Originally Posted by mab6987
Hi all,
As a newbie I’m wondering if I need to always place leveling blocks under the tires before dropping the auto levelers? I’ve watched so many videos on YouTube and some show using leveling blocks before using the auto levelers, others say just turn on your auto levelers and hit auto and your all set.
A little confused right now.
Thanks for any input
We've had a class A for about 8 years so I can suggest 2 or 3 things that work for us.
First I level manually not auto. When we arrive we level back to front then side to side with my wife using a short carpenters level on the mh floor as a guide.
Second We use off cuts from 2x8 's or plywood under the jacks if we suspect the ground is not firm . You can buy plastic blocks from Camping World for this too.
Lastly ( and to us most importantly ) we do not raise the unit and leave space between the tires and the ground . I carry pieces of lumber to put under a tire if leveling means any of them are going to be off the ground.
