And of course at 7k feet and inside temperature was 39*. I checked the sail switch, it moves when the blower comes on and if i held it forward position and tried to turn on blower, the blower would not come on.I did remove the igniter and clean it, it does fire when asked to, the gas isn't turning on. I tried numerous times thinking the fuel wasn't getting to the unit but the water heater works and the 3 burner stove/ heater
works fine. BTW, 3 burners lit with a window cracked heats up the garage a bit.
Anything else and to properly check the unit i have to remove it from the coach. Very little room between bed and wall to pull unit out. I see the fuel line needs to be disconnected and maybe a few screws into the floor holding it in position? Does the unit attach to the outside vents or just slide into them.
