Old 06-10-2021, 11:17 AM   #1
Black tank slider shut off valve
2017 19' ROO, My drain valve is acting up and will not open all the way , Any ideas how to tear it apart and fix it ??? thanks Bob
pudgybear is offline   Reply With Quote
Old 06-18-2021, 07:06 AM   #2
Chuck_S's Avatar
If the valve doesn't respond to some silicone spray lube (or even WD 40) replace it.
These are $20 valves and held together with 4 bolts. Should be nearly obvious how to replace it. Tip: buy the new valve before removing the old one. Tip 2: be prepared for a mess when you remove the valve.
-- Chuck
Chuck_S is offline   Reply With Quote
black, black tank, slide, tank, valve
