Old 08-02-2021, 01:53 PM   #1
Battery hook up
We just discovered over the weekend in our 2007 Roo 21ss. We tried hooking up the battery by turning off all power. When we connected the ground wire it sparked meaning there is a short in the battery wiring system somewhere not sure how to find and and not even sure since we always use electric hook up on our site if we need to worry about it. We did connect the red to the postive and the white wire to the negative.
Zeus1972 is offline   Reply With Quote
Old 08-02-2021, 02:04 PM   #2
That may not be true there my be something left on pulling power anything inside like refrigerator,tv can draw power even off, convertor.
cfo111 is offline   Reply With Quote
Old 08-02-2021, 02:30 PM   #3
Most likely something is left on. If you had a direct short in the 12 volt system it would be there and short out the converter when you plugged into shore power. That would blow the converter fuses and you wouldnít have ant 12 volt power. At least thatís my thoughts.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-02-2021, 02:57 PM   #4
I've only had 2 trailers, a popup and a tt. In both cases the CO monitor is wired direct to the battery.
mysery1 is offline   Reply With Quote
Old 08-02-2021, 03:25 PM   #5
So now you guys or gals have me thinking we have pulled the fuse from the Propane detector since it is outdated and purchased a new plug in style which I know I unplugged but I also know we didn't turn off the refrigerator. I try to remember to unplug everything do you think that or the microwave being plugged in could be the problem. I have never had to do this before so I wanna do it right.
Old 08-02-2021, 03:38 PM   #6
I see a small spark every time I connect my neg cable to the battery. I don't think it indicates anything is wrong, does it?
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 08-02-2021, 03:41 PM   #7
Always Learning
You're mixing 120v items and 12v items. The battery only comes into place for 12v items - things like lights, propane detector, CO detector (which is usually 1 thing), radio, bathroom vent fans, breakaway switch/brakes, and fridge if it runs off of battery+propane, etc. These are the fuses in your power distribution panel.
120v items are things like the household plug for the fridge, microwave, and really anything else that plugs into a standard household outlet.
If you're getting a spark, it's because there is a 12v draw on the system.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 08-02-2021, 03:43 PM   #8
Flybob's Avatar
Any 12V item with a remote ( Radio) etc will be drawing a small amount of power. I would not worry about a small spark as it just indicates something is on.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-02-2021, 07:14 PM   #9
Alright so hubbie just told me that we didn't turn off the fridge and when he connected the white ground wire it sparked and kept sparking would that be the fridge causing that. I wanna try again this weekend so wE have the battery if we need it but this scares me.
Old 08-04-2021, 03:00 PM   #10
Chuck_S's Avatar
Kept sparking?!
-- Chuck
Chuck_S is offline   Reply With Quote
Old 08-04-2021, 03:06 PM   #11
Retired Old Fart
dward51's Avatar
By "turned everything off" did you also disconnect from 120v power (unplug the trailer)? If not the converter is still running and producing current to the battery. That would make the spark you described. Even if the battery was fully charged, the converter will cycle through to determine the state of charge and spark a little.
FYI, your car/truck will do the same thing when you hook the battery back up. Little phantom loads abound.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is online now   Reply With Quote
Old 08-04-2021, 03:10 PM   #12
We did not unplug the trailer. We turned off the main switch at the plug. Will try doing it this way again this weekend unpluging at the main and turning everything off inside the camper. Fingers crossed that it works.
Old 08-04-2021, 03:53 PM   #13
llr
Are you sure the correct wires are hooked to the correct battery terminals? The color codes are not very standard so you need to pay attention to what is connected where.
Is there ant damage to the terminal or battery where the spark cam from? If it was actually a short there should be some melting and black marks. If not I wouldn't worry about it to much.
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 08-04-2021, 03:55 PM   #14
Originally Posted by Chuck_S View Post
Kept sparking?!
-- Chuck
I have the same question as Chuck.... what do you mean by kept sparking? Once the battery is connected (the circuit is completed) there should be no sparking. A small spark when the initial contact with the battery is made is OK, but constant sparking would indicate a short/bad battery/wires connected to incorrect terminals.
Old- 2002 21 Roo
Old 08-04-2021, 03:55 PM   #15
I did trace the white wire back and it is connected to the frame and the red wire goes further and up into the camper so I am hoping that is correct. There is no damage to the battery or the terminal that I can see.
Old 08-04-2021, 05:34 PM   #16
Chuck_S's Avatar
Kept sparking -- as in sparking continuously?!
-- Chuck
battery
