Old 06-16-2021, 06:21 AM   #1
Domer
Overnight Stays - Unhook or Not?
Ok, a rookie question: we are about to embark on an extended trip and will be staying just one night at various campgrounds along the way. Our 2021 Coachmen Mirada will be towing our Jeep Wrangler, using the Blue Ox system. Is it necessary to unhook the vehicle when leveling the coach to extend the slides? Or is there enough play in the system so that's not necessary? Thanks for your help!
Domer1972 is offline   Reply With Quote
Old 06-16-2021, 07:47 AM   #2
It can stay hooked. The tow bar allows for quite a bit of movement and will be fine unless you are on a site so off level the rear of the coach would be several feet off the ground and that is extremely unlikely.
2020 Coachmen Mirada Select 37RB
2020 Ford Ranger
EZGo Freedom TXT Golf cart
DougW is online now   Reply With Quote
Old 06-16-2021, 08:12 AM   #3
Fully COVID-19 vaccinated
Depending on the size of your site, unhooking may be mandatory. Even if I don't unhook, I will lower my tongue jack to take weight off my truck. I will also lower my stabilizing jacks.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 06-16-2021, 08:33 AM   #4
Mr. Dan's Avatar
This is not a tongue jack/tow truck situation. This is a coach towing a toad.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 56; Booked = 52
Old 06-16-2021, 08:42 AM   #5
Regardless, the size of the site may require unhooking.
Old 06-16-2021, 09:11 AM   #6
If we are doing a 24 stop I always ask the camp personnel if itís ok to keep it hooked up. Next thing I do is survey the actual spot to see if itís a cement pad or one with soft ground. Then again this is a TT and not a coach towing a vehicle.
2019 Ram Big Horn 6.7 Cummins
2020 Rockwood Ultra Lite 2304DS
RobRockz is offline   Reply With Quote
Old 06-16-2021, 11:37 AM   #7
Domer
Thanks to everyone for the input. Most of our sites "claim" they are long enough, but certainly something to keep in mind. I just wanted to make sure there was enough "give" in the Blue Ox system to save me the trouble. But then the wife may want to do some shopping anyway...
Old 06-16-2021, 12:05 PM   #8
That alone will be your answer.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-16-2021, 12:50 PM   #9
If it's a pull thru site, I have had no problems not unhooking for overnight stays. If it's a back in site, it's nearly impossible to back the toad in attached to the coach!! So yes, different situations require different actions!
geneandjan is offline   Reply With Quote
Old 06-16-2021, 03:38 PM   #10
I agree. You definitely need to book pull thru sites. Backing it up with a toad is not advised. A pull thru site is almost always level enough that you don't need to unhook.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 06-16-2021, 04:22 PM   #11
rracer5's Avatar
X2!
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-16-2021, 05:09 PM   #12
rracer5's Avatar
X2!
Old 06-16-2021, 06:12 PM   #13
Dodge Guy's Avatar
For overnight I stay hooked up if it’s long enough. If not I make room. There is plenty of movement at the hitch to level the MH.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-23-2021, 06:24 PM   #14
NXR
NXR's Avatar
There is another consideration. What car are you pulling and what kind of power will you be hooked to?
If you are not plugged in to shore power and the generator will not be running continuously there is a chance that the car will suck battery power away from the motorhome or conversely, the battery in the car will try to backfeed into the motorhome.
My F53 chassis has the 7-pin connector wired hot to the motorhome even with the motorhome engine off. Without a diode in the charge line there car can have its battery drained by the motorhome. On the plus side, if I do have generator or shore power available, the motorhome's electrical system keeps the car's battery topped off.
If I leave my Equinox in tow mode it actually can drain the motorhome's battery without shore or generator power.
If I am overnighting without shore or generator power I'll disconnect the the umbilical cord between the car and the motorhome.
FWIW,
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 06-24-2021, 06:49 AM   #15
Domer
Thanks, NXR. We tow a Jeep Wrangler and use 50 amp power. We always stay at full hook-up sites so will have shore power, but this is good info should we find ourselves in a situation without shore power.
Old 06-28-2021, 08:37 PM   #16
Garrette's Avatar
I stay hooked up if possible but, I remove the key and lock the car and remove the electrical umbilical and the break away cable. I do not spare those items.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
