12-04-2016, 03:37 PM
#21
This may well be a threat protector sleeve that was left for posterity during the build. It may have fit the anode rod port or possibly a propane port.
12-04-2016, 04:11 PM
#22
It came out of the pressure relief valve on water heater. Mine is still in place..
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
12-04-2016, 04:31 PM
#23
Found same item in my water heater. It was seated in the hot water relief valve, just stuck up in there within the threaded area. Valved looks like a hose bib with relief lever that allows hot boiling water to escape. Or can allow air into top of tank when plug is removed to drain.
Often wondered why it was there.
12-04-2016, 08:16 PM
#24
Originally Posted by Ford Idaho
I have that same water heater, that is like a rubber foam seal around the pressure valve and the tank plug.
It is 1/4" or a little more thick and soft to the touch.
It's plastic.
2018 Wilderness 2450FB
2021 Chevy Silverado 1500 3.0 Duramax 10 speed
2021 Chevy Traverse LT
2012 Dodge Challenger
If you get to thinkin' you're a person of some influence, try orderin' someone else's dog around.
12-04-2016, 08:29 PM
#25
Originally Posted by mike.t
It's plastic.
What OP posted is indeed, but the seal on the tank is foam or rubber foam and there is no place for the plastic to fit.
After looking mine over I do not believe the plastic is related to the WH.
12-04-2016, 08:35 PM
#26
FI, if you look at the pics I posted previously, with the green arrow pointing right at it, you can see the lip of the red plastic sticking out of the Temp & Pressure Relief Valve
Here it is again, this time circled in green:
 2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
12-04-2016, 09:04 PM
#27
Dragonship Captain
Maybe you need to circle it in a few more colors?
12-04-2016, 09:35 PM
#28
I did not notice that the second picture with the green arrow and red plastic had been added to the reply I quoted in full.
The plastic looks/looked to be to large to fit the pressure valve opening.
12-04-2016, 09:57 PM
#29
DW's 401(k) Plan
While we're trying to identify plastic pieces found behind doors, here's one I found today....
And that's exactly where I found it. Comments? It was in the fridge vent.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
12-04-2016, 10:03 PM
#30
What OP posted is indeed, but the seal on the tank is foam or rubber foam and there is no place for the plastic to fit.Not referring to a piece of foam! It goes INSIDE the relief valve.
12-04-2016, 10:04 PM
#31
Looks a bit smaller but what the hell they solved one may as well keep it going
12-04-2016, 10:41 PM
#32
That's another thread protector. I'd bet it went on the end of the solenoid valve that the copper tube and nut are now attached to. The Amish guy pulled it off, screwed the coppertube/nut onto it, and the lunch whistle blew. (I'd check that the nut is tight!  )
2011 Traverse LT, 3.6L, FWD
12-04-2016, 11:29 PM
#33
By golly Ollie i think ya nailed it.
Now
12-05-2016, 12:43 AM
#34
I drained this same model water heater a couple of weeks ago. I didn't see any parts that looked like that.
12-05-2016, 02:19 PM
#35
2015 Forester
Found the same plastic piece in my hot water tank area but it got too close to the heat and melted so just threw it out . . .
12-05-2016, 02:30 PM
#36
Had one laying inside door of our hot water heater too - tossed it!
I wonder if the guys that build em, read this stuff & laugh!
2014 Work & Play 30WRS
2006 Chevy 3500 Duramax
2001 Suburban 2500 6.0 (former tow rig, now just party wagon)
12-05-2016, 03:13 PM
#37
Found the same thing with the water heater. Originally it was to protect the threads on the pressure relief valve. Mine fell out after I flipped the pressure relief valve when draining the WH.
12-05-2016, 03:51 PM
#38
That's good. That means the Amish guy threw it away, like he was supposed to!
12-13-2016, 09:33 PM
#39
Dragonship Captain
It's the Elkhart Meth heads that leave them in.
