Old 08-12-2020, 03:23 PM   #1
Fuel tank
Does the Freightliner M2 have one fuel tank or two. The tank(s) can be filled from either side of the coach.
John Russ is offline   Reply With Quote
Old 08-12-2020, 03:33 PM   #2
Just taking a stab in the dark here, as I don't have a M2, but if you can fill on both sides of the truck, it's 2 tanks. There may be a hose in between them, so that they drain / are used equally when traveling, but I don't think you can get away with filling one, and it filling the other on the other side as quickly as the fuel will go in. At least that's how I understand semi's and dual fuel tanks.
Greg, Janelle, Tenley, & Ellis
2019 Palomino Puma QBSS
TV: 2015 Silverado Z71
Other toys: 2007 Rinker Captiva w/Monster tower & rack
GXPWeasel is offline   Reply With Quote
Old 08-12-2020, 03:40 PM   #3
That’s what I’m wondering, when you fill from one side are you filling both tanks.
Old 08-12-2020, 07:35 PM   #4
Dodge Guy's Avatar
I don't have anything like that, but I think the smart way they would have built these was to have 1 tank with a left and right fill up.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
fuel, tank
