The Work and Play trailers built with FRP have a stout frame underneath them. At least my 2007 34FK does. If a structural failure does occur in the wall, I think it will be rather gradual and very noticeable. Certainly enough time to get it home.
As opposed to the semi trailer designs of the 1980's and early 1990's with this construction technique which are "frameless", that is the walls, floor and roof all work with one another to provide the needed strength to carry the load. When one of the 3 fails, it is catastrophic.
It got bad enough that after Jan 1997 GM refused to allow any FRP trailers to be unloaded or loaded at a GM plant because of numerous failures, unknown rotten walls gave way as a loaded fork lift went into the trailer and the floor would buckle.
