Old 09-03-2019, 12:52 PM   #1
cold weather camping
If I heat my freshwater tank and lines and put antifreeze in my black and gray tanks should I be good to say 10 Degrees?
sunnyside1 is offline   Reply With Quote
Old 09-03-2019, 12:58 PM   #2
Are you planning on 10 degree weather round the clock or just at night?
If it warms above freezing during the days then you should be more than safe with the precautions you stated.
That said, my TT has heaters on all tanks underneath. Only thing I worry about freezing is my freshwater hose and it gets put away at night when cold.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-03-2019, 01:02 PM   #3
I guess I would like to plan for the worse case scenario . is your belly open or enclosed?
Old 09-03-2019, 03:18 PM   #4
sure.
ppine is offline   Reply With Quote
camping
