Old 12-24-2016, 04:29 PM   #1
grumpy0374's Avatar
Routine Maintenance on Long Trips
Wife and I and another couple in their own class c are planning a long, 3 month trip across US, up into Canada, Alaska, then back east thru Canada. Total will be around 12,000 miles.
I am very picky as to routine and preventive maintaince and will have most of the "heavy" stuff done before we leave (brake, coolant flush and tranny fluid change).
Question relates to a Ford based class c, V-10...
What do you who have taken longer trips do as far as oil/filter changes. I do my own at home using Ford filters and synthetic oil. On the road, it wouldn't be a problem to carry what I would need to do it myself 2-3 times (every 4000 miles), and I'd rather do it myself so it's done right. Do any of you do your own changes while on the road, or do you seek out proper (Ford) dealers to preform the work?
Other couple also has a Ford based class c and same would apply to them...we're both DIY at home.
Thanks,
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 12-24-2016, 05:38 PM   #2
dan-nickie's Avatar
On my Ford class c, I could change the oil filter without having to jack up the rig. If it's important, buy a cheap drain pan and disposed of it when you're done.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-24-2016, 06:00 PM   #3
grumpy0374's Avatar
Yeah, I can easily get under the front and I have a Fumoto valve installed, so draining is no problem. Just wondering if anyone has run into problems with park owners. I realize that it would only be appropriate to ask the owner if it's ok.
Just wondering what you all had done in your travels..
Grumpy
Old 12-24-2016, 06:09 PM   #4
Retired May 2015
Most places we stay don't allow oil changes. I am picky too. I have brought my own oil and filters and gone to a Jiffy Lube or similar quickie place, then I stand outside the bay and watch them like a hawk. I also tell them no tires or air filter as they want to upsell and/or change your tire pressure. It's a little expensive for labor only but you don't have to hassle with oil disposal, etc.
Dennis & Carol
2005 Bulletproofed F-250 6.0 Crew Cab/Long Box
2007 Forest River 38 ft Sierra
Retired 4/30/15
Traveling with new pup "Sammie". Boston Bull Terrier/chihuahua (Bo-huahua). Pronounced Bow wow wow.
dwcjb is offline   Reply With Quote
Old 12-25-2016, 12:33 AM   #5
If you are confident you could do an oil change at a rest area then drop the used oil off at most parts stores which have recycling for this. I would line the drain pan with a trash bag to cut down on having to clean it afterwards. Carry a few empty jugs to put the old in and save the new ones to use for the next change plus carry extra oil and filters for extra security. Shouldn't really take you more than 10 minutes to do.
Davidjeff is offline   Reply With Quote
Old 12-25-2016, 04:32 AM   #6
Glad I'm not that picky. On my 7,900+ mile cross country trip, I just had the oil changed while in Las Vegas, NV. I wasn't about to crawl under my truck and change it while on the road. Much easier, and less fuss by letting it be done.
Atlee is offline   Reply With Quote
Old 12-25-2016, 07:01 AM   #7
I am Not going to change the oil at a CG or Rest area! If I can't find a service center within + or- 500 miles of needed change time I have bigger issues ! We are on Vacation not a Pit Crew! Youroo! !
Old 12-25-2016, 08:43 AM   #8
KyDan's Avatar
What HE said! Plus why not stretch it out to 6000 miles between changes and you'll only need to pay the man once on the road. Change it yourself when you get back.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 12-25-2016, 08:52 AM   #9
Crusadernoob's Avatar
I would change it myself at an overnight stop, no big deal. But I would change it at the halfway point, 6,000 miles on a good running engine with today's oil is no problem.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 2
Crusadernoob is offline   Reply With Quote
Old 12-25-2016, 09:31 AM   #10
W5CI's Avatar
Why change at 4000, If you are really concerned pull into a Ford dealer along the way. Or a SpeedCo service center here in the USA
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 12-25-2016, 10:47 AM   #11
I planned to change our oil myself but almost all campgrounds forbid any maintenance.
