Old 06-13-2020, 10:13 AM   #1
Dodge Guy's Avatar
Generator question
Hello. Wondering if anyone has come across this issue. My generator runs great and has no issues except when I hit a hard dip or pothole. The harsh jolt kills the generator! It will restart and run fine. When the road is smooth I have no issues. It only happens a couple times and only on very rough highways! Oil level is exact, it had a full tune up last year by me. It has 340 hours on it. Runs fine even in the 90’s and 100 degree temps.
Anyone run across this issue. It happened last year right after we bought it. I found it overfull on oil, fixed that and it ran fine till yesterday. Looking back I know that when it died I was on some rough MI highways.
Thanks!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-13-2020, 06:57 PM   #2
Thanks!
Sounds like there might be an ignition power source loss due to jolts. Loose connection? Relay being jolted open?
Might have to drive slower on crappy roads
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
generator
