Old 03-27-2017, 06:40 AM   #1
Blktegra's Avatar
Valve stem diameter
I need to replace a valve stem on my ULSBS, it has the aluminum rims. Does anybody know what size the valve stems are so I can buy them before I go to the shop to dismount the tire? It's my friends Atv shop, he has a full size tire machine but isn't sure if the stems he has will work.
2013 Ultra work and play 275ULSBS
Towed by 98 2500 Dodge Cummins hand built by me
Polaris RZR couple of Ski Doo REVs
Blktegra is offline   Reply With Quote
Old 03-27-2017, 06:52 AM   #2
wmtire's Avatar
As far as the stem hole diameter, I don't think I have seen any FR trailer wheels that didn't have the .453 hole.
Assuming you are wanting to use the metal clamp-in stems (not the rubber stems), then the following will apply. I use the word assume, as it's not clear from your OP what it is exactly you are doing, as you said you are only replacing a stem. If just replacing a rubber stem, it's the .453 size.
Now if you are going to use metal clamp-in stems, The problem that many are encountering however, is that FR is using some aluminum wheels that the valve stem hole is positioned too close to the rim lip/flange that a regular TR-416 clamp-in type stem will not work. If you have this type of rim, then a TR-428 will do.
Actually a TR-428 will work in either application. if you hole is closer to the rim flange or not. This may be the safer one-size-fit-all solution.
Here are some previous links:
http://www.forestriverforums.com/for...tml#post535157
and one from just last week, make sure to read the last post from Bob there.
http://www.forestriverforums.com/for...ml#post1447964
2011 Flagstaff 831 RLBSS
Old 03-27-2017, 09:25 AM   #3
Blktegra's Avatar
Sorry should have clarified better. Noticed last year all were cracking probably from the sun. Came outside the other morning and had a flat tire, stem wouldn't hold any more air. So I'm going to change all four and buy some wheel covers for storage.
The info u have me is what I was looking for. Thanks
Old 03-27-2017, 09:30 AM   #4
SeaDog's Avatar
Good info WMTIRE
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-27-2017, 09:38 AM   #5
wmtire's Avatar
How much air are we talking about? If using just the normal TR-413 encased rubber snap-in stems, they are usually only rated to 60-65 psi.
Old 03-27-2017, 11:38 AM   #6
Blktegra's Avatar
No Air, totally flat. As I filled it back up with air it was pouring out the stem by the rim. Pressing in hard on the stem it would stop pouring out. All 4 of them look dry rot all cracked up. It's only a couple years old I've never seen stems look like that. I have 4 trailers at my house, one I bought brand new in 2005 and they sure as heck never looked like these
Old 03-27-2017, 11:41 AM   #7
wmtire's Avatar
I understand, and just for the record, you aren't using any kind of wheel/tire cleaners on them by any chance. Petrochemicals are a big time no-no in my business.
Old 03-27-2017, 12:08 PM   #8
Blktegra's Avatar
No I haven't used anything but soap and water on the entire hauler. A good friend was the previous owner for a year and he never washed even once. The fact that all 4 look like poop would lead me to believe just cheap materials or what you questioned about harsh chemical cleaners
valve
