Old 03-23-2017, 10:44 PM   #1
Kenny kustom's Avatar
Spare tire class C.
I found a spare tire under my isata, but haven't located a jack or anything else..
( haven't really looked that hard)
What does everyone use to replace a tire?
Roadside assistance?
Big bottle jack?
2017 Dynamax Isata 4
Old 03-23-2017, 11:35 PM   #2
Do you have sprinter. It's in the floor on the passenger side.
Scotty33 is offline   Reply With Quote
Old 03-24-2017, 01:09 AM   #3
wvufan1958's Avatar
"How about Ford E-450 Super Duty" ... tire is in the back under rear of the rig. Haven't found jack yet. ??? Thanks. Tony
wvufan1958 is offline   Reply With Quote
Old 03-24-2017, 02:22 AM   #4
sgtlm17's Avatar
I have a Forester 2801 on an E450. I have a spare under the rear of the coach. I was told it doesn't come with a jack because it is assumed road side service will have appropriate equipment to change tire. Typically consumers are not expected to change tire on these big dually. The tire is so you aren't stranded with no place to get a proper tire replacement.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 03-24-2017, 05:07 AM   #5
grumpy0374's Avatar
Take it from one who knows, and has changed tire/rim on a class c.
To do it right, and not break your back doing it,...
Get a 20 ton bottle jack, regular hight, not the "shorty" version. Anything smaller will just make it harder to lift. Don't need to get fancy...I use one from Harbor Freight...less than 40 bucks with one of their coupons.
Forget about using a manual lug wrench. Very hard to break nuts loose, and tighten them. You'll break your back.
Get an electric 1/2 inch drive impact wrench, or a battery powered 1/2 inch drive impact wrench.
Kobalt brand at Lowes have the best and highest rated for the money.
Electric is rated a 350 ft lbs, and if on the road you can power it via the genny.
The 24 volt battery Kobalt Max, what I use, is rated at 600 ft lbs of torque. It easily backs off and tightens lug nuts.
Using the tools I listed, will make it alot easier to change a flat, if necessary. I'm 67 and have no problem doing it. If all I had were a manual lug wrench, I wouldn't even try.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 03-24-2017, 05:16 AM   #6
World Wide Wanderer
wahoonc's Avatar
What Grumpy says! I am super lazy though and actually thought about using my Bigfoot stabilizers to get the corner off the ground...
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-24-2017, 05:21 AM   #7
Sprinter is class B
Old 03-24-2017, 05:23 AM   #8
Got it!! Bottle jack and the dewalt impact from the toolbox!
Old 03-24-2017, 09:07 AM   #9
RedLdr1's Avatar
As well as tools I suggest you look carefully at the spare on your rig. FR's placement, and attachment, of the spare tire under our GTS made me using the spare highly unlikely.
My wife bought me a Roadmaster Spare Tire Carrier and it is well worth the money if you are even thinking about doing your own tire changes. It took both my son and me to get the spare down and out from under our GTS to mount it on the Roadmaster. BTW you'll need tools to drop the spare... That was in a storage lot...I can imagine just how fun it would be on a rainy, muddy roadside...in the dark.
See Here at e-trailer for some better pictures and a video. It isn't cheap but it works well and does not interfere with attaching our TOAD. Click on my Registry and you can see a picture of our rig with the Roadmaster...
Wayne and Christine
2021 R-Pod RP-192 with OEM Solar
2020 Ford Expedition Platinum 4X4, 3.5L EcoBoost, 9,200# Heavy Duty Trailer Tow Package with 1524# Payload
RedLdr1 is offline   Reply With Quote
Old 03-24-2017, 09:23 AM   #10
Spare tire class C.
I'm young.
All I need is the crank handle and drop it down.
I can crawl under and grab it.
I even relocated my spare on my fifth, to under the rear of the unit, from the basement.
Old 03-24-2017, 12:11 PM   #11
rvrobocop's Avatar
I've had 3 flats on my Sunseeker, 2 of which were on inhospitable and unsafe sections of Interstates. The third was actually in my driveway. AAA and the NJTPK tire guy were the necessary choices at the time. However, I've been mulling over having the option of changing it myself for 6 years if need be and Harbor Freight and Lowe's are fun to buy things. Grumpy, you pushed me over the edge!
rvrobocop is offline   Reply With Quote
Old 03-24-2017, 12:34 PM   #12
RETIRED AND LOVING IT
n-e-d's Avatar
Wayne's right the spare tire on my E450 was a PIA to remove. I put mine in the rear compartment to make it easier on me if I couldnt get service and I had to change it. I dont know about the Isata but on my sunseeker theres no crank to lower it and its chained and bolted .
Mary and Me 😷😷 Stay Safe
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT "Red Roamer"
"I am in the prime of my decrepitude"
n-e-d is online now   Reply With Quote
Old 03-24-2017, 12:35 PM   #13
sgtlm17's Avatar
How do you lower and remove it from the sunseeker
2011 Jeep JK Toad
Old 03-24-2017, 01:03 PM   #14
n-e-d's Avatar
Freed safety chain that was wove in and out of the handholds, put blocks to support one side and loosed nut holding it up finished taking off chain and I let out the nut holding it up. All on my back under the chassis. There had been threads about using E450 van spare tire cranks from Ebay on the forum but I have always carried my pickup spares inside or covered and the 2650s has a large pass thru storage in the back
2015 Jeep Cherokee
Old 03-24-2017, 01:04 PM   #15
A32Deuce's Avatar
I made my own spare mount and use a small floor jack to lower it. All the tire changing tools that are for an E450 I found on ebay and carry under pass seat.
A32Deuce is offline   Reply With Quote
Old 03-24-2017, 01:28 PM   #16
Spare tire
Have done my share of roadside tire changing. Now call roadside assistance, safe spot, get in TT and watch tv while waiting. Too old for stress. 👍
pdqparalegal1 is offline   Reply With Quote
Old 03-24-2017, 02:12 PM   #17
The isata has a crank to lower it.
Just like most pickups.
Although, I think the coach comes with 5 years of roadside assistance.
Old 03-24-2017, 03:45 PM   #18
grumpy0374's Avatar
In addition to my "tools", I do have roadside assistance. To me, it for an emergency breakdown, ect. To me, a flat tire is not an emergency nor a reason to call for help. I can, will, and have changed a flat.
And, for those of you who have roadside assistance, but haven't used it yet, it can sometimes take hours for someone to respond. And, in many areas, your carrier may not even be able to find someone to respond.
If you get a front flat, yopur not going anywhere, no safe spot. Your going to sit on the side of the road until your roadside assistance pulls up, or some passerby, like me, stops to help. Done that 3 times in the past 2 years.
So, you take your chances, or be prepared, or you pay the piper.
Grumpy
Old 03-24-2017, 03:46 PM   #19
Originally Posted by Kenny kustom View Post
Sprinter is class B
No, class C.
Ps- getting the spare tire on/off from under the chassis is not an easy task. Auto Club & tire shop said it was the most difficult set- up they've seen.
mtnlvr is offline   Reply With Quote
Old 03-24-2017, 03:58 PM   #20
Originally Posted by mtnlvr View Post
No, class C.
Sounds like a challenge !
I'll post a video when I get back from spring break!
class c, tire
