Originally Posted by ImKrisK
Titan Mike, I thoroughly enjoy your insightful replies on this forum......obviously a voice full of wisdom and experience!!!
I'm an electrician, but I've never seen that Camco 30/30 Twistlock 90 deg 'dog-bone' connector.....I'm thinkin' I gonna have round me up one of them!
Question for you, tho......was the female 90 deg connector to the RV oriented correctly when attached and locked? (in other words, so the cord end was hanging down, towards the ground?). Do you suppose that all standard RV mounted twistlock connectors are oriented the same????
It would suck if you attached the 90 deg connector to the coach, and the cord was pointing up (or even at 10:00 o'clock, or 3:00 o'clock......)
Thanks again for your advice, and wisdom!!!
The 90 degree " dogbone" perfectly aligned with the Furion inlet. To insert I have to rotate slightly counterclockwise, insert then lock in clockwise direction. At stop the cord is directly at 6 O'clock. I have every reason to believe at least the Furion receptacles are clocked the same and would guess the Marinco units would be the same.
I've greased up threads on coupling to power cord with silicone grease to keep them waterproof so connection to 90 degree portion is as watertight as possible. I see a lot of rain
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
