Closed Thread
Old 07-12-2023, 09:06 AM   #1
wmtire's Avatar
Propane won't refill- check that washer/grommet
bclemens has helped solve propane tank refill problems many times by simply pointing out to make sure the rubber washer/grommet is in place where the refill hose connects to the onboard tank. Many times this washer/grommet will stick to the end of a refill hose and get pulled out when the hose is disconnected....so the next time you go to refill, you will have problems. It is worth your while to keep notice of this and/or carry spares as several members here do, in case you are trying to get a refill at a place who may or may not be familiar with this problem. Not all refill places will have spares either. See pic below (credit Lvnthedream) for where this rubber washer/grommet is located.
Originally Posted by bclemens View Post
That depends on what the problem is.
Lastly make sure the rubber grommet is in tank fill. I see those get lost often.
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but Im too Pora-Pora.
wmtire is online now
Closed Thread
check, propane
