Old 10-02-2020, 04:27 PM   #1
Water Pump Questions
Seems that my water pump is having a problem pulling from the fresh water tank. It works well if I use the winterization valve and pull water in from a bucket of water, but slows to a trickle if I switch the valve back to the tank.
I've tested the pump in isolation and it seems to work just fine.
When I pull the cap off of the intake side of the pump (circled in red above) to clean the filter out, I was surprised that there wasn't a flow of water coming from the the fresh water tank. Possible that this indicates an issue upstream of the pump?
blanksky is offline   Reply With Quote
Old 10-03-2020, 07:14 AM   #2
SeaDog's Avatar
In most installations the potable water tank does not provide positive suction pressure to the pump so pulling the suction strainer cap will not allow water to flow. I would suspect you may have so debris in the tank partially blocking the suction line. I think I would try to back flush the suction line to clean anything out with the tank drain open and see if that solves the problem.
Retired Navy
2016 Flagstaff 26 FKWS
pump, water, water pump
