07-11-2017, 06:35 PM
Generator while running and Fridge Question
Is it ok to use my generator to run the ac while driving down the road in hot conditions to keep the Motorhome cool? Also....If that is ok, will the generator run my fridge at the same time so that I am not using LP while going down the road, or does the alternator in the coach drive electricity to the fridge while rolling down the road?
07-11-2017, 06:36 PM
So would it be ok to run the generator while going down the road to save LP?
07-11-2017, 06:43 PM
Is your generator gas or lp? If you are running the generator just to not use lp for the fridge then are you really saving lp since the generator is running. The fridge will use way less than a generator.
2019.5 Rockwood 2509S
07-11-2017, 06:44 PM
Generator is gas....wondering if it is ok to run it while going down the road..... then I could save LP for boondocking
07-11-2017, 06:46 PM
My generator is gas also
Sent from my XT1254 using Forest River Forums mobile app
07-11-2017, 06:47 PM
Sure you can but just to save the 2oz of lp a day that the fridge will use real does not make sense but it's yours and you can do what you want to do. Happy camping.
07-11-2017, 07:01 PM
Yes, it is okay to run your generator while driving to provide AC power for the A/C and fridge. We do it... If you have a gasoline generator just keep in mind it will not run when you get below a 1/4 tank of gas...
Wayne and Christine
2021 R-Pod RP-192 with OEM Solar
2020 Ford Expedition Platinum 4X4, 3.5L EcoBoost, 9,200# Heavy Duty Trailer Tow Package with 1524# Payload
07-11-2017, 07:28 PM
Thank! Yep...found that out a couple of weeks ago! Haha
07-12-2017, 12:45 PM
I don't use LP for anything when I'm underway. If some idiot hits me and damages an LP supply we're in big trouble. That gas will continue to flow until someone cuts the tank off.
07-12-2017, 01:00 PM
I have run my genny while under way when I had the class A, the only problem was that the cooing air intake was on the bottom and would suck in hot air and overheat and shut down. Now as to the comment about shutting off the propane while driving. While this is the safest way it is not absolutely necessary as most new rigs have excessive flow cutoff valves at the tank.
David & Teresa
2017 Silverado 3500 HD Duramax 4X4 Crewcab Dully
2017 Cedar Creak Silverback 37MBH
07-12-2017, 06:08 PM
Sunstar35F
Fine to run generator while underway
We reside in Northeast Florida and usually run the generator and our 2 AC units & fridge while driving as the dash AC can't cool the whole coach down enough to keep our 2 greyhounds comfortable. Also good to run your generator at least every couple of weeks and since we use the generator when driving, we never have to worry about that.
07-12-2017, 06:14 PM
My last motorhome I had a generator installed exactly for the purpose of running the ac back there while going down the road.
I honestly never even thought about the little bit of propane the fridge uses or not while the genny was running I just wanted it cool back there for the kids.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
08-02-2017, 01:04 PM
We run the generator (diesel) while on the road for the same reason listed above. Our power management system also charges the house batteries as well (8 AGM batteries) while running. Couple of things to keep in mind - always check oil and cooling fluid prior to every time you are going to run your generator while on the road. Also, make sure windows are vents etc. are closed to avoid fumes and carbon monoxide from blowing up into the coach. And shut down the generator prior to fueling your coach. I always make it a part of my walk around when fueling to check underneath the coach to check for dripping fluids (other than the AC condensation runoff). From a maintenance standpoint, I do fuel filter changes more frequently to ensure trouble free running in addition to the normal oil filter and air cleaner changes.
08-02-2017, 01:13 PM
Thank you! Those are good points and recommendations!
