Old 02-18-2020, 05:54 PM   #1
Ramp door hinge bolts wet and rusty
Installed extra spring, hinge bolts wet and rusty were is water getting in bolt holes? Plan on replacing all the bolts. Bolts loosened fine on one hinge tried another couple just spin. How do you hold inside part so you can loosen bolts? Thanks again
Dcan is offline   Reply With Quote
Old 02-18-2020, 06:02 PM   #2
SeaDog's Avatar
are these bolts or screws? If they are bolts thru a nut plate then the nut plate has broken loose you might try placing a screwdriver or something you can wedge under the head of the bolt/screw and pray up as you turn the bolt/screw that may cause it to bit and come out.
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-18-2020, 06:41 PM   #3
Recent thread with a similar problem.
https://www.forestriverforums.com/fo...le-201147.html
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 02-18-2020, 08:15 PM   #4
Hinges
The hinges are at the bottom, seven hinges, six springs now seven. The bolts have Phillips head, but are bolts. Twenty one bolts.
Old 02-19-2020, 12:55 PM   #5
DouglasReid's Avatar
Replace with Stainless Steel hinges and hardware to prevent a reoccurance.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
bolts, door
