02-05-2021, 07:27 PM
Coleman stove to Quick Connect
I have read several of the posts but I am still confused! I want to use my Coleman 2 burner stove and have it hooked thru the quick disconnect where the grill that came with the trailer hooks up. Will the hose I will try to link to below do the trick, or is there a problem with having 2 regulators in line?
https://www.amazon.com/dp/B081RJCTHY...1-456d4aaaa91c
02-05-2021, 07:43 PM
You do not want two regulators in line! Is the regulator that came with your stove a regulator only, or does it also have the flame control valve integrated with it. If the former easy to convert. If the later, not so easy.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
02-05-2021, 07:59 PM
nope no flame control. Just the one pound LP tank fitting into the small hand screw connection into the side of the stove.
02-05-2021, 10:51 PM
Always Learning
There is a product by Torjik called Convert-a-C that adapts Coleman grills for low pressure use.
02-06-2021, 11:10 AM
thanks for all of your info I think I will just carry a few more 1lb tanks. I refill them as I need them anyway. Just trying to reduce the junk I carry
02-06-2021, 11:27 AM
Trailer Park Supervisor
can always put a Y connector on one of your trailer tanks, then just get a hose that has an acme nut connector for propane tank on one end, disposable tank connector on other end. I have a shorter hose like that, I just bring one 20# tank extra, and use the 20# tank to connect everything from Coleman stove, to table top BBQ, to propane firepit.
Yes, I drink the water!
02-06-2021, 01:05 PM
Typical "bottle" LP stove uses a simple pressure regulator and runs on "high" pressure. Stove in the camper runs thru a 2-state regulator (you can see it on the front of the camper) and runs on "low" pressure. Stoves designed for one system seldom work on the other.
-- Chuck
02-06-2021, 03:03 PM
Don't know which stove you have, but you might look at propanegear.com to see if they have a hose or adapter that will work. They have lots of them.
02-06-2021, 05:26 PM
^^ This. I too rock a Y-split off one of the 20# tanks to bypass the onboard regulator and run all my other propane goodies from the split line...
02-06-2021, 05:54 PM
I ended up converting my Camp Chef 2 burner and my Weber Q to low pressure and run a Y off the quick connect on the side of my trailer. I can run both at the same time without issue or degraded performance.
Hobienick
2022 Grand Design Imagine 2800BH
2020 Rockwood Roo 19 (Sold Jul 2022)
2012 F150 SuperCrew Ecoboost
02-07-2021, 02:15 AM
Always Learning
I absolutely hate dealing with the 1 lb tanks. I always seem to run out mid-cooking and don’t realize it until I check the grill again.
02-15-2021, 01:40 PM
How were you able to convert Q grill to low pressure?
02-15-2021, 02:09 PM
The regulator is built into the cylinder connector. Those cylinders have a 240 psi operating pressure. Without a regulator your burners would resemble a blow torch flame.
2016 Salem 27RKSS
02-15-2021, 02:13 PM
A typical Coleman appliance conversion to low pressure QD's will look like this:
2016 Salem 27RKSS
02-16-2021, 08:20 AM
Always Learning
Convert-a-Q kit by Torjik:
https://learntorv.com/weber-q-convertaq/
02-16-2021, 08:53 AM
Not the least expensive solution, but works very well is a 5lb propane tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
