This one will be difficult to explain.... But here it goes.
I want to mount these on my floor. The plate stays and the arms are removable when not in use.
https://riskracing.com/blogs/news/be...e-buyers-guide
Watch the video to get the full understanding.
I plan to mount them offset (forward to rear) over the axles to avoid having the handlebars of 2 moto's side by side (Dual Sport moto's - aka street legal dirt bikes). Ultimately I would like to tap into the metal studs that run width-wise of the camper to provide maximum strength. I love these mounts because they eliminate the need of a front tire keeper and the need for straps running in 20 directions drastically compressing the front suspension. The plates can be mounted with either 8 counter sunk wood screws or 8 countersunk bolts with washers and nuts or a combination of the two. My huge fresh water tank (with mounting wings) is right in the spot where I will need to mount these. The studs are 16 inches on center. There is about 2 inches of clearance between the tank and the bottom of the floor (no worries of penetration of the tank). My problem ... I can't PRECISELY (without drilling multiple pilot holes) determine where these 2 inch studs lie from within the RV. I am PRETTY CLOSE.... within a half inch ... but I want to be exact.
The existing tiedown loops (outer 2) are not mounted into the beams and are screwed into plates that have been added for support. The center one is screwed into the wide metal place running down the middle of the underside.
Thoughts on how to accomplish this task?
I'm worried that if I proceed and use the measurements I have now which are mostly close I will either deflect and miss or will only catch the rim of the beam. If I go with the screws and forget about the beam I thought about pre-drilling the holes and filling with liquid nails as I insert the screws.