I've had mine changed at a Jiffy Lube while on a trip. Call ahead because some quick change places, and even Ford dealerships, don't have a bay tall enough for a motorhome. It cost $65 which I thought was too much since I supplied the oil and filter. They apparently don't put much value on their own oil and filter. The guy said my oil and filter were much better that theirs.
I changed it once in a campground. I had a large ground cover in case I spilled any, poured the oil into jugs, put the filter and oily drain pan in a trash bag, and properly disposed of everything when I got home.
On our last long trip, I ran it beyond my normal 5000 miles. I changed it when we got home with 5100 miles on the oil.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 12-25-2016, 01:37 PM   #12
Agree! I try to change oil on our 6.0 Chevy every 3000 miles, but I'm not going to worry if it goes beyond 4,000 or 5,000 miles if the oil looks clear.
gfarmcafe is offline   Reply With Quote
Old 12-25-2016, 01:45 PM   #13
Pioneer RV Park in Whitehorse has a do it yourself pad for oil change. $5.00 That should be about a 1/2 way point for you.. We did ours there last August.
We camp on earth with a Sun Seeker 2300
yworrydog is offline   Reply With Quote
Old 12-25-2016, 01:48 PM   #14
rvrobocop's Avatar
In the Baltimore metro area it is tough enough to get a Ford truck dealer to take you in let alone a Ford dealership that if they have the ability (or desire), you need to leave it overnight. Private shops the same. I hope there might be others out there more accommodating. I have resolved to at minimum change my own oil to save a few bucks and not have the need to go in every 4000 miles. On the road I suspect the issue would be getting rid of the used oil conveniently.
rvrobocop is offline   Reply With Quote
Old 12-25-2016, 02:01 PM   #15
Help me understand the concern over this. I have done my own maintenance for 50 years but while I am on the road I do not even hesitate to use the dealership for my Powerstroke or my new Duramax diesel. I watch what they do in the bay and have always been happy. The cost is insignificant compared to what you spend for travel and wear and tear.
palmetto rogue is offline   Reply With Quote
Old 12-25-2016, 02:26 PM   #16
I love synthetic oil and on most vehicles I run 100,000 miles between changes with never an engine problem. Oil filter gets changed at factory specified intervals and oil gets added when low but that's so seldom that I only check level monthly.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 12-25-2016, 02:52 PM   #17
When we were in Alaska, we stopped at an auto parts chain store, I think it was an O'Reilly in Fairbanks and asked if we purchased oil and filter from them if we could change it in their lot. They agreed if we used the area on the side. Other people were there working on their vehicles and one of them even took our used oil for a waste oil furnace. Other places we stopped or called said we would have to wait possibly hours for the service to be done. It is a tight fit to get to the filter under our Sunseeker 2500TSC but if you put the front wheel up on a pad, it is easy.
TSman is offline   Reply With Quote
Old 12-25-2016, 03:02 PM   #18
Do,you mean 10,000 miles
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 12-25-2016, 03:27 PM   #19
grumpy0374's Avatar
Thanks TSman. That is the best idea I've seen. Didn't even think of that option.
I have NEVER used ANY quick lube. Refuse to let an 8 buck an hour kid do work on an 80 grand motor home...wouldn't let em change the oil in my lawnmower.
Everyone has their own preference as to what and when, and I have followed a 4-5 thousand mile change with synthetic and filter for years and years, and will continue. I chose 4 thousand as, to me, it's preventive maintaince, and I do it myself so I know it's done right.
Grumpy
Old 12-25-2016, 05:11 PM   #20
Mobile One was tested in taxis in NYC, considered the worst treatment of an engine. As long as the filter was changed at factory specified intervals, the oil lab tested as lubricating properly and engine wear was within new specs at 100,000 miles. Many engines won't break in properly on synthetic because there is almost no wear. You can change synthetic oil anytime you want but mostly its a waste of time and money and trashes the environment. Vehicle manufacturers have to warranty their engines and call for absurdly frequent changes. IMO. All I'm suggesting is that for synthetic oil users, you can enjoy your trip and change it when convenient.
William & Sara
