Old 03-04-2020, 04:04 PM   #1
18ec water pump
I recently purchased an 18ec. I haven't had a chance to do much with it since it's winter, but I am wondering where the water pump is. I assume it's under the bathroom sink since I don't see it anywhere else. I would appreciate it if someone could tell me for sure.
thanks
Wayfat is online now   Reply With Quote
Old 03-04-2020, 04:34 PM   #2
most of the time it will be next to fresh water tank for water coming from the tank to all the camper
cfo111 is offline   Reply With Quote
Old 03-04-2020, 05:06 PM   #3
cavie's Avatar
Usually and water pump location are not used in the same sentence in the RV world. They are hidden everywhere. Many times found BEHIND wooden panels held in place with #2 square drive Screws. Best way to find it is turn the pump on and listen. Turn a faucet on and walk around the inside and outside And listen for it. I can hear mine at the kitchen sink and it is in the pimp is in the pass thru storage area behind wooden panels which I removed.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-05-2020, 10:20 AM   #4
In this case I would say your tank would be close by because if you have a bathroom sink and a toilet and shower it would need to feed it also from the tank.
Old 03-16-2020, 10:07 AM   #5
It’s under the bathroom sink, you have to remove cover under sink.
Dcan is online now   Reply With Quote
Old Yesterday, 07:59 PM   #6
Thanks, I did find it under the bathroom sink. I tore the sink out and I am building a vanity with doors so I don't have to take the panel off when I winterize. It's going to be much more user friendly and I will even get a little extra storage out of ot too.
Old Yesterday, 08:09 PM   #7
Water pump
I would like to see pictures when you finish.
Old Today, 02:17 PM   #8
I will try uploading some pictures. I think it turned out well. I even managed to get a small shelf inside. When you camp with 2 women you need every inch of storage you can get.
ID:	225899   Click image for larger version
ID:	225900   Click image for larger version
ID:	225901   Click image for larger version
Old Today, 02:42 PM   #9
Pump
Looks great, you have skill.
Old Today, 03:01 PM   #10
Thank you. I had my shate of obstacles, like usual, but afterca week it's finally done.
pump, water, water pump
