
Please complete your signature block with Make, Model, Year. That will assist others to help you.
Are the outlets you need assistance with 12 volt DC or 120 volt AC house hold type?
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
08-20-2017, 08:01 PM
2011 Georgetown 350
It would be just your regular plugin outlets to the wall.
08-20-2017, 08:05 PM
Originally Posted by B D HOWie
Welcome,
Paul
2011 Georgetown 350
I would have to say just your typical house plugin outlets
Thanks Paul
08-20-2017, 08:23 PM
Check the GFI outlets with the reset buttons on them.
Typcially near the kitchen and bathrooms.
I have a GFI in the rear bath that kills the outlets in the dirvers cabin.
Dan
2014 Berkshire 390RB-60
08-21-2017, 03:30 AM
It kills the outlets in the front cabin even if they are not marked GFI ?
Right now every outlets that is marked GFI is working...there is also other outlets in the motorhome that are not marked GFI and those are fine...the only part that is not working is that section at the front cabin on passenger side and they are not GFI outlets...
Thank you! [emoji846]
08-21-2017, 08:14 AM
Yes that is correct. They are Daisy chained through the coach in what seems like a random order. Each GFI will kill multiple Outlets.
Some rigs have a GFI in the basement.
or it could be a loose wire and one of the outlets where it's daisy-chained. I had one of those that I couldn't find in the factory had to find it for me. It was under the floor.
Or one of your breakers on the breaker panel.
good luck.
Dan
08-21-2017, 10:01 AM
good luck.
Right on ! That is good lead.
Thank you for taking the time to help me ...I will keep you updated [emoji4][emoji1303]
08-21-2017, 12:47 PM
Retired Ford Tech
No power
I have an 08 350 and if you have too many things in those outlets, it will trip the breaker. My breakers are right outside the bathroom door. The breaker I think is the 2nd or 3rd from the right. If your not sure if it tripped, just push them all to the on position. The one that tripped will have a springy feeling, just push it down to off, then up to on. If that's it, then just limit the stuff you plug in to that circuit.
Mine controls the outlet near the dinette, but controls the TV also.
08-21-2017, 12:55 PM
Electrical plug
I found that a rat had chewed the line going to plug in front tripping the
Gfi found where wire came from gfi to front and disconnected it.
Woks fine now
08-21-2017, 08:49 PM
Problem fixed...it was a loose wire in one of the outlets in the front cabin
Cheers [emoji482] [emoji2]
08-21-2017, 08:57 PM
[emoji1] [emoji1]
Dan
08-22-2017, 02:59 AM
X2^^^^ GFI reset will solve the problem most likely
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
