Good job!! Since there is also a potential liability issue if you had an accident without brakes, this was a very good idea. Ford does make it easy. I changed my 2001 F150 from a 4 pin to to 4/7 pin. Easy plug and play. All the wiring was already there for a 7 pin.
Anyway, good job!!
P.S. You might want to check and see if the relay and fuse are in place in your fuse box for the "hot" wire that provides 12V to the trailer. For whatever reason, these are typically not installed at the factory. This allows you to charge the trailer battery while towing. If you have a 3-way fridg, it will also allow you to run the fridg with truck power while towing. Our pop-up had one of those and it was handy. Our Surveyor is only 2-way though so we have to use the propane while towing.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
