Originally Posted by SeaDog
You don't have to become a prisoner of your RV cover in the winter. If you are concerned about things breaking due to freezing and removing your cover a few simple steps will resolve that. lift the bottom section of your cover in the area of the furnace inlet and exhaust well up away from that area start the furnace and let the heat build don't rush let things get warm and then remove the cover.
I don't know. Might not be workable for me.
My 2 cents for the OP would be to not cover if getting out of Dodge quickly is the main goal.
My adco designer series cover doesn't offer enough slack or the ability to create enough open space next to the furnace exhaust outlet without compromising cover stability in the wind - it probably won't blow off but will reposition itself in the wind and likely in a way to burn a hole in the cover from the exhaust heat - or worse.
