Originally Posted by rflynnmtw
I have not pulled the panel where all the fuses and breaker are. Could it be behind there?
Yes most are.
But, most also have access to the reverse polarity protection fuses from inside the power distribution panel door. These fuses are on the DC output side of the converter and if blown, would keep the converter from charging the battery(ies). Also, do you have a battery disconnect switch?
