Old 09-21-2020, 01:46 PM   #1
Different tires on Roo...
Basic question: 2021 Roo 233s
One tire has a nail in sidewall and needs replacement. It came with 4 Goodyear endurance tires (205/75 14). Those tires are out of stock nation wide until Q1 2021 per local Goodyear store.
Can I replace one tire with Carlisle trailer tire?
Docedward is offline   Reply With Quote
Old 09-21-2020, 02:04 PM   #2
rsdata's Avatar
sure... make sure it is the same size... did you not already have a spare tire?
If you have the spare on the trailer now... do you feel lucky and drive without a spare until you can get another GY Endurance?
is the GY store a company store or just a dealer? GY owned stores have a better track record getting the Back Ordered tires quicker...
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 09-21-2020, 02:27 PM   #3
I have the spare on and it did not look like a GY Endurance. Ill look again when I go back out to the storage facility. I do not feel lucky seeing that Ive got a nail in the sidewall and this is the third tire from nails on 2 cars and the RV in one season.
I called local Goodyear Auto store and one outside of town. Both had same answer that theyre on back order.
Old 09-21-2020, 04:54 PM   #4
Retired Panpsychist
Theo's Avatar
Check out Tire Rack using your zip code. For my area (New England), they're available by mid-October.
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
Old 09-22-2020, 02:00 PM   #5
I just check tire rack and for my location I can get them wed
Shipping Quote
Shipping Cost to ZIP/Postal Code 07840 (change ZIP/Postal Code) for:
Qty.Size and DescriptionItem Total
4 205/75R14 Goodyear Endurance Trailer Use Only$475.96
Distribution CenterInventory Status Est. Delivery DateShipping Cost
Windsor, CT0 9/29/20 Wed, 09/30 FREE
merchjo is offline   Reply With Quote
Old 09-22-2020, 02:34 PM   #6
coney's Avatar
Shipping Quote
I bought 4 tires the same size load rating D $ 125 each mounted and balanced
Central Joisey
2017 Nissan Pathfinder SL
2014 Rockwood Roo 19
coney is online now   Reply With Quote
Old 09-22-2020, 02:35 PM   #7
Originally Posted by Docedward View Post
I have the spare on and it did not look like a GY Endurance. I’ll look again when I go back out to the storage facility. I do not feel lucky seeing that I’ve got a nail in the sidewall and this is the third tire from nails on 2 cars and the RV in one season.
I called local Goodyear Auto store and one outside of town. Both had same answer that they’re on back order.
A hazard of RV-ing is that many campers use their "work trucks" to tow RVs. Add to that the fact that many campgrounds are off the beaten path a bit (with rougher roads on the way in), and I've collected more than my share of sheetrock and deck screws and nails in both my RV tires and my TV tires.
Sloppy/lazy TV prep obviously threatens the perpetrator's RV tires, too, but most are too lazy to clean out their TV's bed/cargo area, and one thing leads to another. It goes with the territory...sadly.
As for mixing brands of tires, it's not ideal, but it's also not a big deal. Why? There are no driven wheels on a travel trailer or fiver. A slight difference in circumference won't eat up a differential. The worst case scenario is that the slightly larger tire on a trailer will carry a slightly larger portion of the load on that pair (or trio) of axles. Don't worry about it.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
roo, tire, tires
