Old 10-22-2020, 04:48 PM   #1
Leprechaun 240FS Antenna Booster Switch?
Anyone know if the Coachmen Leprechaun 240FS (ours is a 2019) has an antenna booster switch? I can't find one anywhere and our dealer told us it didn't have one either. However when hooked into campground coax cable, our tvs are still fuzzy. I just wanted to confirm there isn't a booster switch hidden somewhere that I need to turn off.
wrbrown74 is offline   Reply With Quote
Old 10-22-2020, 04:53 PM   #2
bikendan's Avatar
If you have a roof tv antenna, then yes there's an antenna booster button.
Old 10-22-2020, 05:09 PM   #3
OK, if anyone has this same model leprechaun, I'd love to know where it is. I haven't found it yet.
Old 10-22-2020, 05:37 PM   #4
bikendan's Avatar
I moved your thread to the Coachmen Motorhome sub-forum. Hopefully someone there can better answer your question.
Do you know what the antenna booster wall plate looks like? It usually also has a female coax port.
Old 10-22-2020, 05:50 PM   #5
Thank you, sir. Yes, our old travel trailer had the antenna booster wall plate, but I can't seem to find anything like that in our Leprechaun.
Old 10-23-2020, 02:04 PM   #6
Look in the upper bunk. I don’t have the same model as you but my booster is there.
HAPP is offline   Reply With Quote
Old 10-23-2020, 02:41 PM   #7
mike.t's Avatar
https://www.manualslib.com/manual/10...page=35#manual
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
2012 Dodge Challenger
I was never taught not to like you, you did that!
mike.t is offline   Reply With Quote
Old 10-23-2020, 02:50 PM   #8
bikendan's Avatar
Originally Posted by mike.t View Post
That's the typical generic description.
The OP already said that they are familiar with the wall plate, they just don't know where it is in their rig. And that manual you linked is generic and WON'T have that information since it doesn't have model-specific information.
Old 10-23-2020, 02:53 PM   #9
mike.t's Avatar
Excuse me.
2014 Dodge Durango
Old 10-23-2020, 03:37 PM   #10
Holy cow...I cannot thank you guys enough!!! Behind the curtain in the bunk is exactly where it was. Beautiful resolution on the TV now...haha.
Old 10-23-2020, 03:56 PM   #11
bikendan's Avatar
Glad someone here was able to help you locate it.
On my previous Rockwood, the plate on the wall and easily seen.
My current TT has it hidden inside an upper cabinet.
Even within the same brand, the wall plate location can vary widely between their models.
Old 10-23-2020, 04:51 PM   #12
mike.t's Avatar
Glad you found it, some on here would rather boast, but most will point you in the right direction. Safe travels.
2014 Dodge Durango
Old 10-24-2020, 07:38 AM   #13
Does the "King" antenna system have an antenna booster system???
Jim in Halifax is offline   Reply With Quote
Old 10-24-2020, 07:53 AM   #14
bubbles's Avatar
If you're referring to a King Jack antenna then yes. The so called booster system is a panel that supplies 12Vdc via the coax cable to an amplifier within the antenna. Don't know of a factory installed over the air RV antenna that is not powered.
Old 10-25-2020, 12:48 PM   #15
Anyone know where this is located in a CC-33ik 5er?
Old 10-25-2020, 02:32 PM   #16
bikendan's Avatar
Probably should be asking this, in the Cedar Creek sub-forum, not the General Motorhome Discussion section.
Old 10-25-2020, 03:43 PM   #17
Sorry....never noticed that!!
antenna, switch
