Old 05-22-2022, 08:54 PM   #1
Does 2019 19WCB have inverter???
Hi,
I am considering adding a solar setup to my rig and am curious if the 2019 19 WCB actually has an inverter and or a transfer switch installed from factory?
In order to add the solar setup I want, I would like to put the shore power/generator feed into the Solar Controller and then connect the controller to the panel, by passing the factory "converter".
Thanks in advance for your assistance and insight.....
dabeertender is offline   Reply With Quote
Old 05-23-2022, 06:54 AM   #2
SeaDog's Avatar
Are you sure you want to configure your solar controller that way?
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-23-2022, 11:43 AM   #3
Originally Posted by dabeertender View Post
Hi,
What makes you think that there is an inverter and transfer switch installed? Unless you have a 12v or residential refrigerator, inverters are not standard.
As to solar, I have no experience.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 05-23-2022, 01:08 PM   #4
Flybob's Avatar
The converter will charge the battery at a much higher than a simple solar controller and a few hundred watts of panels. In addition, I have not seen an RV solar controller that will accept 120VAC input.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
inverter
