05-02-2020, 01:03 PM
#61
Lets go camping!
i run mine on low and keep the fan on the entire time. that way air is always circulating.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
05-03-2020, 12:09 AM
#62
Originally Posted by rockfordroo
With regards to no restriction of air flow - If you have ceiling vents, you need to make sure that the passageway from the AC's cold air plenum to the ducts through the ceiling are fully open. They have to cut these duct themselves during manufacture and if they don't make them large enough, you don't get enough air flow. You have to either drop the inside grille, or go on the roof, remove the AC cover, then remove the metal cover of the plenum.
Here's a pic of the plenum cover:
Attachment 228136
Here are some pics of mine that I had to make larger. The pics looking down the ceiling duct, taken from one of the ceiling registers.
This pic is before I reamed out the passageway. I went with removing the AC cover and the metal duct cover. The light area on the right is the passageway from the duct to the cold air plenum.
Attachment 228132
This pic is after opening the passageway. You can see the foam I cut out lying on the floor of the duct and the light through the passage way is brighter.
Attachment 228133
Thanks. I cleaned out the unit the other day and checked the openings going from the AC to the ceiling as well as the separation between the return and the vents. That was all fine. I will have to inspect the vents themselves tomorrow with my boroscope.
05-03-2020, 07:47 PM
#63
Hey guys I’m new here but I just read this today that might help shed a little bit of insight. This came directly from the quick reference guide from Forest river.
This just is in regards to high humidity and AC
05-03-2020, 08:52 PM
#64
Originally Posted by NJKris
I am still amazed that people choose to live in some of the most inhospitable environments in the country! Blazing hot southwest, oppressively humid deep south (served my time down there, love the people, hate sweating all the time!) or bitter cold Minnesota for example.
I am stuck in NJ till wife retires. NJ has it's own horrors, but not usually climate horrors. If it were not for my family and friends, I would move in a heartbeat.
I moved from Florida to New Jersey when I was a teenager. Hottest summer I’ve ever had! I’ll take an air conditioned house in Florida over a non-air conditioned house in New Jersey any day!
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
05-04-2020, 07:14 AM
#65
Trailer Park Supervisor
Gator, we can get Florida hot, but usually only when Florida sends it's hellish heat up our way! It just followed you!. Before I joined the service and moved south, we had no A/C, and my sisters and I would fight over who gets the one fan in the house. Then when I lived in Florida, the cars I had did not have A/C option. The one car was a convertible Triumph Spitfire. From all the time in the sun, when I would go home on leave in the winter, I looked like I was adopted in the Christmas pics.
Yes, I drink the water!
05-06-2020, 10:33 AM
#66
Originally Posted by Wlasota
We have a Cedar Creek 5th Wheel. During air conditioning season I remove the return heat grill and fill that area with 2 “ foam insulation. Than replace the grill. I noticed (since cold air tends to fall) that a portion of our cool air was going into that return and in turn cooling the underbelly. Don’t need cooling in the underbelly. It made a significant difference in compressor run times. Just need to remember to remove the insulation prior to firing up the propane heater.
So how are you attaching/ keeping in place the insulation in the return?
05-06-2020, 10:43 AM
#67
In a hybrid it is going to be a challenge.
Try low all the time.
05-06-2020, 11:03 AM
#68
Maybe this, instead
How about just removing the grille and wrapping it with a scrap of 10 mil construction vinyl, tucking the vinyl around the back, maybe using a little masking tape to keep it in place? Then remount the grille, piercing the vinyl with the four mounting screws.
Larry
05-17-2020, 10:29 AM
#69
Boondocking in hot weather in a hybrid is why I sold mine.
