Old 11-13-2012, 06:39 PM   #1
Iggy's Avatar
Tire Rotation - Michelin XRV 235/80R22.5
When would you consider rotating tires?
Miles?
Age?
Wear pattern?
What have you done in the past?
NEW 2021.5 GT5 34H5 (2/8/21)
2012 Georgetown XL 378TS (SOLD)
Old 11-13-2012, 07:42 PM   #2
VinceU's Avatar
Miles?
Age?
Wear pattern?
What I' seen in the past few years, many bloggers recommend not to rotate due front to back yires do not wear the same and you should never mismatch duals. Side to side is no good because most radials are not suggested to rotate backwards once broken in (some never). Therefore the answer do not rotate and maintain proper pressure, they will last a normal rubber life 5-7 years. Note the circumference of these tires allow less than half the road contact of auto tires per mile. My last unit was 26,000 miles but 7 years old at renewal.
