Old 05-22-2023, 09:31 AM   #1
Do step stabilizers really work?
I just purchased a SolidStance step stabilizer and was curious of people's experience with them? Seems like when stepping on the bottom step (where the support is installed) it would work, but when stepping on the middle or upper step, wouldn't the bottom step move along with the camper and not provide any support at all? It seems like the support should be under the highest step not the lowest one, am I missing something? Thanks
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 05-22-2023, 10:53 AM   #2
GalsofEscape's Avatar
i dont have that particular item, but i do use a quick products step stabilizer. put it under the bottom step (we have the old two step pull out stairs). it works well for us keeping the camper from moving when we use the steps - and we are not lite people.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 05-22-2023, 11:04 AM   #3
I can't see your installation but if you installed them on a folding lower step, then they would do exactly as you have described. I think the idea is to provide stabilization on the longest part of the lever. (the bottom step)
On our last R/V with 4 folding steps, I put a scissors jack under the 2nd step from the bottom when the steps were deployed and it worked well.
On EDIT: Watch this video (especially the first 40-50 seconds) and you'll see the flex you described.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-24-2023, 11:54 PM   #4
rbq
I bought one of those & had to return it. My steps were not wide enough for it to work. I really wanted it to work, but no way.
2014 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 05-25-2023, 06:20 AM   #5
Semperfi24's Avatar
I havent used that specific item, but I have used something else and in my experience it really did make a difference. The product I used went under the frame rather than under the step.
Like this:
https://www.campingworld.com/univers...wwnJqbbEW9levU
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 05-25-2023, 06:32 AM   #6
Georgia Rally Coordinator
aceinspp's Avatar
They have slide out tubes or braces what ever they are called. I used one of these to put under the frame of the camper just behind the step. It was adjustable. Worked great plus I had a pair of step stabilizers attached to the bottom step. I had the fold up 3 step. The stabilizers where permanently attached to bottom step and you folded them up against the bottom of the step when you got ready to travel,. These two items sure made the camper rock prof. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
aceinspp is online now   Reply With Quote
Old 05-25-2023, 06:39 AM   #7
fonzie's Avatar
I use a scissor jack under second step and it works for me.
Fonzie
Old 05-25-2023, 07:58 AM   #8
I have this device installed on the bottom step of my TT. It does a great job of eliminating the stair flex when in use with no movement of TT when the stabilizer jacks are also in use.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 05-25-2023, 10:00 AM   #9
I have it on our Wildcat 5er and I would not live without them now.
keizer_or is offline   Reply With Quote
Old 05-25-2023, 11:17 AM   #10
Our Wildwood has a Lippert SolidStep - little bit different from the SolidStance in that the ends telescope out instead cranking down from the step. I don't think our 3 year old would be able to navigate the steps without some sort of stabilization. Heck, even with the SolidStep she has a tendency to fall off. Apparently she got her Dad's (meaning my) sense of balance and gracefulness.
2022 Wildwood X-Lite 273QBXL
2019 Nissan Titan XD Diesel
K_M_H is offline   Reply With Quote
Old 05-25-2023, 11:28 AM   #11
We have the Lippert solid steps and we had to put the carpeting on them because the dogs wouldn’t walk on the aluminum
2021 Flagstaff 27BHWS
2024 Silverado 2500
G37x is online now   Reply With Quote
Old 04-05-2024, 02:38 AM   #12
I think you are right. Besides that, I just mounted the Lippert unit on my lower step, now unable to stow steps for travel. Almost can, but it's too tall by at least a 1/2". If I try to force it in, may be very difficult to get back out. I will try as you suggest. Thanks!
planes48 is offline   Reply With Quote
Old 04-05-2024, 07:21 AM   #13
Hmm, that does not sound right. Are you sure your removing the pins and folding the feet in so they lay flat? I have the same unit on my main entrance and it works fine. If I do not fold the feet under it will do as you say.
2017 Wolfpack 315 Pack 12 5th wheel Toy Hauler
2013 F250 6.7 Diesel Dually 4x4
Odyknuck is offline   Reply With Quote
Old 04-05-2024, 11:06 AM   #14
It is the U-channel mount that is too tall, not the stabilizer arms. Contacts the bottom of the trailer when pushing in to stow. Migh be able to force it, but may also be tough to pull out again. I'll look at it again when the rain stops.
Old 04-05-2024, 11:28 AM   #15
Are you folding the bottom step in first? If not it will not work correctly.
Old 04-05-2024, 01:35 PM   #16
Yes, same as always before. Lift and push in to store is where the U-frame contacts the bottom of the trailer before it drops into stowed position.
stabilizer, stabilizers
