Old 08-15-2019, 06:14 PM   #1
Senior Gold Member
rthomaslyons's Avatar
Washing (Cleaning) the front of a Class C
We all know that the washing (Cleaning) of the front of a Class A and C motorhome is a big job but Class Cís have there own set of difficulties with the overhang and protruding front end. Has anyone come with with a way of getting at this area so the bugs can be scrubbed off?Click image for larger version
ID:	212479Click image for larger version
ID:	212480Click image for larger version
ID:	212481Click image for larger version
rthomaslyons
2019 Sunseeker 3010 DSF
rthomaslyons is offline   Reply With Quote
Old 08-16-2019, 08:55 PM   #2
Garrette's Avatar
I have always had this problem. I would take an extension ladder and put pool noodles to pad the arms but hated doing this.
I purchased the Shurhold yellow brush with extendable pole and the angle adaptor and now washing the front cap is a lot easier from the ground. They are a lot better than the the carwash brushes.
Underneath the cap I use a short carwash brush and just get wet. I also use a short step ladder to wash that area between cap and roof. I use a long skinny appliance coil brush with a cloth wrapped to get this area. Again from the short step ladder.
Now waxing is a whole different story. I use a car wash/wax product. Works for me.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-17-2019, 12:45 AM   #3
I don’t own a RV. But I wash my truck and cars with a foam cannon.
https://youtu.be/POTN4A-9GzA
Ron750 is offline   Reply With Quote
Old 08-17-2019, 03:30 AM   #4
Senior Gold Member
Washing Class C
It’s not the washing per se thats the main problem with cleaning the front of Class C’s it cleaning the dead bug guts off the hard to reach front. Short of standing and or kneeling on the hood to get the overhang it’s very hard to reach to clean the bugs off. Their guts are like superglue.
Old 08-17-2019, 05:14 AM   #5
DW's 401(k) Plan
DaGrinch's Avatar
.... and getting the inset areas around the clearance lights... GEESH! Short of laying on the roof, it's practically impossible.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 08-17-2019, 05:14 AM   #6
Many bikers use 50/50 mix of hydrogen peroxide and water to remove bugs. I use Original Bike Spirits. Itís an inexpensive spray wax and cleaner. Itís the formulation of the original Honda Spray Wax and Cleaner, which was reformulated about ten years ago.
Old 08-17-2019, 12:29 PM   #7
KNMIB's Avatar
We have a 12 ft ladder and I can do 70% from the sides and DW does the middle with me holding the ladder. We also us an automotive long reach brush. I also use Mcquirers liquid wax which helps a lot to keep bugs from sticking. Did 3 months out and clean up wasn't bad.
KNMIB is offline   Reply With Quote
Old 08-17-2019, 01:13 PM   #8
Senior Gold Member
Originally Posted by rthomaslyons View Post
Itís not the washing per se thats the main problem with cleaning the front of Class Cís it cleaning the dead bug guts off the hard to reach front. Short of standing and or kneeling on the hood to get the overhang itís very hard to reach to clean the bugs off. Their guts are like superglue.
ID:	212669Click image for larger version
ID:	212670 this what I currently use a folding ladder made into a portable scaffold. It slows me to reach most of the front up to the running lights but underneath near the cab is still tough to get at without climbing on the hood of the MH
rthomaslyons
Old 08-17-2019, 01:17 PM   #9
Deputy Sheriff (Ret.)
Smile Bugs
On the front of my Cedar Creek Fifth wheel the bugs are horrible. I found a product called Bugs N All. Just wet the surface and spray with Bugs N All and you can literally see the bugs melt away. You can wait just a few minutes then take a long handle brush and wash. This product does not hurt graphics, wax or paint. I also use it on windshields, grilles and mirror heads. I won't be without it. Try it, you won't be disappointed. You can only buy online.
Mike and Mary in Central Arkansas
2017 Cedar Creek Silverback 35IK
2017 RAM 3500 Laramie DRW, Aisin Trans, 3.73 gears
Shih Tzu traveling baby. Mya age 3
Mike522 is offline   Reply With Quote
Old 08-17-2019, 02:49 PM   #10
I do lay on the roof. I use Rejex several times during the season, which helps to keep them from sticking as badly. On the road, I use Wash Wax All - ladder on sides - lay on roof to get the top. I have not found an easy way. At the truck stop, .I use the long pole with windshield washer fluid.
Nothing beats washing with the brush on the extended pole.
AbdRahim is offline   Reply With Quote
Old 08-17-2019, 03:09 PM   #11
Bug removal
I use a Home Depot spray bottle and straight ammonia on the from of my Wildcat. The ammonia dissolves the glued on bugs after about one minute of soaking. Then just use a brush to finish the job.
cmar273225 is offline   Reply With Quote
Old 08-17-2019, 05:37 PM   #12
Bob2800
For the parts you can reach. Dampen a dryer sheet with water and use to scrub the bugs off and rinse.
Bob2800 is offline   Reply With Quote
Old 08-17-2019, 07:24 PM   #13
jbrosecity's Avatar
I use a long handled windshield bug scrubber and squeegee. I get a bucket HOT water, dip it in and go over the front of my Forester once to loosen em up, then go back again with another hot water dip and scrub at the stubborn ones. The trick is to do it at days end when they are fresh. Kinda like a religious practice... When they are fresh they are not hard to get off this way. When I am done, I wrap my chamois around it and dry it and then I do the hood and grill with a hand scrubee pad
2019 Forest River Forester 3041DSF
Ford E-450 Chassis
www.Wind-seeker.com
2018 Vanleigh Vilano 375FL
www.Wind-seeker.com/vilano
jbrosecity is offline   Reply With Quote
Old 08-18-2019, 10:35 AM   #14
I bought this kit and it works like a charm. No climbing a ladder or scaffold.
https://smile.amazon.com/Aero-Cosmet...s%2C262&sr=8-4
HAPP is offline   Reply With Quote
Old 08-19-2019, 09:41 PM   #15
I got it off of their site no shipping. Love the wash and wax!!!
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 08-26-2019, 02:37 PM   #16
Long handled extendable brush, think ours goes to 12'. We use Rain X Bug and Tar remover in gal jug, and the Rain X Bug and Tar Defense in spray bottle. Spray it on, let soak and then rinse anscrub off. The left-over Rain X product keeps them from sticking so hard in the future.
2019 Sunseeker 3010DS
160w/9A roof top SOLAR
Playmaker DISH w/ Wally
Blank is offline   Reply With Quote
class c, cleaning
