Assuming you have ducted AC. If so, they may not have opened up the passages from the AC's cold air plenum into the ducts large enough. Below is a pic of the opening of the passage from my duct to the cold air plenum.
In this pic, you can tell the light from the plenum is a little brighter and you can see the foam I cut out of the restricted passage laying on the bottom of the duct.
I accessed mine from the roof, but it's probably better to do it from the inside. Also while you're in there, check the barrier between the hot and cold plenums. Very often this barrier is not installed properly, or has leaks around the edges.
See Fig 1 in the attached for the passages ("Supply air ducts") and the barrier ("Duct Divider").
