Old 04-18-2016, 05:17 PM   #1
Battery Disconnect
Hello,
First time on posting here.
My question is on the appropriate position of the battery disconnect which in my camper is located next to the converter at the floor level under the refrigerator. My camper is a 2013 Rockwood Roo 23SS. The switch is silver and is a push/pull type.
I'm to understand this switch is to be used when the camper is not in use so that the battery does not get drained. Question: To disconnect the battery is the switch pushed in or pulled out?
Any other information on the proper use (do's and don'ts) of this switch would be much appreciated.
tduff is offline   Reply With Quote
Old 04-18-2016, 05:30 PM   #2
SeaDog's Avatar
with you rig unconnected from shore power and the lights on turn or push the switch and you will get your answer. I do not know your unit or switch.
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-18-2016, 06:01 PM   #3
The switch is like an old fashioned car headlight switch. Pull out to turn on. Push in to turn off
beachcamper is offline   Reply With Quote
Old 04-18-2016, 07:02 PM   #4
So you want it out when you're using your TT and you push it in when you aren't. (Otherwise your battery will drain and be dead next time you want to use it.)
2011 Traverse LT, 3.6L, FWD
Old 04-18-2016, 09:35 PM   #5
I notice you have listed your current an previous trailers along with your tow vehicle? Is that what I'm reading? Is that a typical things people do on this site? Additional question:
Is it normal for the converter to make a humming noise when the switch is puled out?
Old 04-18-2016, 10:22 PM   #6
bikendan's Avatar
Yes, it's called your sig line. Most of us at least list tow vehicle and trailer, so others can see what you have, when you ask questions.
Yes, it's normal when plugged into shore power or generator, since the converter will start recharging the battery when it has 110v AC supply.
Old 04-19-2016, 04:05 AM   #7
bareftn's Avatar
On my 2016 23ss the battery disconnect switch on under the trailer hitch under the propane tanks
bareftn is offline   Reply With Quote
Old 04-19-2016, 05:00 AM   #8
bikendan's Avatar
The OP has a 2013 and the disconnect switch was inside the trailer.
FR changed the switch location in 2015.
Old 04-19-2016, 05:40 AM   #9
fonzie's Avatar
push in to disconnect.....pull out to connect
Name:	push-pull battery disconnect.jpg
Fonzie
battery, battery disconnect
