Hello. We’ve had our 2015 23IKSS since new, and recently I’ve noticed that the inside part of the bunk hinges are looking bent (both front and back bunk). The hinge itself is straight when I check it outside, and the bunks open fine. But there is a noticeable arch in that white bar in the pics below. That bar use to be pretty much flat on the cabinet top below.
Have any of you had this happen, and any suggestions on what might be causing it & how to fix it? Thanks!
