Old 10-20-2021, 06:23 PM   #1
door locker 2104 roo ikss
are all lock sizes the same?I have a roo2014ikss .
thanks
liz12 is offline   Reply With Quote
Old 10-21-2021, 08:33 AM   #2
Yes (CH751 are universal in most RVs), except for the door bolt lock and the outside shower.
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 10-21-2021, 08:49 AM   #3
door lock
that's what I need the main door bolt .
Old 10-21-2021, 10:15 AM   #4
Rhumblefish's Avatar
Note: Newer models are keyed aliked, Liz, so your year make and model are important.
While TT locks aren't much of a deterrent (if any) to a determined thief, it's helpful if (1) you have less keys to carry to use your TT (vs one for the door, one for the storage compartments, and one for the shower), and (2) you're not securing your TT with the same CH751 key that every other TT owner has.
Lots of viewpoints here for a common problem. but if you just need a new key for your main door, or need a new lock AND key, you can simply order them from any number of sources:
https://www.easykeys.com/rv/keys
https://www.etrailer.com
http://www.amazon.com
etc.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is online now   Reply With Quote
Old 10-21-2021, 10:28 AM   #5
Chuck_S's Avatar
My camper came with half a dozen keys for the main door. Got one left? There's a key number on it you can use to order a couple more on-line. There was a key for the latch that only opens that and a different key for the deadbolt that opens both (and the bed doors on my Roo) so that's really the only one I need.
CH751 opens locks everywhere including the security panel on my home security system and my backyard shed. Always handy to have one around. I think it also opens the external storage on the Roo.
YMMV.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 10-21-2021, 05:14 PM   #6
Retired Panpsychist
Theo's Avatar
On our 2020 Roo, the deadbolt key has a "G" code stamped on it. With that code, you can get a replacement key made. The code may also be on a white sticker placed on the inside housing of the lock.
One of the first things we did was to convert all the CH751 locks (including the bunk locks) to be the same as our deadbolt. We find it much easier to have a single key for all locks.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
210, door, lock, roo
