Originally Posted by RACarvalho
yes, you will get water there but it drain.
I'm not sure if there is a hole for this water to drain or it drains running under the aluminum rail but in ours it drains.
I would look for wood dust clogging something.
Another thing is leveling the trailer: Was the trailer level when you saw this?
The water drain so slowly that 1 hour later it was still there.
As for leveling the trailer was level.
I will see if there is a purposeful drain that maybe plugged.
Thanks for the reply.
